  • Replies 292
I don't use spoons,
But on a side note, have had a few members in the last couple of months confide to me some shady deallings with AL they've been through. But are too scared to say anything thinking they might not ever get thier money or vehicles back by making him mad. How shitty is that.
Hearsay bs slander.
When these individuals choose to speak up they can.
And you've made it very clear in your wording who your talking about so good job outing him.
If the Eagle thread got locked and member banned...Sounds like the same damned thing is happening here.
What's good for one should be good for all.
There are several threads on Ratsun that need to be locked. Your opinion is not important to anyone but you  :thumbup:
Just my opinion
Hearsay bs slander.
Whoa there F. lee Bailey ,,,,,,,, I think you are using big people words you have no idea what the meaning of is.
And wouldn't for it  have to be completely uncorroborated in any way for that word ( if it was correct word )  to be applicable??
What about this ??
Well a long over due update.....this will be for sale in the next couple days. Long story short i got fucked over for being a nice guy to Albert Rasmussen. The truck looks the same but basically a rolling shell. It comes with a KA motor and trans, a painted red frame, and coilovers up front. It has no wiring, no ecu, no driveshaft, no brakes.
If you would like to know the full story my cell number is 2062296534, I will also suggest anyone doing business with him to be cautious of your actions.
http://community.ratsun.net/topic/64980-the-soaring-521/page-7
Me and Scalpum talked to this kid in person and on top of taking his running driving truck and making it completely un-usable ( and un-sell-able because Albert also switched OG frame with a 620 frame)  the kid gave Albert $2500.  ...
And don't take my word for it,,,,,,,,,,,,,,,,, he put his number up so if you wanna give him a ring and ask him personally ,,,,,,,,, be my fuckin guest
Here's my story.   Be sure to read at the very bottom too....     Take it for what it's worth.  I am not going to go back and forth and argue about this.  People can make their own judgement on whether or not to deal with Albert.
I had a 521.  I got it from Brian Hatfield.  Spent the last 6 months working on it here and there. New clutch, cleaned the fuse box... Got electrics to work.  It did run, just not very well (distributor)  Got to the home stretch and found out the timing chain guides were dead and needed replaced. Which means the motor needed to come back out.  I didn't wanna pull a motor and do all that shit, as i already had it out once.  Have had some health issues lately (nothing to serious, just pinched nerves in the spine and sciatic... Some autoimmune disease shit...  Seeing a specialist and should be good to go sometime this year), and just wasn't up for it.  I have a 720 that needed some light work, carb, tie rods.. simple easy stuff.  I already had a carb for it, and adapter.  Just no funds for the steering parts that need replaced. So I wanted to take time with the 720, get parts when I could. In the mean time, drive around in a datsun.  Needed my own vehicle
Anyways.  I posted the 521 up for sale/trade. I wanted something that runs and drives.  He offered me up a 79 king cab. (he actually offered me a selection of 620s, none had a motor.  But he had an L16 that runs great he could put in any of them)  Said it had no motor, but he would put in a running L16.   So over the course of a week, he got the motor in it.  Told me it runs and drives.  I asked if the tires had tread, he said yeah some. So it gets here.  And he says, the alternator is dead it needs a new one, and gave me a replacement. Then he says, the radiator gets damp. so he gave me another one of those too.  Then I found out the windshield is busted, when he got here... But he gave me one of those, also.  Was looking around the truck, and the tires are shot.  Completely.  Only good for rollers in the garage.  One is a racing slick now, the rest are past the wear bars.
I swapped the alternator out, the replacement was dead.  Installed a 720 alternator, good to go...   I filled the original radiator up, and it literally pours out the bottom.  Now he told me the day prior he ran it for a few hours and it was great.  He also said the radiator just gets "A little damp". That's why I filled the original radiator up.  I just wanted to fire it up and check it out, then noticed the massive leak in the radiator.  There is no way it ran for a few hours with a dead alternator, a radiator that leaks as much as fast as this one does...  So continued on.  Pulled the radiator out,  set the new one in. It's the wrong one.  That sucked :|   But, Albert DID buy me another radiator off another member.  Oil leaks at a pretty good rate from the timing cover and front main seal.  This engine needs to come out, get torn down and new gaskets.  But is it even worth it?  He said it doesn't smoke. But it smokes... And IDK if it's even worth the time/effort/money pulling it and re-gasketing it....   It was backfiring out the carb. So I checked the timing.  It was at 15 degrees.  I backed it off to 12 & 10. But it has absolutely NO power there, none.... Could be the points in the dizzy are shit?  L16 still has the points dizzy on it. I have a matchbox to install.   The dash lights come on/off randomly when the headlights are on.  And when the lights in the gauges go out the turn signal indicators light up solid.
The point is.  He told me it was a running driving truck. And it's not.  It's a project.  It needs more work than the 521.  I didn't want to let go of the 521... The only reason I did was to get a running/driving datsun to use while I work on my 720... And when I was done with that, throw the 620 in the garage and start working on it.   Now I have a 79 620 project sitting in front of my house I can't really do anything with.  I don't have the funds to dump into the thing right now. And really, i'd rather have the 521 back and work on it vs this thing.
