wayno Posted October 17, 2016 Report Share Posted October 17, 2016 Did you get the parts from that 4wd 720 in the Vancouver Yard? Did you grab the rear leafs? 1 Quote Link to comment
dat nasty Posted October 17, 2016 Author Report Share Posted October 17, 2016 That's the one and the springs were there when I left. No needs bags will be here Tuesday :D 1 Quote Link to comment
wayno Posted October 17, 2016 Report Share Posted October 17, 2016 So your saying that the power steering gear from the 1986 Nissan 720 4X4 bolted into your D21 frame? 1 Quote Link to comment
flatcat19 Posted October 17, 2016 Report Share Posted October 17, 2016 I'd be willing to buy a set of 720 4x4 leaves. 1 Quote Link to comment
Stoffregen Motorsports Posted October 17, 2016 Report Share Posted October 17, 2016 Did you test fit the column with the plastic shroud and gauge cluster in place? There is a potential interference issue there. 1 Quote Link to comment
wayno Posted October 17, 2016 Report Share Posted October 17, 2016 I think he is all right, that steering wheel and the dash cover make it look a lot closer to the dash than it really is, plus it is tilted up in that photo, my 720 tilt column cover touches the plastic shroud when in the full up position, and there is about a three quarter inch gap in the all the way down position, by the way there is a notch in the column cover that matches the dash shroud perfect. Also to let everyone know if the 720 non-tilt column is used, the stock 521 steering column mount hardware is used, there are no modifications needed, as the 520/521/720 non-tilt column tubes are the same size, but all the 720 mount hardware on the tube has to be cut off. I found after taking them 4 bolts out that hold the lower tube to the 720 mount hardware, it was a bitch to get them back in/aligned. 1 Quote Link to comment
dat nasty Posted October 18, 2016 Author Report Share Posted October 18, 2016 1 Quote Link to comment
dat nasty Posted October 18, 2016 Author Report Share Posted October 18, 2016 I left the mounting bracket alone on the column at the top and put in a flat bracket in under the dash to bolt it to. I cut out the firewall part of the column and made it work. It was loose and I could slide it around where I needed it. I will post a couple pics of that very shortly. It went in way easier than I thought. If the cluster is in the way I can put a couple washers in to clearance. I'm going to find out tonight I did not even think about it. I've been trying to leave room here and there on everything I do. I can't believe how easy that one was. I thought I was going to have to modify the shaft length and change out Rag joints 1 Quote Link to comment
wayno Posted October 18, 2016 Report Share Posted October 18, 2016 You don't have to worry about anything but placing the steering wheel were you want it to be depth wise, as the collapsible part between the rag joint and the steering gear is adjustable. There is one thing that might be an issue though, normally the rag joint is up at the firewall, and the knuckle is down at the steering gear on power steering 2wd applications on the 720, as the rag joint will not clear the upper control arm where it mounts, but your using a D21 frame, so that might be different, let us know if anything rubs, I believe I ground off the corner of the control arm to make it clear until I bought a proper steering column. 1 Quote Link to comment
dat nasty Posted October 18, 2016 Author Report Share Posted October 18, 2016 Pic from bottom of dash, At firewall from inside 1 Quote Link to comment
dat nasty Posted October 18, 2016 Author Report Share Posted October 18, 2016 You can see I tried making the original holes bigger to give more shaft angle but ended up just turning the shaft and going straight from the bottom. just need a longer bolt for the second one. Cluster plastic cleared w plenty to spare, I'm going to drill the slots more to let it up higher, comes all the way down to my legs almost the seat. Totally worth it 1 Quote Link to comment
dat nasty Posted October 18, 2016 Author Report Share Posted October 18, 2016 Rag and U-joint are the same set up on the Hardbody as the one I just got. Hardbody setup was way too long even collapsed Rag joint is about a half an inch from my air conditioning lines which I might just be pulling out anyways I find a more compact solution. A little more than half an inch from u joint to egr tube. 1 Quote Link to comment
