Noflers Posted September 8, 2016 Report Share Posted September 8, 2016 Problem is, wiper motor didn't come with linkage arm. What's stopping me from drilling out the hole in the Datsun arm so that it fits over the Mazda shaft?The Mazda shaft is tapered slightly so it wouldn't be hard to press it on thereWill that work? Quote Link to comment
cl72wagon Posted September 8, 2016 Report Share Posted September 8, 2016 Problem is, wiper motor didn't come with linkage arm. What's stopping me from drilling out the hole in the Datsun arm so that it fits over the Mazda shaft? The Mazda shaft is tapered slightly so it wouldn't be hard to press it on there Will that work? Here is what I did.... http://community.ratsun.net/topic/68033-finally-found-a-510-2-door-1972/page-2 Quote Link to comment
Noflers Posted September 8, 2016 Author Report Share Posted September 8, 2016 Perfect, I'll get back on it tomorrow. Did you plug the motor in to the car before you cut the shaft, or is the motor already at it's home position before plugging it in? Quote Link to comment
cl72wagon Posted September 8, 2016 Report Share Posted September 8, 2016 Perfect, I'll get back on it tomorrow. Did you plug the motor in to the car before you cut the shaft, or is the motor already at it's home position before plugging it in? I plugged it in to make sure it was at its home position Quote Link to comment
Noflers Posted September 8, 2016 Author Report Share Posted September 8, 2016 I've got the arm mounted to the stud now. I just need a nut that fits the Mazda shaft. Quote Link to comment
Noflers Posted September 9, 2016 Author Report Share Posted September 9, 2016 Random matching nut to the rescue! Now I just need the piece that links the squeegee to the arm pivot. Quote Link to comment
