Moisabamf Posted October 22, 2008 Report Posted October 22, 2008 checked the cables under the dash and on the taillights themselves. but they just wont turn off. only if i umplug the switch that connects to the pedal itself help? this electrical shit is getting annoying:mad: Quote
dat620 Posted October 23, 2008 Report Posted October 23, 2008 are they the brake lights, or the tail lights, if the brake lights, then u have a bad brake light switch, mine went bad on my 620, and the wife noticed when she opened the garage door that the brake lights were on, it is the switch down by the pedal stem, up by where it bolts to bottom of dash area, they are pretty much universal in dattos, i got mine from pep boys, they had it in stock for like 8.00 bucks:) Quote
Eastcoast521 Posted October 23, 2008 Report Posted October 23, 2008 Assuming you are talking about brakes lights, check the pedal. The pedal has a hole in it where a rubber or plastic button goes that contacts the switch and if it is missing the pedal doesn't turn the switch off when your foot is off the pedal. Quote
Moisabamf Posted October 23, 2008 Author Report Posted October 23, 2008 im pretty sure its the switch Quote
zerow Posted October 23, 2008 Report Posted October 23, 2008 Standard Motor Products P/N: SLS-101 http://www.standardbrand.com/wmimages.asp?file=SLS101.jpg&partnum=SLS-101 Hope this helps. -0- Quote