wayno Posted October 18, 2016 Report Share Posted October 18, 2016 This is how I did mine, I used the stock mount holes, it was a pain. This is what I did for the column. And here is my power brake setup. Clutch master is mounted on part of the brake master pedestal. 1 Quote Link to comment
Stoffregen Motorsports Posted October 19, 2016 Report Share Posted October 19, 2016 It looks like neither of you guys (Wayno and Dat Nasty) have the column supported at the firewall.I would weld the flange on there and bolt it to the firewall, otherwise the lower half of the column is going to flop and clunk around. Quote Link to comment
dat nasty Posted October 19, 2016 Author Report Share Posted October 19, 2016 I just haven't drilled and bolted it yet. I have more patching to do on the firewall and tunnel so I'm waiting to bolt it in 1 Quote Link to comment
dat nasty Posted October 19, 2016 Author Report Share Posted October 19, 2016 As if we weren't already ballin out of control... 30" triangulated 4 link from nfamus and Firestone 2600s I have not bought front bags yet because I wanted to see how big these were or if I need to get 2500s 1 Quote Link to comment
wayno Posted October 19, 2016 Report Share Posted October 19, 2016 It looks like neither of you guys (Wayno and Dat Nasty) have the column supported at the firewall.I would weld the flange on there and bolt it to the firewall, otherwise the lower half of the column is going to flop and clunk around. Mine don't move around much, that is 1/4 inch thick rubber I used at the firewall, and is is surrounded by that metal piece on all sides except the top. I could make a metal piece for the top also, but it doesn't move now, so I don't see the point, it has been that way for years and I have power steering, so it isn't hard to turn either. 1 Quote Link to comment
dat nasty Posted December 5, 2016 Author Report Share Posted December 5, 2016 Engine bay is pretty much wired/plumbed except lights, everything fit except the battery, relocating it to the back. Wiring harness is laid out in the cab, ready to start wiring the dash next. Everything is going pretty easy, most accessories even look to have the same color wiring. 2 Quote Link to comment
Stoffregen Motorsports Posted December 5, 2016 Report Share Posted December 5, 2016 I'm diggin' that air cleaner. The motor looks high in the engine bay. Are you going to try to use a stock mechanical fan? If so, will it clear the upper radiator hose? 1 Quote Link to comment
wayno Posted December 5, 2016 Report Share Posted December 5, 2016 Remember that square headlights are not wired the same as round headlights, you cannot just plug them onto the lights and expect them to work properly. I made pigtails from other headlight plugs from different wiring harnesses, plugged it into the headlights and then plugged the wires in the proper places and mine work just like they were stock. I also figured out how to use the stock 521 wiper motor with a modern 720 wiring harness, I smoked a couple 720 intermittent wiper electrical units figuring it out, but I did figure it out, I have off/intermittent/slow/fast just like a stock 720 does in my 521. 1 Quote Link to comment
dat nasty Posted December 5, 2016 Author Report Share Posted December 5, 2016 The KA radiator was too tall, 521 radiator is to deep to use the fan/clutch. Going electric. Not sure what I'm going to do for intake/hood yet. It sticks out pretty good. The perimeter of my hood is pretty much shot but it has a good middle, I'm looking for a hood with a good outside edge all the way around so I can cut my center out and use it make a cool stockish looking scoop 1 Quote Link to comment
dat nasty Posted December 5, 2016 Author Report Share Posted December 5, 2016 All the light wiring in front of the firewall came up short so it needs cut/lengthened and converted to the old clips. Lots of Slack in the cab, stuffing it wherever I can inside the dash 1 Quote Link to comment
dat nasty Posted December 5, 2016 Author Report Share Posted December 5, 2016 1 Quote Link to comment
dat nasty Posted January 28, 2017 Author Report Share Posted January 28, 2017 Sorry been snowed in, well out of my "shop" getting back at it this weekend. Hoping to start/drive it to where im doing the 4 link so i can move on to the bed Tired of pushing it 2 Quote Link to comment