He lied to me about it running and driving.  If you count that it starts and backfires out the carb, has no power and will move very little on its own as running and driving, then I guess it is.  It barely makes it up the hill from my garage to the street.  I just pushed it outside after seeing all that and swapped the carb on my 720 and will drive it and fix it.
Pictures of conversation. Multiple times I asked/said need running driving, and assured me it was.
First one.  Says they run and drive
Screenshot_20170312-204954_zpsz1ze1wqb.p
Him telling me what he has, and me telling him I need something that runs and drives.
Screenshot_20170312-205024_zpsfmnu3h7v.p
I listed everything wrong with the 521, that I knew about. So he would know what he was getting into.
Screenshot_20170312-205034_zpsk9bcg31t.p
Here's him saying it runs great
bdf252c3-28c3-4537-9614-081e0eb9a896_zps
Here's him saying he trusts the motor
Screenshot_20170312-205212_zpsshuhq2c4.p
Screenshot_20170312-205228_zpsgbbbtz2a.p
A picture of the motor.  Me saying again, just needs to run and drive.  I also asked about the tires...  He said the tires have OK tread
Screenshot_20170312-205241_zpswnho0x8h.p
(said tires that are OK)
The other 3 look like this, down past the wear bars :(
Him saying he will run/drive it and make sure it's all good
Screenshot_20170312-205258_zpslsmhwvzp.p
Him saying he would be a fe wdays later, which was OK
This was the day before he brought it out.  Wednesday.
Screenshot_20170312-205436_zps9doyawob.p
Here it is!  Where he says he ran it for a FEW HOURS.  With a dead alternator not charging, and a busted radiator?
Screenshot_20170312-205444_zpstznqsp0i.p
I didn't know about the windshield, radiator, and alternator until it got here.
Natural weight reduction.
Now, I could have turned down the trade.  But I was told I was getting a running and driving truck, and I trusted him. Not knowing all the other shit that's happened.  He had drove like 4 or 5 hours, and I wasn't ready when he got here. So i had to throw my 720 together, get his wheels on the 521 and get them loaded up.  I should of taken more time to look it over.  but again, i just trusted his word.  We were in a hurry.  I was excited to have a running/driving datsun truck again.  Some of that blame is on me.  This is for others to see, and make their own call on dealing with him or not.  It wouldn't be exactly easy either, to tell him nevermind after he drove all that way to drop it off.
The 521 is worth more than this thing.  Cost/value aside.  I wanted that 521, so bad... Just couldn't be pulling motors and stuff right now.  And now I have to.  I'd rather just have my 521 back and do the work to it VS the 620.
He did buy the radiator replacement.  Said he would try and help make it right. But IDK what to do to make it right.  A good known running motor that doesn't leak or need a bunch of shit, and a set of tires that were actually good would be nice.   But don't expect it.  I'd be ok with the trade if that stuff came through.   He messaged me earlier but I haven't responded to him yet.
Oh and here's the kicker.  Wasn't even Alberts truck.  It was Hoagies!  Hoagie,  I do not put any of this on you man.
The specifics your talking about would not be classified as hearsay. The individual who had the direct experience is making the comment. Ted's post is exactly the definition of hearsay because it is an uncorroborated rumor.
Just because your the big shot in your click doesn't mean that I do to have a vocabulary to dip shit
Well since hearsay wasn't the word you used incorrectly and the last part of the highlighted sentence  pretty much proves which one of us is the dipshit ,,,,
thanks for trying your hardest though.
You can thank iphone smart text for you making your point. Isn't being a Datsun enthusiast fun on Ratsun? We should hug it out bro.
I don't use spoons,
Can corborate this and the owner of the asm zero truck is 100 percent accurate ........ he was lucky to recoup some of his losses ......unfortunately he absolutely shouldn't be working on people's cars..... my inbox is full of people who haven't had fair deals ......
Percent
I have a part in the deal that Izzo was talking about. It was my kc shell that had a motor dropped in and traded for his 521. I am communicating with him to see what can be salvaged from this.
At the end of my earlier post, I had mentioned that this isn't on Hogie.  I want that to be super clear here.  Hogie didn't have anything to do with the trade. Shit I didn't even know it was his until Al was leaving my pace
Teds not a big shot ....... we are all eqUally mediocre but even at that we have more integrity for the community then he has shown ........ period your bro is a hack and that's disrespectful to halfassers everywhere ....
That's nice of u to attempt to mitigate his wrong doings...... maybe al should be responsible for al's shit shows
Argh matey where's my yee old vodka .......
Just saying drunk, I can still build road worthy shit while al just endangers people and selfish takes from the community ........wanna come rebuild the ca 18 that took 17 months to get after paying for as a running driving motor ....... woot woot ..... oh I got What I paid for ......17 months later ....but after the truck it was delivered with I'm surprised Sasquatch didn't jump out the oil pan and rape my jack Russell ......... even my jack is more competent ......
Small Claims Court
Each district court in the State of Washington contains a “Small Claims” division for the settlement of civil disputes in which damages claimed total less than $5,000.
https://www.courts.wa.gov/newsinfo/resources/?altMenu=smal&fa=newsinfo_jury.Scc
Or...I don't know...maybe man the fuck up and ACTUALLY DO SOMETHING ABOUT IT.
But that's just my opinion.
