Skyline C110 Kenmeri front struts Inserts.
  • Replies 4
What's in there now????
If it still has the original oil filled dampers, do what I did on my Datsun. Dump the thin watery oil out and replace with 20W (or 10W or 15W) motorcycle fork oil. It's thicker so resists being pushed through the valves more. The problem with inserts is who knows what the compression and rebound rates are? They are unknown and if not all the same are some generic amount. I hear about running VW Rabbit inserts??? what? they are designed for a Rabbit not a Datsun.
Your struts were designed with the proper valving for your car, all you need is having them a bit firmer.
I used BelRay 20W motorcycle for oil about $17CDN per liter. That's enough for 3 struts. Full of anti foam and rust inhibitors.
