a15egi Posted October 14, 2016 Report Share Posted October 14, 2016 Hi guys . Found this rusty gold . It has single outlet exhaust compare to my previous a15egi which is cast iron 4-2-1. dualhead valve spring. cam profile for high rpm. looks like i need to start new project... going to empty my pocket again :( [/url]">http:// [/url]">http:// [/url]">http://http://s1212.photobucket.com/user/Mariese_Shathasivam/media/a14e1.jpg.html'> 3 Quote Link to comment
Draker Posted October 14, 2016 Report Share Posted October 14, 2016 Worth big money... world wide! 1 Quote Link to comment
KoHeartsGPA Posted October 14, 2016 Report Share Posted October 14, 2016 Interesting! 1 Quote Link to comment
a15egi Posted October 15, 2016 Author Report Share Posted October 15, 2016 My previous a15 egi [/url]">http:// [/url]">http:// [/url]">http://http://s1212.photobucket.com/user/Mariese_Shathasivam/media/a15egi3.jpg.html'> 1 Quote Link to comment
a15egi Posted October 18, 2016 Author Report Share Posted October 18, 2016 Hi guys, a14/a15 came with carburetor and efi. ga16 also carburetor and efi. So, can i adopt GA16DE wiring and ecu to make my a14e/a15e work? 1 Quote Link to comment
Draker Posted October 18, 2016 Report Share Posted October 18, 2016 a15 maybe, a14 might be too rich. Although, if you can adjust the air meter.. you might be able to lean it out a bit. 1 Quote Link to comment
a15egi Posted October 18, 2016 Author Report Share Posted October 18, 2016 stand alone ecu will be the better choice? 1 Quote Link to comment
Draker Posted October 18, 2016 Report Share Posted October 18, 2016 I can't say for sure. I don't have much experience with these specific EFI setups. But what I can say is some of the fair meters are adjustable. Which gives you the ability to lean out the mixture a bit if being used on a smaller displacement engine. Something along these lines: http://atlanticz.ca/zclub/techtips/afm/ 1 Quote Link to comment
Lockleaf Posted October 19, 2016 Report Share Posted October 19, 2016 Ga engines came fuel injected in 1.4 and 1.5 liter. If ga16 is common where you are, you could set it up on that stuff and then swap out the ecu for the smaller motor version if you wanted/needed to. I would just about guarantee that if the ecus are the same age, they will use the same connectors, so it would plug right in. 1 Quote Link to comment
a15egi Posted October 19, 2016 Author Report Share Posted October 19, 2016 thanks for the input... :) Quote Link to comment
a15egi Posted December 22, 2016 Author Report Share Posted December 22, 2016 [/url]">http://http://s1212.photobucket.com/user/Mariese_Shathasivam/media/WP_20161219_15_24_59_Rich.jpg.html'> bought another set.... almost complete. 1 Quote Link to comment
Draker Posted December 22, 2016 Report Share Posted December 22, 2016 omg... dude! Congrats. Unbelievable! 1 Quote Link to comment
