720 Crewcab - 4 doors, 4x4, and a huge freaking headache
Today's Episode - "Pounding out panels"
Ok, so its not plural.  Its just one panel.  But its basically done.  I welded up all the seams.  the outer corner in particular came out really nice.  I was able to remove basically all evidence of the welds without grinding through.
large.20210312_203225.jpg.23231cc69b4d08
large.20210312_203249.jpg.60bd655f5cea62
Then worked on grinding back the rest of the seams
large.20210315_001255.jpg.abcd0e16a266cf
They didn't come out as nice as the outer corner, but still pretty good.  I think this will probably be upholstered eventually, but even if not, I think I could hide the worst of it with some high build primer and paint.
The only thing left to do was weld up the outer edge and fill all the holes from spot weld cutting.  So I used the spot weld cutter to cut out a bunch of circles from some scrap and then got back to welding.
large.20210315_004453.jpg.80f2fe709025f8
large.20210315_004501.jpg.a2710bf434f90e
And after grinding all that back, the door welt still fits nicely.
large.20210316_180618.jpg.c8816c6be3e1c7
Of course, while welding the outer edge seam together, I managed to tack the panel to the truck body.  I knew it would happen and I knew what would happen to me when it did as well.  Fighting this thing to bust it free, it finally popped off the truck.  And hit me directly in the forehead with the top edge.  So now I have a 3/4 inch long cut down my forehead...  oh well,  If you aren't bleeding, you aren't trying.
The door frame still flexes some.  This idea helped significantly, but it did not correct the full issue.  So I will probably be working on further ideas to reinforce this.  I have a couple different ideas tumbling around in my head, but I will have to try fitting them in there to see if I can do them properly without fouling against the hinges.
Regardless, I'm pretty happy with how this panel came out.  I think that once it is painted, it will look stock.  Without knowing it was modified I think most people will look right past it.
  • Like 3
  • Replies 161
To be honest, I didn't even notice that part was pushed out.. I had to go back to the last page to figure out what was goin on here. I thought you deleted the hinge mount holes as part of a redesign. 🙂
  • Thanks 1
Thanks Noll, I do appreciate that.
Today's Episode - "Buckle Up, Buttercup!"
A bit more finishing work got done on that interior panel, then I decided it was time to test fit the Pathfinder seat belt.
Seatbelt installed, I was even able to reuse the factory trim panel over the seatbelt.
I will however have to make one small modification.  The seatbelt top mount doesn't reach its destination.  I will stretch that.  Since all the load appears to be borne on the lower mount, the upper just being a 6mm bolt, I don't think that will cause me any safety concerns.
And this photo is the outside of the door frame with this panel fully installed.
I'm stymied as to how to attractively and effectively close off these openings.  I've got a very vague idea about building boxes on the hinge body itself that teh hinges would swing in to, but I really dont know.
large.20210318_001737.jpg.309fd885a0ebdc
  • Like 3
A friend of mine suggested the "feathery plastic crap from an escalator" as at least a temporary solution if I can't come up with something better.  Like this stuff.
I just might have to go that route if I can't come up with anything else that fits in the space.
Today's Episode - "You flexin' on ME?"
I still haven't figured out how to close these holes in the body.  But we are going to ignore that and celebrate victory nonetheless.
I FIXED THE DOOR FRAME FLEXING!  I'm very happy about that, because honestly, I was not really sure I could make it happen.
I decided to really look at how the factory dealt with the flex problem.  Since I didnt use the hinge side of either door to build the new door, I had all those original brackets at my disposal.  So I figured I would try to use them.  Cut them out of the doors, I did.
large.20210319_202345.jpg.9b26b05881aa5d
Each one took a different form of modification to make useable, but really it wasn't too bad at all.
