skyblue Posted August 2, 2016 Author Report Share Posted August 2, 2016 I hope there is at least one stick she can drive. If you know what I mean. Hahaha. Oh tanker. That escalated quickly. You got a short term/long term list of things to do? Short term list is just getting it to stop good. Doing the gas tank filler hose mod. And slapping a weber downdraft. Quote Link to comment
racerx Posted August 2, 2016 Report Share Posted August 2, 2016 Good your performing maintenance, also do a compression check. Quote Link to comment
skyblue Posted August 2, 2016 Author Report Share Posted August 2, 2016 Good your performing maintenance, also do a compression check. PO told me he did a compression test and it has good number. But I'll probly do one myself as well. Quote Link to comment
racerx Posted August 2, 2016 Report Share Posted August 2, 2016 Wise to double check. Make sure ur datsun is operating temp., open throttle wide open, use screw in type compression tester not plug in type, more accurate. Having a good compression engine is a good starting point before buying parts. Quote Link to comment
banzai510(hainz) Posted August 2, 2016 Report Share Posted August 2, 2016 get a elelctronic ignition of some sort. Most proplems with a Datsun is ignition related and points is the Killer besides overheating(warping a head) Oh no oil pressure(most girls/women always ask what does the oil light mean while still driving? 3 Quote Link to comment
skyblue Posted August 4, 2016 Author Report Share Posted August 4, 2016 yep. i'll either go pertronix or matchbox. whichever crosses my path first i guess. Quote Link to comment
skyblue Posted August 7, 2016 Author Report Share Posted August 7, 2016 Fixed the brakes. Took a ride around the the block and got the dat some sun. Also, what do people do for a replacement AT shifter? Cause this one has seen better days. 3 Quote Link to comment
Icehouse Posted August 7, 2016 Report Share Posted August 7, 2016 So glad it went to a good home! 1 Quote Link to comment
skyblue Posted August 7, 2016 Author Report Share Posted August 7, 2016 So glad it went to a good home! yea thanks! so the battery died yesterday. Which is fine cause it was only really to get the car here from WA. so we got a brand new one. now the car fires up no problem. Also, the brakes still need some attention. the master is doing this weird thing where the front brakes reservoir gets lower and the rear brakes reservoir overflows. it will be fine to drive it to the dmv to get plates, but i think I'll just replace the master once we're all plated up. 2 Quote Link to comment
banzai510(hainz) Posted August 8, 2016 Report Share Posted August 8, 2016 dont buy the rebuilt Masters with no tubes. They always seem to leak. Put a meter on the battery to make sure its chargin correctly with a load. I would get a solid state Volt reg as a spare. 1 Quote Link to comment
skyblue Posted August 8, 2016 Author Report Share Posted August 8, 2016 dont buy the rebuilt Masters with no tubes. They always seem to leak. Put a meter on the battery to make sure its chargin correctly with a load. I would get a solid state Volt reg as a spare. yes i know. I have a spare Voltage reg. already. Quote Link to comment
4perrev Posted August 24, 2016 Report Share Posted August 24, 2016 Blue, I may have a shifter that is better. Just have to check the stock outside. I'll hit you back when I get out to the car tomorrow. Quote Link to comment
4perrev Posted August 24, 2016 Report Share Posted August 24, 2016 So, I just looked in the car and mine is in the same shape, sorry. A guy could rewrap that in leather or vinyl to be good. Quote Link to comment
edekalil Posted August 24, 2016 Report Share Posted August 24, 2016 I should have a shifter handle from one of two auto's that had been swamped out. I will look when I get back this Sunday. The biggest issue is locating it, shouldn't be too hard to locate. I'll let you know. Quote Link to comment
skyblue Posted August 25, 2016 Author Report Share Posted August 25, 2016 Guys you rock! Thanks for checking! Quote Link to comment
skyblue Posted August 25, 2016 Author Report Share Posted August 25, 2016 Gave it it's first car wash. Air dry. Not too bad. Also got a repop gas filler hose to get rid of the gas smell. 1 Quote Link to comment
edekalil Posted August 25, 2016 Report Share Posted August 25, 2016 Gave it it's first car wash. Air dry. Not too bad. Also got a repop gas filler hose to get rid of the gas smell. I have to get a few of those too, having that issue as well. Cars looking good. 1 Quote Link to comment
skyblue Posted August 26, 2016 Author Report Share Posted August 26, 2016 yea its the worst Datsun quirk. been too busy to put it in. thnks Quote Link to comment
edekalil Posted August 28, 2016 Report Share Posted August 28, 2016 yea its the worst Datsun quirk. been too busy to put it in. thnks I know that. Quote Link to comment
edekalil Posted August 28, 2016 Report Share Posted August 28, 2016 Thought I was hot on the trail for a moment but the trail when cold. Gonna keep looking though. Quote Link to comment
edekalil Posted August 28, 2016 Report Share Posted August 28, 2016 Found this one less the rest so far. I think this came off the blue car. Not in the best shape itself. Let me know if you want it, I'll send it to you. Quote Link to comment
skyblue Posted September 3, 2016 Author Report Share Posted September 3, 2016 Found this one less the rest so far. I think this came off the blue car. Not in the best shape itself. Let me know if you want it, I'll send it to you. Thanks man. I'm gonna hold off for now. Also, I installed the aftermarket gas filer hose. Voila! No more gas smell. Time will tell how durable these are. It went on fairly straight forward. The only negative is the hole dimples don't match up to the retaining plate so u have to make new holes. 2 Quote Link to comment
skyblue Posted September 11, 2016 Author Report Share Posted September 11, 2016 Swapped the carb for a brand new weber 32/36 today. Car runs like new! And then I noticed a small leak from the top of the radiator. I attempted to solder it but it didn't stick too well. Hopefully it will hold till we get a new radiator. Car is ready for the road! It still needs work in other areas, but that's the datsun life we live. Lol. 6 Quote Link to comment
Draker Posted September 11, 2016 Report Share Posted September 11, 2016 looking good! Quote Link to comment
skyblue Posted September 11, 2016 Author Report Share Posted September 11, 2016 looking good!Thx! Updated fix list Things I've fixed so far: - brake lights - turn signals - matching wheels and tires (stock steelies with my old hubcaps) - fuel gauge - battery hold down - rear and side view mirrors - added a spare - new exhaust - replaced gas filler hose - new weber carb - new fuel filter - new radiator cap 1 Quote Link to comment
