Chocolate covered circus peanut
Icehouse
Well somehow I want to drive it to Canby.....  Maybe.  Either way I'm going for it.  I haven't worked on it as much as I'd like to.  Here are some updates of rust repair and IC/Rad fitment.
Added some weld nuts for the IC
Got everything mocked up.  Still adjusting in this picture though.   Think I might pain the IC black on this build.  Hide it a little better.
Had to move the rad inlet, hopefully it will work there.  I check on Franks car but who knows.
Making the pipe a size I can get couplers for...  Stupid pipe and tube being differently measured.
Ground clamp broke mid project, this seemed to work rather well actually :)
Frank washed my motor for me.
Before:
After:
  • Like 8
  • Replies 195
  • 3 weeks later...
Getting closer!  I was try to get it ready for Canby but my wife decided to shatter both her leg bones near her ankle! Needless to say it was a pretty crazy week!  Anyways here are some updates on the build.  Finally got some paint in the bay!
EOkfFBx.jpg?1
xdNYHii.jpg?1
Here is the piece I cut out.  This is from the good side!
Epox and some mud!
Filler primer
Paint
  • Like 12
  • 4 months later...
How close is that to original paint.
I really like that color.
The coupe was originally the super pale yellow, almost a white.  Basically the color the engine bay was minus the rust and grease.  The color I sprayed the engine bay is butter scotch.  It was the color of my first 510 and one of my favorites.  So I decided to go with it.   Lets see if I can dig up a photo of my first 510.
  • Like 5
I'm not buying that that's you in the pic. Lol.
I forgot me and Sedona re did the dash.  Rich gave me a mint dash pad.
brand new factory clutch master :)
  • Like 5
  • 4 weeks later...
Need a fuel tank for the endure car.  I figured I could pull the coupe tank and use it.  Since I had a tank Rich modified for it waiting to go in.  Well turn out the coupe tank is junk.  But it was good getting it ready for the new tank anyway.  I gotta get this car going.  Sick of seeing it sit in my garage anyways.  So I pulled the tank, wire brushed all the rust and banged the tire well somewhat straight.  Some idiot picked it up with a forklift!!!  Dented the spare tire well really bad.  Not sure how visible it will be in the photo.
HHHMM someone did some welding at some time in the past.  Kinda scared to dig into that area later.
other side....
Found this under the tank
mmmmhhhh candy!!!
Must be newish.  Still squishy.  Gas door has part number on it too.
Bam new!
m6yb2EU.jpg?1
  • Like 5
