Stoffregen Motorsports Posted November 2, 2017 Report Share Posted November 2, 2017 There's only one idle mixture screw and then the idle RPM screw. If adjusting both of those doesn't get you running well, then I'd start looking for vacuum leaks, improper timing (timming) adjustment or worn out distributor. 2 Quote Link to comment
wayno Posted November 2, 2017 Report Share Posted November 2, 2017 I have had nothing but issues with 320 distributors, none of my good running 320s have one anymore. I am always cautious about cheap carbs or parts for that matter, you get what you pay for, it's cheap for a reason, but I have had a 320 carb rebuilt and it didn't run properly either(floods out going around corners or when unlevel), I suspect it was because of the needle and seat they used, I could have broke open a rebuild kit I have and installed the proper ones, but I put a Weber on it instead and it starts way easier now, but about the same time I figured out how to put positive ground electronic ignition on it, all I know is it starts way easier but now has another miss issue I already mentioned. 1 Quote Link to comment
320 Newb Posted November 2, 2017 Author Report Share Posted November 2, 2017 It seems like it runs well but I can't get it adjusted so it idles. Any tricks to getting the idle adjust screws in a starting place that'll let the truck long enough to heat up so I can fine tune it? 1 Quote Link to comment
wayno Posted November 3, 2017 Report Share Posted November 3, 2017 Does it try to chug when you let off, or does in run smooth and then die when you let off? Does it smell rich? There is a fuel mixture screw at the base of the carb, have you tried adjusting it yet? 1 Quote Link to comment
Stoffregen Motorsports Posted November 3, 2017 Report Share Posted November 3, 2017 If it's not idling, I suspect that either the idle up screw isn't making contact with the lever or that the distributor is having issues. Did it have the same problem before you swapped carbs? If yes, then check the distributor and timing. I would also confirm that the linkage on the carb is not faulty. Was the carb complete when you bought it? Or did you have to install your own throttle lever on the carb? If you had to mix-match pieces, maybe one of them wasn't right. Can you affect the RPM at all by using the idle up screw (not the idle mixture screw) ? A good starting point for the idle mixture is 1.5 to 2 turns out. 1 Quote Link to comment
320 Newb Posted November 3, 2017 Author Report Share Posted November 3, 2017 Got it! I tightened the idle up screw all the way down, let it idle high until the engine reached running temp and then tuned it down. Woo hoo! Up next is to locate an air cleaner. The top of the carb is 2.75" wide. Does anyone know if a 521 or 620 air cleaner would fit that diameter? I could also cut the little metal tabs off the inside of my 320 air cleaner and I think the outer clamping collar would fit. I'm just nervous to hack at my only 320 air cleaner. 2 Quote Link to comment
wayno Posted November 3, 2017 Report Share Posted November 3, 2017 If you want to drive it I would suggest going down to the auto parts store and buying a cheapo aftermarket air filter housing/filter, I am sure they have something that will work. Here is one on ebay. https://www.ebay.com/itm/Mr-Gasket-1487-Air-Cleaner-9-x-2-3-4-Inch/263131075072?epid=227862322&hash=item3d43d59200:g:t4kAAOSwAVxZ1Skh&vxp=mtr Here are larger ones under "2 3/4 inch air cleaner" https://www.ebay.com/itm/Mr-Gasket-9790-Round-Steel-14-Air-Cleaner-Assembly-for-2-3-4-Barrel-Carburetors/141351572767?epid=227199949&hash=item20e935d51f:g:eZgAAOSwPTlTyXFH&vxp=mtr https://www.ebay.com/itm/Mr-Gasket-4339-Round-Steel-14-Air-Cleaner-Assembly-for-2-3-4-Barrel-Carburetors/121389041049?epid=227402909&hash=item1c4359c599:g:OLMAAOSwX6VTyXFm&vxp=mtr https://www.ebay.com/itm/MR-Gasket-1487-Holley-Edelbrock-9-X-2-3-4-Easy-Flow-Chrome-Air-Cleaner/161933473118?epid=227862322&hash=item25b3fcb55e:g:j7gAAOSw7GRZH0Ir&vxp=mtr 1 Quote Link to comment
difrangia Posted November 3, 2017 Report Share Posted November 3, 2017 Ted in Washington had spare 320 air cleaners a year or so ago. 1 Quote Link to comment
320 Newb Posted November 4, 2017 Author Report Share Posted November 4, 2017 I talked to Ted and he's got some 3" 620 cleaners but I think at this point I'm just going to modify my 320 air cleaner. It'll be tight but I think I can get it to work. 2 Quote Link to comment
320 Newb Posted November 13, 2017 Author Report Share Posted November 13, 2017 Picked up a nice 320 air cleaner off of Los Angeles Craigslist for $30. The guy selling was super nice and let me pay him with PayPal and shipped it out. He's got a few other things if anyone's interested: https://losangeles.craigslist.org/sfv/pts/d/datsun-parts/6351639199.html I'm still taking off trim and I took apart my door latch inside the door to get to a trim nut I couldn't reach otherwise. After I put it back together if works but I have to slam the shit out of the door to get it to shut right. The door lock and inside/outside handles all work it just doesn't shut completely without force. Is there a way to adjust the latch? Is there an easy fix I'm missing? 1 Quote Link to comment
