difrangia Posted February 26, 2020 Report Share Posted February 26, 2020 (edited) Check out this informative little article on spark plug/coil/distributor theory, polarity, and diagnostics that a quick net search turned up. https://mgaguru.com/mgtech/ignition/ig104.htm Edited February 26, 2020 by difrangia 1 Quote Link to comment
320 Newb Posted February 26, 2020 Author Report Share Posted February 26, 2020 8 hours ago, wayno said: I am happy for you that you figured it out, I am sorry I got all negative. No worries I appreciate everyone's help and patience. It's my first car project so the learning curve is steep. I think I've sorted out all my electrical bugs--all the lights, gauges, dome light, turn sigs are working properly. When I took off the cab and bed I had the underside media blasted and coated in bedliner so all of my problems were ground-related. I had to go back to some of the ground areas and take it down to metal to get good contact. 1 Quote Link to comment
stevecar Posted March 31, 2020 Report Share Posted March 31, 2020 (edited) Very nice! But your steering wheel is upside down. The larger area should be at the bottom. I know, because I did the same thing. And before anybody says it - it is indeed a "d" not a 'p". Edited March 31, 2020 by stevecar added info 2 Quote Link to comment
320 Newb Posted March 31, 2020 Author Report Share Posted March 31, 2020 8 hours ago, stevecar said: Very nice! But your steering wheel is upside down. The larger area should be at the bottom. I know, because I did the same thing. And before anybody says it - it is indeed a "d" not a 'p". Well shit. Last time I took my wheel off I broke my nose. Needless to say I'll leave the nut on a thread or two before I start pulling on it. 2 Quote Link to comment
320 Newb Posted April 3, 2020 Author Report Share Posted April 3, 2020 H horn was working great but stopped working out of nowhere. Horn button and relay are fine. When I bench test it the thin metal diaphragm vibrates but it doesn't honk. I messed with the adjustment screw a little and got it to honk once but it went back to not working. Any advice on where to go from here? The wiring and armature look pristine. 3 Quote Link to comment
320 Newb Posted April 4, 2020 Author Report Share Posted April 4, 2020 Horn update: following the advice of an Aussi 320 FaceBook friend I ran 1000 grit between the contacts and boom--fired right up. Horns are back in and honking nicely. 1 Quote Link to comment
difrangia Posted April 4, 2020 Report Share Posted April 4, 2020 There ya go tootin' yer own horn again, MT. Congratulations, sometimes it's the simplest thing like the old sayin' goes 'It's a dime holdin up a dollar' !! Nice work all the way through your build. 2 Quote Link to comment
320 Newb Posted April 5, 2020 Author Report Share Posted April 5, 2020 6 hours ago, difrangia said: There ya go tootin' yer own horn again, MT. Congratulations, sometimes it's the simplest thing like the old sayin' goes 'It's a dime holdin up a dollar' !! Nice work all the way through your build. Thanks for the kind words. 1 Quote Link to comment
320 Newb Posted April 7, 2020 Author Report Share Posted April 7, 2020 Got my steering wheel turned right side up and took it for a drive this afternoon. Took advantage of the COVID19 situation and took a pic in an empty parking lot that's usually full. 5 Quote Link to comment
difrangia Posted April 7, 2020 Report Share Posted April 7, 2020 MT, did you duck when the wheel popped off this time ?? 1 1 Quote Link to comment
320 Newb Posted April 7, 2020 Author Report Share Posted April 7, 2020 What did the factory battery hold down look like? 1 Quote Link to comment
difrangia Posted April 7, 2020 Report Share Posted April 7, 2020 (edited) 1 hour ago, 320 Newb said: What did the factory battery hold down look like? Here's what mine looked like when I tore the truck down for rebuild. I had it coated with high-Temp aluminum/ceramic by Jet-Hot in Oklahoma City. It still had the Nissan parts sticker on it. Not positive if it's the original but the hold down hardware wasn't. Did you refer to the parts manual ?? I will when I go out in the shop. Edited April 7, 2020 by difrangia 1 Quote Link to comment
