DogoX Posted October 10, 2016 Report Share Posted October 10, 2016 Hello guys, I'm doing and engine swap, and need some advice on front brakes. Not looking to use the 1200 hub at all, but keep the factory struts that will be convert to adjustable coilover with the T3 kit installing a 15x4 ford 5 lugs 4-5 bolt pattern front wheel I have read around but mostly swap are people wanting to keep the 13" wheels. what are my choices for bigger brakes using 5 lugs thanks in advance! Quote Link to comment
datzenmike Posted October 10, 2016 Report Share Posted October 10, 2016 Not following at all. 15x4 ford 5 lugs 4-5 bolt patter ......what does this even mean???? Bolt pattern has nothing to do with brakes. Assuming you are putting a Ford hub??? on??? Well what's on these hubs now for brakes? Try a Ford forum and see what fits the hub you plan to use. Not going to find many Ford brake experts here... Quote Link to comment
flatcat19 Posted October 10, 2016 Report Share Posted October 10, 2016 If you're looking to upgrade, using a 4" wide wheel seems like 8 steps backwards. Just because you have a part in hand is not a good enough reason to use it. You can do better with less. Keep doing your homework. 1 Quote Link to comment
datzenmike Posted October 10, 2016 Report Share Posted October 10, 2016 Five seconds to type 1200 brake up grade into the search function gives... http://community.ratsun.net/topic/55675-2101200-brake-upgrade/ http://community.ratsun.net/topic/24226-1200-brake-upgrade-mklotz70/ http://community.ratsun.net/topic/29503-why-280zx-struts/page-2 14" and 15" zx factory mags and rims and 14" factory S110 and others will fit the stock 1200 hub and strut. You want brakes? look up swapping '79-'83 280zx or Maxima struts with big calipers and vented rotors on. Same bolt pattern. Ford??? Pfffffft. If these fit the Nissan spindle I think it would be common knowledge. Quote Link to comment
DogoX Posted October 11, 2016 Author Report Share Posted October 11, 2016 If you're looking to upgrade, using a 4" wide wheel seems like 8 steps backwards. Just because you have a part in hand is not a good enough reason to use it. You can do better with less. Keep doing your homework. Guess I'm not building as everybody else.., doing a drag race set up Quote Link to comment
flatcat19 Posted October 11, 2016 Report Share Posted October 11, 2016 Well, you can still achieve a result better than stock, with less effort. Follow posts Mile had posted to upgrade your brakes, then easily find pizza cutters that still fit stock Datsun hubs(4x114.3) Quote Link to comment
powerbench Posted October 11, 2016 Report Share Posted October 11, 2016 I'll ask a guy on facebook what he is using. He has low 8 second coupe with a rotary in it . I'm sure he doesn't run stock brakes Quote Link to comment
DogoX Posted October 11, 2016 Author Report Share Posted October 11, 2016 Thanks guys, I decide to buy the Aereopace brake set up specially made for the 1200 Quote Link to comment
datsunfreak Posted October 13, 2016 Report Share Posted October 13, 2016 First, I'll tell you how, then like everyone else, tell you why you shouldn't. :rofl: Hello guys, I'm doing and engine swap, and need some advice on front brakes.Not looking to use the 1200 hub at all, but keep the factory struts that will be convert to adjustable coilover with the T3 kitinstalling a 15x4 ford 5 lugs 4-5 bolt pattern front wheelI have read around but mostly swap are people wanting to keep the 13" wheels. what are my choices for bigger brakes using 5 lugsthanks in advance! 79-82 210 front suspension (LCA, TC rod, etc) 79-83 280ZX struts (with the coilover conversion you mention) 85-88 300ZX 5-lug hubs and 11" rotors Either adapters to run Wilwood Dynalite calipers (readily available), or custom adapters to use the 280ZX or 300ZX calipers This will net you monster brakes, using (mostly) stock parts that are relatively easy to find. Now, here's why you shouldn't. :rofl: Short primer on brake theory: Brakes don't stop a car. Tires do. If you have massive brakes and skinny tires it will still stop like shit. Monster brakes with skinny front runner tires will take longer to stop than stock brakes with 8" wide slicks. Simple physics. You run skinny tires and put on big brakes, you're just going to lock them up. Every single time. As a very talented race car engineer friend of mine is fond of saying, if you can lock the brakes, you don't have enough tire. B) 3 Quote Link to comment