This is the lowest one in process.
large.20210319_202409.jpg.2b36f3bf31acb9
Middle was almost fitting, but it was too tall.
large.20210319_202420.jpg.8a748dea92732d
My plan was to spot weld these brackets to the door frame and to the outer skin of the truck.  But then I became concerned that doing so would put too much stress on the body panel and eventually deform it.  So I went a step beyond and build some load spreader plates.  I had some extra cab skin from the trucks I cut apart, so I used that since it already had all the proper bends and curves to it.
large.20210319_223029.jpg.34ba0c1e1e9969large.20210319_223045.jpg.3c4b319a6cf20c
and welded in place
large.20210320_004400.jpg.c044cc03179f8b
I'm not really sure why I made it short.  This was only enough for the lowest bracket....  Dummy.  So I built another one.
large.20210320_013459.jpg.7ef2d82bcf988e
That's better.  Before I installed the brackets, I ground down those spot welds that were in the way so the brackets sat flush.
large.20210320_013443.jpg.a64b15da06a2ec
Outside view of those load spreaders installed.  I got decent penetration at least.
large.20210320_162007.jpg.15d26a2e79087e
Brackets are in place now.  Together, with the slip fit panel for the frame edge, this doesn't really move at all when the hinge moves.  However, I've now spaced the door toward the rear by the thickness of those brackets, so I now have to space the door back forward by that same amount.  Ugh, more and more things are pointing to rebuilding this passenger door.  And I found a 720 at a yard I went to yesterday with decent doors.  So maybe that was a sign...
Regardless.  This is a huge win in my book and I'm really happy overall that I could do this and still be able to install the door and get it in the right place.  I might need to file a couple of the hinge mount holes, but that is all that I should need to make this work fine.
If anyone is curious, this is how I put my layers of metal together for spot welding.
1) Drill my spot weld holes
2) Paint only the back side of the piece I am going to weld in place.  By back, I mean the side that will be facing more metal once installed.
3) Paint the area of the truck where I am going to weld a piece to.  Let everything dry.
4) Hold piece in place on truck, scribe out the circles for the spot welds in to the primer below.
5) Grind/sand away the primer around the spot weld circles I scribed on the truck body.
Now when I am ready to weld, the top all of the directly exposed metal is bare.  For me I have found this to be preferable over weld through primers.  I typically use a self etching primer on the bare metal, then remove only the little of it where I am welding.
Today's episode - "Lather, Rinse, and Repeat."
Did a little more finish work to the hinge openings on the door frame.  Makes it look nice, and might keep 5% of water from entering the body itself.
large.20210323_201911_HDR.jpg.01e52e74b6
After that, I decided it was time to move on.  It was time to turn the truck around and get to work on the drivers side for real.  To turn it around, it had to be pushed out of the garage.  So for fun I took a few comparo pics with my Kingcab 720.
large.20210326_172950_HDR.jpg.9dfbf967bf
front of cabs lined up
large.20210326_173002_HDR.jpg.d65b5e7fa5
The front of the cabs are lined up here, so you can see how much longer than a king cab this will be.
large.20210326_173116_HDR.jpg.b68d92d4fa
pretending its actually a truck!
large.20210326_173126_HDR.jpg.88eca6f4b1
Here the backs of the cabs are lined up and you can see how much farther forward the windshield/cowl line is.
Then I pushed it back into the garage facing the other way and got cranking.
images?q=tbn:ANd9GcQ5QZpuH3VvTBgH76XpoVqlarge.20210326_174930.jpg.93b6b2f6ca9643
Finished grinding the exterior on the drivers side.  Multiple factors sped this up compared to Passenger side.  1) This side was in WAY fewer pieces, so nowhere near as many seams to clean down.  2) I'm better at judging my grinding depth and controlling the grinder than I was when I did the passenger side, which helped in 2 ways A) I ground fewer holes unnecessarily, and B) when I did have to do a little touch up welding, I didn't blow through anywhere near as often or as badly when it did blow through.
large.20210326_195854.jpg.6beb5c89648513
Its not perfect.  I wish it was.  But oh well, a little filler will hide the issues for sure.
