Rick-rat Posted August 8, 2016 Report Share Posted August 8, 2016 I have a 79 620 KC, l 20 and 4 speed. When I started my truck today it was making a noise that sounded like a like a loose rocker. When I pushed in the clutch the noise went away. Let the clutch out and ticking started again. Could it be the bearing on the input shaft starting to go out? Any advice or suggestions appreciated Quote Link to comment
datzenmike Posted August 8, 2016 Report Share Posted August 8, 2016 Well it's definitely something behind the clutch. With the clutch out everything spins in neutral but the mainshaft, everything, even if not under load. Quote Link to comment
Rick-rat Posted August 8, 2016 Author Report Share Posted August 8, 2016 Ok, thanks. I will get another transmission and replace the one I have Quote Link to comment
DanielC Posted August 8, 2016 Report Share Posted August 8, 2016 Rick, See this thread; http://community.ratsun.net/topic/70116-5-speed-rebuild-kits/ Quote Link to comment
Rick-rat Posted August 8, 2016 Author Report Share Posted August 8, 2016 Thank you Quote Link to comment
datzenmike Posted August 8, 2016 Report Share Posted August 8, 2016 Ok, thanks. I will get another transmission and replace the one I have Whoa.... could be anything. and it could run forever like that. Try driving it in 1st and idle along... Quote Link to comment
q-tip Posted August 8, 2016 Report Share Posted August 8, 2016 Just don't pull a ted and drive it around dry and you should be ok.... 1 Quote Link to comment
