gmkeegan Posted October 13, 2016 Report Share Posted October 13, 2016 Hi guys i'm about to start working on my L18 and want to change my points into a electronic distributer? any suggestions? i have found this one wanted to know if anyone else is running this one thanks https://www.amazon.com/Nissan-Datsun-Ignition-Distributor-BlueBird/dp/B01KPRCQM2/ref=sr_1_1?ie=UTF8&qid=1476385608&sr=8-1&keywords=Datsun+L18 Quote Link to comment
racerx Posted October 13, 2016 Report Share Posted October 13, 2016 is that hot spark? careful. Quote Link to comment
datzenmike Posted October 13, 2016 Report Share Posted October 13, 2016 Find a Datsun matchbox distributor, much better quality. That looks Chinese made. All '79 and 80 L20Bs had them That would be the ... '79 620 truck '80 720 truck '79 S10 (200sx) '79 A10 (HL510) Another that will work is the '79 and '80 A10 (HL510) with Z20S and the '80 S110 (200sx) with Z20E engine. In both cases it must have a 4 spark plug head. All California models had 8 spark plugs and won't be the same. All '78 L20Bs had a similar EI distributor called a remote igniter that can be easily converted to use a General Motors HEI module. 1 Quote Link to comment
flatcat19 Posted October 13, 2016 Report Share Posted October 13, 2016 Hi guys i'm about to start working on my L18 and want to change my points into a electronic distributer? any suggestions? i have found this one wanted to know if anyone else is running this one thanks https://www.amazon.com/Nissan-Datsun-Ignition-Distributor-BlueBird/dp/B01KPRCQM2/ref=sr_1_1?ie=UTF8&qid=1476385608&sr=8-1&keywords=Datsun+L18 PASS. Use the list posted by Mike above and buy one from RockAuto. Also need cap, rotor, wires, plugs, and a coil from the same vehicle. Then look up how to eliminate the ballast. Quote Link to comment
banzai510(hainz) Posted October 13, 2016 Report Share Posted October 13, 2016 85 $ I should try it out Quote Link to comment
gmkeegan Posted October 15, 2016 Author Report Share Posted October 15, 2016 Find a Datsun matchbox distributor, much better quality. That looks Chinese made. All '79 and 80 L20Bs had them That would be the ... '79 620 truck '80 720 truck '79 S10 (200sx) '79 A10 (HL510) Another that will work is the '79 and '80 A10 (HL510) with Z20S and the '80 S110 (200sx) with Z20E engine. In both cases it must have a 4 spark plug head. All California models had 8 spark plugs and won't be the same. All '78 L20Bs had a similar EI distributor called a remote igniter that can be easily converted to use a General Motors HEI module. PASS. Use the list posted by Mike above and buy one from RockAuto. Also need cap, rotor, wires, plugs, and a coil from the same vehicle. Then look up how to eliminate the ballast. thank you guys i'm going to eagle rock next month and if i cant find anything i will be ordering from rockauto. Quote Link to comment