Then on to the interior panels again.
large.20210326_211757.jpg.cdf80c0c7c2195
A bit of mild shaping and cutting and then panels across the door frame top were ready to go.  And having the other side as a reference made it much easier to build the B pillar panels.  Just copy the ideas I had already figured out.
large.20210327_103909.jpg.35563871f8e867
One patch up at the top to fill a void and its basically ready to go.  I still need to weld on a seatbelt reinforcement plate that is part of the B pillar interior panel, but both of these panels got stitched together completely.
large.20210327_211630.jpg.21e8993c142184
And then ground back and ready to install more or less.  Honestly, these panels didn't come out nice at all. I don't know if I was rushing the welding or the grinding or what it was, but these seams, while solid, are wavy and ugly in person.  It will take actually filler work to fix these if I don't just upholster over them.  I'm not really proud of these panels.  The time spent on them shows I'm learning and improving because they were done much more quickly, but the quality of work doesn't look as though I'm improving.  All told though it really is a vast time improvement.  I'm in to these 4 panels (including the two small ones across the top) only about 8-8.5 hours of work.  I have to install the seatbelt mounts then make the panel that covers the bottom of the B pillar and then just a couple more minor things and the B pillar will be ready to go.
Edited by Lockleaf
  • Like 3
Thin metal gonna wave. Patience is difficult when your staring down 4 ft of weld, once stitch at a time. Sounds like you're improving though, and gaining confidence for the next job. Sometimes you just gotta get in there and booger things up. Next time will be better. It's been inspiring to see the work Noll has done in his Z thread. That's what I picture for this one as well. By the end, you'll be wanting to go back and fix things because your skills have improved.
My mig is setup with .025 wire. Makes welding j-tin a bit easier, but I still make a mess at times.
Thanks Draker.  I'm running .023 wire with C25 gas mix.  Recently on one of the Fitzee's Fabrication videos, he mentioned that he runs straight CO2 for his welding.  Higher penetration at the same heat settings vs C25, though it is known to spatter more and make welds less pretty.  I'm curious how that change might affect my welds.  In theory, I could get the same penetration I am seeing now (which is usually pretty good) yet run less heat in to the panel itself, which seems like a good thing on this thin sheet.  I only recently refilled my bottle, so I doubt I will swap out any time soon.  Mostly just thinking out loud.
I am getting better, but man did I pick a ridiculous project.  I swear by the time I am done I will have laid down a linear mile of tacks.  Hopefully, after a mile of welding, I'll be half way decent 😄 .  Really, I'm hoping to be to "got this mostly figured out" by the time I have to do exterior body welding.  I have to modify door skins some, and I have to install a whole new roof.  I really gotta rein it in when I'm doing those and produce the best quality I can.  I have some time and a whole lot of welding to do before then.
On the roof subject, I'm thinking a Cherokee sport might be where I go.  It seems like a good size and they are common enough in junk yards etc.  Also, if I choose to go electric windows etc, I think I might use the cherokee switch panels.  They are attractive enough and also period correct looking to fit the vibe of the truck. Using those switches will likely require me to use the Cherokee door handles as well, so there is that issue.
large.image_2021-04-01_115410.png.dd06ce
I know I could always use the stand alone GM chrome switches easily enough.  But those aren't quite the vibe I want.  I would love to use sweet hot rod window switches that you use your window crank handle to actuate a switch, but those are stupid expensive to buy and I am not clever enough to make my own.
So, anyone reading this, suggestions on sources for roofs and switches are appreciated.  Factory sunroof would be a bonus.
Edited by Lockleaf
Today's Episode - "I cut a hole"
Time to wrap up the B pillar.  Well, mostly.
Just like the drivers side, I made a custom panel from scratch for the bottom of the B pillar.  There were some big ol' holes in one of my door skins from where big farmer style mirrors had once been mounted, then removed and allowed to rust badly.  So i used that section of door skin to make my panel.
large.20210401_231144.jpg.8a3fe3e4adcfc9
Cut out the garbage section and rounded over the edges, again like the passenger side.
large.20210402_000054.jpg.e84ac30443efe2
Panels are all basically finished.  Just some minor things here or there to touch up and finish on them.
large.20210402_000049.jpg.9fa1de93422416
Behind that panel, I built in seatbelt mounting like the Pass side.  Now the Pathfinder seatbelt fits nice.
large.20210402_000540.jpg.3e65d3ef95fec5
I need to weld in the upper cross brace to reinforce the top across those seams I put in, and then I think I will be ready to remove the rear panel, and get to work on the hinge body.
