itsallgood Posted October 2, 2016 Report Share Posted October 2, 2016 i have a 68" 520 just got the SR20DET mounted. i would like to keep the rear axle and change the gears. are there any other datsun that are interchangeable? what ratio would be good? any stores that still have stock or am i going to have to find them used? thanks. 2 Quote Link to comment
datzenmike Posted October 2, 2016 Report Share Posted October 2, 2016 All 521/620/720 2wd (some early 720 4x4) D-21 4 cylinders trucks and even Xterras used the H-190 differential. The 810 and Maxima wagons, '82-'83 S110 (200sx), '74 and up 610 wagons, the 510 wagon and the Roadster..... if you just want the crown and pinion gears. If you want to just swap the third member only trucks have the 29 spline gears that your axles fit into. You can swap your 29 spline side gears with a car's 23 spline side gears if careful. Gears? The 720 have the widest range depending on model and year, and they are relatively newer. 720s range from 3.364, 3.545, 3.70, 3.889, 4.11, 4.375, to 4.625 Less commonly found H-190 but you never know.... Roadster........................... 3.90 510 wagon........................ 3.90 521all................................ 4.375 610 wagon, '75 and on..... 3.70 810 wagon........................ 3.70 and 3.90 after '78 Maxima............................. 3.545 st. and 3.545 auto S110 (200sx).................... 3.545 st. and 3.70 auto S12................................... 3.70 st. and 3.889 auto early '84 only. D-21 Hardbody.................. 3.545, 3.90 and 3.889 Lots of options to choose from. Well the SR is only 2 liters and without boost will drive like a 2 liter at low speed. Still it sure doesn't need the J13's 4.875 ratio gears. Sort of like a race horse pulling a heavy wagon. The 520 is relatively heavy, certainly 300 pounds more than a 510. I think a 4.11 would be a good place to start if too low go 3.90, but if you are after mileage more than performance perhaps a 3.70? The 4.11 will rev quicker and get you boostin' sooner. 1 Quote Link to comment
wayno Posted October 2, 2016 Report Share Posted October 2, 2016 It really kinda depends on what you are trying to accomplish, to go really fast down the quarter mile, or lower your RPMs on the hiway. All rear gears are interchangeable from your Datsun 520 truck thru the 1986 2wd Nissan 720 truck, the 3.364 gears are very hard to find, so are the 3.545 gears and 4.625 gears, even harder to find are the LSD versions, they are very rare. 1 Quote Link to comment
datzenmike Posted October 3, 2016 Report Share Posted October 3, 2016 Forgot about LSD, wayno. Probably will need it with an SR. Yes the '88 through '93 D21 Hardbodys had LSD but hold on.... it was a rare option. Fastest way to find one is locate a 4 cylinder powered D21 of those years and look at the rear of the differential. There will be a stamp sized ORANGE sticker saying LSD or USE ONLY LSD OIL Take a rag. Expect to check hundreds to find one..... maybe. 1 Quote Link to comment
Stoffregen Motorsports Posted October 3, 2016 Report Share Posted October 3, 2016 Numerically lower gears will give you better manners when accelerating. With that kind of HP in a truck and a 4.375 ratio, you'd be shifting from first to second gear in about half a second and breaking the tires loose would be a constant problem. 1 Quote Link to comment
wayno Posted October 3, 2016 Report Share Posted October 3, 2016 I believe all the 520s had 488 gears, and so did the 521s with the J13 engine. 1 Quote Link to comment
datzenmike Posted October 3, 2016 Report Share Posted October 3, 2016 Yup, 520s were 4.875 One year only '69 L521s had J13 and 4.875. All PL521s had L16s and 4.375s 1 Quote Link to comment
G-Duax Posted October 3, 2016 Report Share Posted October 3, 2016 With that kind of HP in a truck and a 4.375 ratio, you'd be shifting from first to second gear in about half a second and breaking the tires loose would be a constant problem. Or use bigger/wider tires :-) 2 Quote Link to comment
itsallgood Posted October 3, 2016 Author Report Share Posted October 3, 2016 i found this list: Road Warrior Senior Member 19,058 posts Location:Maui, HI USA Cars:no cars Posted 13 July 2012 - 01:53 PM 81-83 200sx is NOT good for the B210. It's too wide, and it doesn't bolt in, it has 4-link connectors instead of leaf spring plates for the B210. The primary swap candidate is 320 pickup. The 200SX units work in the B310 (210).Here is a list of vehicles that used the H190:Datsun SPL311/SRL311 "Roadster/Sports" Datsun 410/411 Datsun 510 Wagon Datsun 320 Pickup Datsun 520 Pickup Datsun 620 Pickup Datsun 720 Pickup Datsun S110 "200SX" from 1982-1983 (disk brakes) Nissan S12 "200SX" 1984 (drum brakes) Datsun 810 wagon Datsun 910 wagon "810" Nissan D21/D21U pickup Nissan D22 pickup Like This and i was wondering if any of these would work? thanks for the help. http://www.ebay.com/itm/Datsun-Nissan-210-B210-200sx-axle-diff-differential-pumkin-3-70-/252541960813?hash=item3accac826d:g:b-UAAOSwTA9X22R9&vxp=mtr http://www.ebay.com/itm/1995-95-Nissan-D21-truck-rear-carrier-differential-drop-out-2wd-NL-3-54-OEM-used-/381791996921?hash=item58e4938bf9:g:HpAAAOSwARZXluk5&vxp=mtr 1 Quote Link to comment
datzenmike Posted October 3, 2016 Report Share Posted October 3, 2016 Post #3 has the ratios also. 1 Quote Link to comment