320 Newb Posted April 7, 2020 Author Report Share Posted April 7, 2020 This is great, thank you. Ebay seems to have tons in this style--I'm on the hunt for one that fits my battery. 1 Quote Link to comment
Stoffregen Motorsports Posted April 10, 2020 Report Share Posted April 10, 2020 I make my own battery hold down straps. If you can find something that works, great, but most offerings today are garbage or too flashy...and garbage. I don't want to see flames or a logo cut into the steel of the battery tray on a classic truck. 1 Quote Link to comment
datzenmike Posted April 10, 2020 Report Share Posted April 10, 2020 I just don't want to see any flames.... 2 Quote Link to comment
difrangia Posted April 10, 2020 Report Share Posted April 10, 2020 Sure hope I can squeak past the 'Pearly Gates' after adding that crystal-skull vodka bottle in for a coolant overflow reservoir !! 5 Quote Link to comment
320 Newb Posted April 14, 2020 Author Report Share Posted April 14, 2020 Has anyone ever compared a 320 rear bumperette with one from a Morris Minor? It's not quite as round as the 320 bumper but looks closer than the 521 and 620 rears. https://www.ebay.com/itm/CLASSIC-MORRIS-MINOR-TRAVELLER-REAR-CHROME-1-4-BUMPER-BLADE-FREE-SHIPPING/362964472121?hash=item54825e5139:g:hN0AAOSw0yJefl4O&fbclid=IwAR0WlmZR2j-GvWB-mPhILGd3AO07HbaTNUaUkS01MhXNjEvfM-PMSRj0QR8 https://www.morrisminorspares.com/body-inc-panels-trim-c21/traveller-parts-c34/rear-bumper-blade-chrome-traveller-quality-uk-chromed-p828692?fbclid=IwAR1EUo12j9ICcR_ldo3KPywT-Wm8g3IC9Toc5HhUI7glGB5MNYw0oVodMwo The place that did my paint is a British car place and they've got a Morris Minor or two around the place. I'll try and compare. 1 Quote Link to comment
320 Newb Posted May 23, 2020 Author Report Share Posted May 23, 2020 (edited) Got my grill back from Chrome yesterday and took it for a spin, took some pics. Edited May 23, 2020 by 320 Newb 7 Quote Link to comment
thisismatt Posted May 23, 2020 Report Share Posted May 23, 2020 Awesome. Looks like a miniature model 😁 3 1 Quote Link to comment
emceefarlane Posted May 24, 2020 Report Share Posted May 24, 2020 Looks mint! Where did you get those number/license plates? 1 Quote Link to comment
Charlie69 Posted May 24, 2020 Report Share Posted May 24, 2020 She is a little beauty!!! Quote Link to comment
gene knight Posted May 25, 2020 Report Share Posted May 25, 2020 (edited) On 8/17/2019 at 7:51 PM, 320 Newb said: I'm thinking of doing another run of blank 320 VIN plates. Anyone interested? Shipped to US for $40 I think the quality is pretty good. I made high a high resolution scan of a VIN plate and blanked it out in Photoshop. It's a direct copy not an approximation with modern fonts. pm sent Edited May 25, 2020 by gene knight 1 Quote Link to comment
Stoffregen Motorsports Posted May 25, 2020 Report Share Posted May 25, 2020 On 4/14/2020 at 4:06 PM, 320 Newb said: Has anyone ever compared a 320 rear bumperette with one from a Morris Minor? It's not quite as round as the 320 bumper but looks closer than the 521 and 620 rears. https://www.ebay.com/itm/CLASSIC-MORRIS-MINOR-TRAVELLER-REAR-CHROME-1-4-BUMPER-BLADE-FREE-SHIPPING/362964472121?hash=item54825e5139:g:hN0AAOSw0yJefl4O&fbclid=IwAR0WlmZR2j-GvWB-mPhILGd3AO07HbaTNUaUkS01MhXNjEvfM-PMSRj0QR8 https://www.morrisminorspares.com/body-inc-panels-trim-c21/traveller-parts-c34/rear-bumper-blade-chrome-traveller-quality-uk-chromed-p828692?fbclid=IwAR1EUo12j9ICcR_ldo3KPywT-Wm8g3IC9Toc5HhUI7glGB5MNYw0oVodMwo The place that did my paint is a British car place and they've got a Morris Minor or two around the place. I'll try and compare. The two are similar, but the Datsun units are a bit more rectangular shaped. I bet the Morris parts would look great. 1 Quote Link to comment
320 Newb Posted June 17, 2020 Author Report Share Posted June 17, 2020 On 5/24/2020 at 4:16 PM, emceefarlane said: Looks mint! Where did you get those number/license plates? I bought it used on eBay for maybe $40 and I think it maybe came from Indonesia? 3 Quote Link to comment
