MaxChlan
Max's 1986 Nissan 720 King Cab 4x4
UPDATE: The 15" Xterra rims did not fit on the vehicle (just a hair too wide, and let this serve as a warning, unless you get the 16" rims), so I picked up some FREE rims off of a '96 Pathfinder. Got them mounted, and now we're sittin' pretty. I love the look of the smaller rims and tires (General Altimax Arctic 205 70r15) as opposed to the bigger ones, plus the truck accelerates and turns better without all that rubber. Here is a silly dark picture (My house matches my truck, hahaha)
Share this post
Link to post
As it's getting colder out, I've realized that my truck has difficulty idling when cold. This morning I checked the choke plate, and it was completely closed. Firing the engine up (one or two pumps, holding it halfway and turn it over, per the Owner's Manual), it'll chill at 1000 RPMs for one or two seconds before going down to 500 or even 400. From what I'm gathering, my choke seems to be working okay, but my fast idle cam isn't engaging.  I checked hoses, and everything is tight with no leaks. Once the vehicle is warm, it runs absolutely fine, idling at around 800 where it should. Does anyone have any other ideas? Could someone show me how to adjust the fast idle?
Share this post
Link to post
Got a nice dusting of about five or six inches of snow this weekend here in the cities. Didn't even have to shift into 4WD with these snow tires on. Here are some pictures I took after doing a few skids around the parking lot:
I am going to make a habit out of taking a rag and cleaning the underside and in the wheel wells after I drive. Weekly washes will help too hopefully.A few questions about the 4WD system:
When I engage 4H, roll about 3 meters and lock the hubs, and then put it back into 2H, can I switch into 4WD while moving and likewise as needed? I did not try it, but I do not want to be rolling around in 4H much unless I absolutely need to, but it's nice to be able to use it to pull out from a stop.
Share this post
Link to post
Auto hubs should remained locked after initial engagement. So you pull it into 4, pull forward till they lock, then shift out of 4 and you should have shift on the fly. You have to back up like 10 feet or something to unlock, then you'll have to stop to engage 4
Share this post
Link to post
Well, I went to adjust the fast idle screw because it was not engaging, only to realize that it wasn't there. Does anyone know what size of screw it is? Or, would anyone be willing to mail me a "letter" with the screw off of their old stock carb?
Share this post
Link to post
you might put up a part number on a diagram like I've been doing. I think the website is nissan parts deal
Share this post
Link to post
I've looked, and the part is discontinued.  :blush:
Share this post
Link to post
We have a fastenall here in town. They make every single bolt/screw that you can imagine. Check any specialty fastener store.
Share this post
Link to post
Yeah, if I had the size of the screw, I would hit up a local hardware store and grab one (I'm sure it's metric), but I don't have a clue as to what it is or what it looks like, and NissanPartsDeal only says part numbers and not sizes of screws and things like that.
Share this post
Link to post
Prob an M8 or M6. If I have time I'll pull mine out and take a pic for ya.
Share this post
Link to post
I would really appreciate that.
Share this post
Link to post
I personally would not buy that wheel, if you look close at the hub there are 3 out of five veiwable screws are broken off in the hub.  This is a common acurance when trying to seperate the hub from the wheel.
http://www.ebay.com/itm/Nissan-720-1980-86-Steering-wheel-OEM-/152337066684?hash=item2377ff2abc:g:UugAAOSw-CpX~uIl&vxp=mtr
Share this post
Link to post
Good catch Charlie. I wasn't going to buy it anyway; waaay to expensive. I'd rather get something from Grant, NRG, or Royal
Share this post
Link to post
Still no word on what the measurements are on the fast idle screw. An extensive search has lead me to no results... Anyone got an extra?  :confused:
Share this post
Link to post
No luck on that hitachi site? Were you able to pull of the numbers on your carb?
Share this post
Link to post
No luck. I emailed the website asking for some help, and they simply said no.
Share this post
Link to post
This is the fast idle cam (light colored plastic thing)
The fast idle adjustment screw is shown with it's locking nut. When started cold with the choke on the fast idle sits on the highest step on the cam. as the choke warms the cam rotates and the fast idle drops progressively to lower and lower steps until it drops odd completely and the idle speed screw on the throttle takes over.
This screw is practically impossible to get at with the can on the vehicle.
16065-W8800 looks like it is used all Z 20/22/24 carburetors.
Share this post
Link to post
After purchasing this to replace the Power steering idler pulley, I discovered that it was too big for the application. The original has a 17mm (11/16th inch) bore for the bearing, and about a 76 mm diameter, and this one is... too large. I can not find the original Nissan part number after looking at NissanPartsDeal, and I can not find a similar pulley with the correct dimensions. Does anyone have any ideas?
Here is a picture of what I am talking about (this is a diagram for a hardbody)
and here is a picture of it in the engine bay (from Lockleaf's 720 thread)
Share this post
Link to post
I will bring a spare pulley in to work tomorrow (oreilly auto) and do some searching for you.
Share this post
Link to post
That would be excellent. I think I found what I'm looking for, so maybe confirm it for me. This is the part I think it is, and it's dimensions are as follows off of Gates' website:
Width: 18mm
Bearing Bore inside Diameter: 17mm
Outside Diameter: 81mm
Share this post
Link to post
I have that part number on hand, so I will compare tomorrow.
Share this post
Link to post
I forgot. I will try Monday.
Share this post
Link to post
So, when I was pulling in tonight, I think my idle tensioner pulley finally took a crap. I got a low idle and a pretty strong rubber burning smell, which to me seems like the idle tensioner pulley seized up. However, it still turns when in the garage, but that was according to my girlfriend and not my own eyes. I'll take a look at it tomorrow because it's too late, but I just wanted to post it. Maybe I tightened the belt tensioner too tight as well, I'm not sure. Just wanted to throw that out there for some confirmation, and see if that's happened to anyone. I went ahead and ordered that Gates pulley; and it should be here Tuesday. Free Amazon returns are super convenient.
Share this post
Link to post
Update on the belt issue: My Power Steering Idle Pulley bearing seized up, and it was kind of a pain to find a new one. I ended up purchasing a new one (the correct one on Amazon is here). There is some sort of spacer in the factory pulley that needs to be pressed out and pressed into the new one to get it to fit on the bolt properly. I put the convex blue dust jacket from the back side of the old one on the the back side of the new one, and there you go! Nice new tensioner. What you could also do is replace the bearing on the old pulley. The bearing is a 6203z, which are pretty inexpensive and easy to find. Kind of makes me want to replace all of the bearings, because it runs much quieter now! Anyway, hopefully someone finds this useful because it was a lot of messing around to get the correct pulley.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
