S@nt0s Posted October 20, 2008 Report Share Posted October 20, 2008 did a lil work today and here is the outcome... Quote Link to comment
slodat Posted October 20, 2008 Report Share Posted October 20, 2008 Details on the brakes? They look like a front setup for drag racing.. Quote Link to comment
S@nt0s Posted October 20, 2008 Author Report Share Posted October 20, 2008 yes they are for a drag car but can be used on the street. rotors are Steel CNC'd 6061 T6 Aluminum CNC'd Billet Aluminun Dual Piston Calipers 2 lbs. total weight Special Billet Aluminum Mounting Brackets Grade 8 Hardware Special Billet Aluminum Hubs w/screw on dust caps Bearings & Seals for your model car Pads - 3.25" 1/2" Studs 260mm (10 1/4'') Diameter Drilled Rotors 10mm thick (will clear 14" wheels) bigger brakes with weight savings are always a + 4 piston and spindle mount avail as well... Quote Link to comment