Stoffregen Motorsports Posted November 13, 2017 Report Share Posted November 13, 2017 Is the door flush after it clicks shut? Did you install new rubber weatherstripping? I had the same problem after I installed my door weatherstripping. 1 Quote Link to comment
320 Newb Posted January 7, 2018 Author Report Share Posted January 7, 2018 My wife and I had baby #2 so the project has slowed down but today I hooked up an uncut 320 air cleaner I scored. I'm running a J15 motor and J15 carb but was able to use an exhaust adapter to go from the 2.75 carb opening to the 2.5 air cleaner opening. It bumps the whole assemble up a little but it clears the hood no sweat. 2 Quote Link to comment
320 Newb Posted January 27, 2018 Author Report Share Posted January 27, 2018 Here's a pic of the stainless exhaust adapter I cut down and used to fit a stock 320 air cleaner to a J15 carburetor. And below it is a pic of my new air cleaner all cleaned up. Inside the housing the paint was in great shape so I cleaned it up and had the local auto paint store use their magic camera to do a paint match and mix it in a rattle can. I sanded the housing down, gave it a handful of coats and there you go. Oh and I cut a new piece of rubber into a new rubber boot where it clamps down. And I wire brushed up the clamp arm. 2 Quote Link to comment
320 Newb Posted November 12, 2018 Author Report Share Posted November 12, 2018 I'm back at it... Motor and tranny out, bed off, dash and windshield out. Lights out, trim off... Getting it stripped down for paint. I cracked my windshield a little taking it out but I've got a local glass guy that thinks he can cut me a copy out of a modern windshield. 1 Quote Link to comment
66Fairlady Posted November 13, 2018 Report Share Posted November 13, 2018 I have new 320 windshields. $400. Pickup in Bellevue WA only. 1 Quote Link to comment
320 Newb Posted November 13, 2018 Author Report Share Posted November 13, 2018 5 hours ago, 66Fairlady said: I have new 320 windshields. $400. Pickup in Bellevue WA only. Thanks for the offer but I'm in Tucson AZ. 1500 miles makes it tough to pick up. ? 1 Quote Link to comment
320 Newb Posted November 14, 2018 Author Report Share Posted November 14, 2018 Here's a random question. Does anyone know what finish the tailgate chains came with from the factory? Zinc plated maybe? 1 Quote Link to comment
wayno Posted November 15, 2018 Report Share Posted November 15, 2018 As far as I know they came painted the same color as the truck. 1 Quote Link to comment
320 Newb Posted November 15, 2018 Author Report Share Posted November 15, 2018 Seems like that'd just be a recipe for getting chipped up to shit. I've got the original bed chains and there's def no OG paint on them. They just have a light rust patina. Any suggestions on what to do with the chains for a stock look? Powder coating to match the truck color? Zinc plating? Black chassis paint? 1 Quote Link to comment
Toybomber Posted November 15, 2018 Report Share Posted November 15, 2018 GOLD ROPE CHAIN ? 2 Quote Link to comment
wayno Posted November 15, 2018 Report Share Posted November 15, 2018 Most truck drivers do not like hearing the chains rattle around in the bed so they put water hose or clear hose over the chain so it doesn't hit metal and make noise. OK, I have 2 different 521 chains, one has red on the hooks on each end but nothing on the chain links, the other one has blue on the hooks on each end and has very little blue left on a few of the links, but it could have been painted by the owner of the truck at some point. If you do not want to paint them then I would find some galvanized chain and use that, at least it will not rust right away and stain the bed below it. 3 Quote Link to comment
thisismatt Posted November 15, 2018 Report Share Posted November 15, 2018 I believe they were zinc plated originally. I have some originals but can't remember exactly how they look. They had clear tubing over them to prevent clanking/rattling and damage. Currently I'm using black bicycle tube(ing) over mine, with a hole punched in the middle bottom to prevent holding water in the folded/upright position. 3 Quote Link to comment
Stoffregen Motorsports Posted November 15, 2018 Report Share Posted November 15, 2018 I second the plating, though I'm not sure if it was zinc. They had a dull sheen, not the shiny zinc you see on most hardware these days. I got some chains for my CJ5 restoration project recently that were vinyl wrapped in the original Jeep fashion. You could probably use these chains or have an upholstery shop wrap them for you - https://www.kaiserwillys.com/replacement-tailgate-chains-with-cloth-covering-fits-46-71-cj-2a-3a-3b-5-truck?gclid=EAIaIQobChMI_dvkmfTW3gIVlIqzCh13Ew1yEAQYASABEgIG0PD_BwE 2 Quote Link to comment
thisismatt Posted November 16, 2018 Report Share Posted November 16, 2018 Yeah, might have been a hot dipped galvanizing? 2 Quote Link to comment
nl320what Posted November 16, 2018 Report Share Posted November 16, 2018 I would say originally they were just zinc, but I used cold galvanizing and then slide over bicycle tubing cut to fit. 1 1 Quote Link to comment