  • Like 3
  • 4 weeks later...
Today's episode "Door Hinge Redux"
With the B pillar essentially finished, it was time to move on to the C pillar and door hinge.
Step one, remove the inner C pillar panel.
large.20210407_182151.jpg.79528c56ee1740
Step two, mess up a hinge.  Heres the two hinges again, one pre and one post modification.
large.20210409_165138.jpg.1d7a17a458ae4e
90% of the way to finished with mods.  Only took a couple of hours this time as I had a better idea of what I was doing.  And also fairly close to the correct vertical so I avoid the sagging issues that have plagued me on these.
large.20210409_213053.jpg.42249d54000495
large.20210409_213100.jpg.99ba5dd0e472f4
For these cuts, and the modifications to the hinge, I have just measured the work I did on the passenger side and I have done my best to duplicate it.  Nothing is exact from side to side, but I think it will be fine.
While I was in this corner there was a bunch of rust, so I ground all that back and hit it with some rust converter/primer.
large.20210409_233501.jpg.dfdf1466cf355c
And once again, doing things in a different order than the first time (learning from my mistakes is a good thing), I decided to fill the spot weld holes in the C pillar inner panel BEFORE I welded on the flange that fits around the door frame.  Again, I just used the spot weld cutter to cut new circles out of scrap to weld in to these holes.
large.20210410_000023.jpg.a52ddc5c433db7
large.20210410_000033.jpg.2417db964e2fc9
I still have to finish welding these holes up.  And I finally went back and welded in the upper bracing cross all my pieces.
large.20210429_180905.jpg.2e69be70dcf7c1
And lastly, I pulled the doors off the front of this and started stripping them down.  They are totally empty of their guts now, I just need to remove the skins and window frames before they are ready to start construction on door number two.  This doesn't really look like progress though.
large.20210429_202832.jpg.0b20d5a3458f12
Today's episode - "That's the spot"
Hooray for spot weld hole filling!  Especially when you don't realize that your welder is set just a little too cold, so instead of penetration, you get surface welds.  Then grind those off and you have....nothing.  Crap.  So I basically did a bunch of this welding twice, cuz the first round wasn't really very good.
The upper corner of the C pillar panel I'm working on got jacked up when I removed it from the truck, so I found a random piece of truck scrap with a similar bend in it and replaced the corner completely.
small.20210502_181707.jpg.4007ce181ed2ac
That repair at least went decently.  Ground back it looks pretty good.
small.20210502_191937.jpg.642644622f2a2c
Once I got all the spot welds all cleaned up and the panel looking decent,  I immediately cut it into pieces.  More of that "progress" I was talking about right there 😄
small.20210502_200305.jpg.3347cd17ec71a3
I didn't get any farther than that, but next step is to built the bolt points for this panel to mount to the truck and get the panel modifications done.
Today's Episode - "A Bracing Development"
Still working on Driver's side C pillar panel.  I built the side and lower braces that the panel bolts to.  I drilled holes in it to plug weld to the body, and mounted a bunch of trapped nuts for bolting, just like the passenger side.  Both of these are slightly different from the passenger side because I made what I consider to be improvements to them.
