240zness Posted May 8, 2017 Author Report Share Posted May 8, 2017 Right , current levels in the column switches are to high. Relays eventually Will check the bulbs and I have one that was working when removed 1 Quote Link to comment
240zness Posted May 11, 2017 Author Report Share Posted May 11, 2017 Fixed , something with the brights... Clicked brights on with combo in parking , then to headlights. Brights came on , click off.. headlights on. Guess just some corrosion Love old cars 2 Quote Link to comment
S30Jay Posted May 13, 2017 Report Share Posted May 13, 2017 Glad you found it. 1 Quote Link to comment
240zness Posted May 18, 2017 Author Report Share Posted May 18, 2017 Parking lights circuit out now .. just an update .. cars running great :) Hope I get the thing put back together , some picks of a complete car. Quote Link to comment
Bleach Posted May 19, 2017 Report Share Posted May 19, 2017 I had a 1975 280Z that had the parking light circuit continually blowing fuses. I put in a slightly higher amp fuse ... blew that too a few days later. Not good. So I just re-wired only the running lights and then sold the car later. It was kind of a junky Z. 1 Quote Link to comment
Charlie69 Posted May 19, 2017 Report Share Posted May 19, 2017 Nice work and enjoy it! Quote Link to comment
240zness Posted July 13, 2017 Author Report Share Posted July 13, 2017 Trying to throw something up here even though haven't worked much on the Datsun. Driven about 3500 miles and see some Small oil and Coolant leaks. Main front seal and thermostat housing bolt getting crusty. Looks like the gasket sponged up liquid to the inside bolt. After refinishing the neck and filing bottom housing , nissan gasket and slightly longer bolts still small drops forming splattering onto valve cover. Re nickeled intake manifold lines are showing some crusty threads also. Have plans for monitoring and resealing housing , replacing lower.. So giving the daily driving up on the Z, decided to work on electrical for lights. Reconnect all markers lights etc. With connector cleaning , some spade issues. Probably check the turn signal switch internal. Realize that hazard switch has caused problems with past turn signal problems. Its very sticky and I'll try to get stuff working with some giggling with all the circuits complete. And I bought an new switch , will wait to try since I feel like the whole harness fuse connector swich system needs more attention Quote Link to comment
240zness Posted October 20, 2017 Author Report Share Posted October 20, 2017 Before after , dropped of at lakeside auto body . Drove out there for some reason. Liked it , country Quote Link to comment
240zness Posted October 20, 2017 Author Report Share Posted October 20, 2017 New wheels few weeks ago, guy with a really nice '72 near me. Whole suspension torn apart in his garage. Cool to see. I'm still running oil filled shocks in front. Springs, shocks and a bushing kit next , at a shop.. Quote Link to comment
240zness Posted November 8, 2017 Author Report Share Posted November 8, 2017 Bump my own .. Original fiberglass headlight buckets To be replaced with steel .. after painted Quote Link to comment
Bleach Posted November 27, 2017 Report Share Posted November 27, 2017 Did you end up painting already or is that still happening later? Quote Link to comment
WallRocket Posted December 6, 2017 Report Share Posted December 6, 2017 Damn! That engine is NICE! Quote Link to comment
mrbigtanker Posted December 6, 2017 Report Share Posted December 6, 2017 Wow looks good. Great work on engine. Quote Link to comment
240zness Posted December 7, 2017 Author Report Share Posted December 7, 2017 Working on painting buckets that fit, found some issues into that front corner .. little separation headlight wall to fender to nose.? Then theres colour matching , the paint job is not quite code 918, have some thin areas, chips. Thinking about respray. Quote Link to comment
240zness Posted December 7, 2017 Author Report Share Posted December 7, 2017 Good colour there Quote Link to comment
240zness Posted February 1, 2018 Author Report Share Posted February 1, 2018 Guess the hole thing needs repaint.. Working on signals valences.. screws into plastic threads. Mine are in good shape broke two screws Quote Link to comment
240zness Posted February 1, 2018 Author Report Share Posted February 1, 2018 Floor repairs.. uhh I smeared that seam sealer. Picked it up , they said it's wet but put floor mats and my rubber mat hole covers back in when I pulled up I ended up scraping off excess.. need to re paint Quote Link to comment
240zness Posted February 1, 2018 Author Report Share Posted February 1, 2018 At least it's sealed and waterproofed But , would've liked to be more delicate.. my felt trans tunnel got ripped out. Needs to be restored Fender fix turned into more.. One piece floor replacement.. tacked to frame rail and two inches up all the way around, and sealed Other holes were fixed with tacked on patches and sealer , then sprayed with the hard seal rust preventer. Quote Link to comment
240zness Posted February 1, 2018 Author Report Share Posted February 1, 2018 Still waiting for spot into the rack for front end .. Rear end is suffering.. diff oil blowing out , half shafts seam ok That level or filler plug are thought to get to huh.. plus never been removed I'm guessing Then there's the whole forward diff 30mm thing. Some issues even with the mustache bar etc.. the diff mount and strap need mods to work. Quote Link to comment
240zness Posted February 1, 2018 Author Report Share Posted February 1, 2018 All lighting issues were fixed by replacing a fuse that measured ok but blew when pushed down. Combo switch has needed a few extra resets , and the the fuses get hot, but everything functions. Would like to properly restore the nissan connectors with new spades.. Quote Link to comment