itsallgood Posted October 3, 2016 Author Report Share Posted October 3, 2016 will you check the ebay listings for me and see if i am looking at the right 3rd members. thanks agin. http://www.ebay.com/itm/Datsun-Nissan-210-B210-200sx-axle-diff-differential-pumkin-3-70-/252541960813?hash=item3accac826d:g:b-UAAOSwTA9X22R9&vxp=mtr http://www.ebay.com/itm/1995-95-Nissan-D21-truck-rear-carrier-differential-drop-out-2wd-NL-3-54-OEM-used-/381791996921?hash=item58e4938bf9:g:HpAAAOSwARZXluk5&vxp=mtr 1 Quote Link to comment
Lockleaf Posted October 3, 2016 Report Share Posted October 3, 2016 Top one, the gears will work, but it's from a car which means the axle spline count is different than the truck. You would need swap to that ring/pinion on to your carrier. Bottom, yeah that would be fine for you. Should bolt right in. 2 Quote Link to comment
flatcat19 Posted October 3, 2016 Report Share Posted October 3, 2016 That 3.54 seems super sluggish though. Do you have any salvage yards near you that might have a 720 in them. I'd put something close to a 4.1 or 3.9 in an SR powered something. Maybe 3.7 at the most. 1 Quote Link to comment
itsallgood Posted October 3, 2016 Author Report Share Posted October 3, 2016 That 3.54 seems super sluggish though. Do you have any salvage yards near you that might have a 720 in them. I'd put something close to a 4.1 or 3.9 in an SR powered something. Maybe 3.7 at the most. i found this list: http://forums.nicoclub.com/the-ultimate-final-drive-gear-ratio-thread-t228683.html S14 - SR20DET - MT - R200V - 3.692 dose this mean using the 3.7 ratio, would work well? 1 Quote Link to comment
flatcat19 Posted October 3, 2016 Report Share Posted October 3, 2016 There ya go. You found your baseline. I guess 3.54 isn't too far off the mark then. Given the weight difference, maybe 3.54 won't be too terrible. You won't be beating anybodt off the line with that though. 2 Quote Link to comment
datzenmike Posted October 3, 2016 Report Share Posted October 3, 2016 What does an S14 and a 520 weigh??? If similar, no problem. If you want more acceleration go 3.90 or 4.11 1 Quote Link to comment
itsallgood Posted October 3, 2016 Author Report Share Posted October 3, 2016 What does an S14 and a 520 weigh??? If similar, no problem. If you want more acceleration go 3.90 or 4.11 S13 = 2,700 lb 520 = 2,200 lb - 2,500 stock i am missing a lot of my truck, so may be a lill lighter. i would like to go with your recommendation of 3.90 i will keep looking, i just think it is going to be hard to find. 1 Quote Link to comment
itsallgood Posted October 3, 2016 Author Report Share Posted October 3, 2016 Top one, the gears will work, but it's from a car which means the axle spline count is different than the truck. You would need swap to that ring/pinion on to your carrier. Bottom, yeah that would be fine for you. Should bolt right in. so if i pull the ring and pinion off it, will fit in my 520. will the spline on the pinion fit my drive shaft mount? 1 Quote Link to comment
datzenmike Posted October 3, 2016 Report Share Posted October 3, 2016 Will the 520 flange mate to the new pinion spline? Good question. Most all H-190s I have seen were the same. I did get an early 4v4 diff from a 720 and no the spline was not the same as the earlier 2wd ones. I was pissed after all that work. 2 Quote Link to comment
Lockleaf Posted October 4, 2016 Report Share Posted October 4, 2016 If they differ in spline count, you might be able to redrill a new bolt pattern so it still fits your driveshaft fine. Or find a flange that would permit that. 1 Quote Link to comment
wayno Posted October 4, 2016 Report Share Posted October 4, 2016 Some of the later 4X4 720s had larger pinion flanges, I believe that is was because they had a C200 rearend, but that doesn't mean they didn't have them on H190s also. I have had no issues with any 2wd drivelines bolting onto the H190 pinion flange. I have a nice and tight 390 gearset, I also have a nice 370 gearset, PM me 2 Quote Link to comment
G-Duax Posted October 4, 2016 Report Share Posted October 4, 2016 The later H190 LSDs I get out of Japan all come with the large diameter pinion bearings, in an iron housing. But the spline on the pinions are the same, and my aluminum carrier 620 flange fit right on. Like everything Nissan makes, you can find all sorts of different versions. I think there are over 15 versions of R200 shafts. 28,29,30, and 31 spline, with 4 different flange bolt patterns, plus several different spline counts & bolt patterns for the viscous LSDs. 1 Quote Link to comment
datzenmike Posted October 4, 2016 Report Share Posted October 4, 2016 Some of the later 4X4 720s had larger pinion flanges, I believe that is was because they had a C200 rearend, but that doesn't mean they didn't have them on H190s also. I have had no issues with any 2wd drivelines bolting onto the H190 pinion flange. I have a nice and tight 390 gearset, I also have a nice 370 gearset, PM me This. 2wd seem all the same. I thought I would simply fit my 620 flange on but it was too small to fit the 4x4 pinion spline. I ended up machining the 620 flange off and welding it to the 4x4 one to get the bolt pattern 2 Quote Link to comment
Charlie69 Posted October 4, 2016 Report Share Posted October 4, 2016 My experience is the D21 354 pinion flange is larger diameter and larger bolt pattern. Quote Link to comment
