Angel_Legion Posted October 7, 2016 Report Share Posted October 7, 2016 Ok guys fixed my speedometer. Next I need to fix my temp gauge I don't think it's the gauge itself what sensor do I need? 1 Quote Link to comment
racerx Posted October 7, 2016 Report Share Posted October 7, 2016 mechanical or electrical? Auzone or Oreily don't sell those? 1 Quote Link to comment
datzenmike Posted October 7, 2016 Report Share Posted October 7, 2016 You don't throw parts at a Datsun, you find out what is wrong first and replace only what's needed. If gas and temp gauge are both acting up it's likely the voltage regulator that is common to both that is at fault. On a warmed up engine. Find the temp sender located on the front of the thermostat housing, it will have a Yellow/White strip wire on it. Make sure the connection is good and clean. If still not working hold the Yellow/White wire to ground on the housing case. With the key on, the gauge should read full HOT. No the gauge does not move... the problem isn't the sender but somewhere between the sender and the gauge. Could be the wire is broken or the gauge no good. Yes the gauge read HOT. The gauge obviously works. The sender is presumed to be at fault. 2 Quote Link to comment
Angel_Legion Posted October 7, 2016 Author Report Share Posted October 7, 2016 Gas gauge works it's just the temp gauge that doesn't 1 Quote Link to comment
datzenmike Posted October 8, 2016 Report Share Posted October 8, 2016 NEXT!!! You don't throw parts at a Datsun, you find out what is wrong first and replace only what's needed. If gas and temp gauge are both acting up it's likely the voltage regulator that is common to both that is at fault. On a warmed up engine. Find the temp sender located on the front of the thermostat housing, it will have a Yellow/White strip wire on it. Make sure the connection is good and clean. If still not working hold the Yellow/White wire to ground on the housing case. With the key on, the gauge should read full HOT. No the gauge does not move... the problem isn't the sender but somewhere between the sender and the gauge. Could be the wire is broken or the gauge no good. Yes the gauge read HOT. The gauge obviously works. The sender is presumed to be at fault. 3 Quote Link to comment
flatcat19 Posted October 8, 2016 Report Share Posted October 8, 2016 I had a faulty temp gauge but gas was normal. Everything else was fine. VR fixed my issue. 1 Quote Link to comment
Draker Posted October 8, 2016 Report Share Posted October 8, 2016 Mike spelled it out pretty good... just do what he said and it'll be fixed. 1 Quote Link to comment
Charlie69 Posted October 8, 2016 Report Share Posted October 8, 2016 You don't throw parts at a Datsun, you find out what is wrong first and replace only what's needed. If gas and temp gauge are both acting up it's likely the voltage regulator that is common to both that is at fault. On a warmed up engine. Find the temp sender located on the front of the thermostat housing, it will have a Yellow/White strip wire on it. Make sure the connection is good and clean. If still not working hold the Yellow/White wire to ground on the housing case. With the key on, the gauge should read full HOT. No the gauge does not move... the problem isn't the sender but somewhere between the sender and the gauge. Could be the wire is broken or the gauge no good. Yes the gauge read HOT. The gauge obviously works. The sender is presumed to be at fault. But my wallet is full of hundred dollar bills! LOL 1 Quote Link to comment