Side brace
large.20210503_203157.jpg.91a23b93a0edda
large.20210503_203202.jpg.12adae52c06ef1
Lower brace
large.20210503_233754.jpg.7bf5f329543f94
large.20210503_233812.jpg.ff1b1e3b0bce80
And primed.  I need to grind back some primer before welding, but otherwise these are ready to go in.
large.20210503_234027.jpg.22d8f33cedd8be
I also did a lot of work to the panel itself.  I had to add metal to top and bottom to make it fit how I want it.  I started shaping the notch that goes around the seat belt lower mount hole, and also drilled about 1/3 of the mounting holes for the side brace.
large.20210503_203529.jpg.49e653fa10a639
large.20210503_203601.jpg.16e8bb9f80c388
I think it will take me two more evenings to get this finished, but my gas solenoid in my welder died last night so it is dumping shielding gas the whole time the gas valve is open.  I want to replace that before I do any more welding or I will burn through half my tank in no time.
  • Like 3
Nice !!!! I almost did this also , but realized it was just a crazy amount of work ,and just stretched mine , kodo's to you for sticking with it !!!
I am glad to see I am not the only one that's 720 nuts lol.
I thought about it for a long time , like using ranger four door rear glass , welding the back half of two 720 doors together , almost bought a 720 4 dr cab in Mexico .
I haven't had time to wander around this site for a while been building a new body for the 350Z in fiberglass  ............miss working with metal .
And I still have Blue thunder to finish , it's so close , but I had to start the Falcata Z project because a shop became available .
Link if your interested
https://my350z.com/forum/exterior-and-interior/624675-falcata-re-body-my-zed.html
I will be checking back for sure !!!
Cheers
Hey Fast,
I've actually done a bunch of reading on your Falcata thread.  Building a quad cab is too much work?  I will weld metal all day long, but fiberglass and I are not friends.  You Falcata looks awesome and the work you've put in is amazing.  I'm nowhere near your level of quality (or design work).  I look forward to seeing you around here more often again.
46 minutes ago, datsunfreak said:
I feel this is the cheat I would have used, but I am very impressed you are taking on just making it yourself. 👍
I spent two years looking at these things in Mexico.  But $4500 was the cheapest I could find a quad cab, and I just don't have the cash to blow $4500 on a cab all at once.  It would have been WAY SMARTER AND BETTER.  but instead, here I am.  I enjoy the work as much as the vehicle, so I tend to buy garbage no one else wants and then fix it up on the cheap.  Everything is always half done because I get to the point where I have to spend lots of money on things like new window rubber or redoing upholstery, or adding sound deadening, and then I go play with something else.
And thank you for the compliment.  I love watching all the stuff you and Dimlight build, so I really appreciate that.
Edited by Lockleaf
Thank you. We both hate welding sheet metal and will do anything to avoid it...  😁
Everything is always half done because I get to the point where I have to spend lots of money on things...
Same. I am rapidly approaching a point on the Galaxie where it needs parts to be purchased that will cost a fair bit more disposable income than I currently have (engine, carb, intake, etc). Having Tim around helps, cause' I can just go work on his car, or a friend's car.
For me, our shop is really just a time away from the real world, so I don't really much mind if I am working on my stuff, or someone else's...
I share a lot of that with you.  I try to dedicate a good amount of time to working on my buddies truck.  He only has the one real project (the truck that is pulling the travelall in the first pics of that thing). A couple weeks ago we pulled a 6.0 to replace the 5.3 that his truck currently has.  I think he just got the cam put in the 6.0 so soon I will be at his place to pull the truck drivetrain out and swap in the new one.
Ordered a part to fix the welder. Installed said part and that didn't work.  Now I have to determine if my diag was wrong, or I just got a bad part off shelf and just need to do it again.  So very little has changed.
I finished completely breaking down both doors
large.20210514_163118.jpg.ace14858afb757
and made some cuts to begin building the rear drivers door.
large.20210514_163108.jpg.76fa022f9f5d85
I also burned in the bolt flanges for the hinge cover/interior panel and drilled all the holes and got that bolted in ready to build the rest of it.
large.20210514_181756.jpg.8ddc9755cc8393
I put this one a little closer that the other side apparently, so inside the bolt point rubs on the closed hinge slightly.  I will have to adjust that fit as I finish building the panel.
large.20210514_181818.jpg.89c493c9569897
Edited by Lockleaf
