CGraves Posted May 18, 2016 Report Share Posted May 18, 2016 I've got a 260z that came with factory air conditioning but it's got an L24 that did not come with AC. Is there a catch all kit or would I need one for a L24 or a 260z? Quote Link to comment
datzenmike Posted May 18, 2016 Report Share Posted May 18, 2016 The L26 and the L24 engines are virtually the same outwardly. Only the internal displacement and carbs are different between them. What's missing that you need to get this going? Do you have the engine driven compressor and it's mount.? Do you have the condenser that mounts in front of the rad? These would all swap onto an L24. Quote Link to comment
CGraves Posted May 18, 2016 Author Report Share Posted May 18, 2016 @Mike As far as I can tell I need literally everything. I THINK the P/O gave me a compressor in the big parts box but I'm not sure if it works at all. Quote Link to comment
datzenmike Posted May 18, 2016 Report Share Posted May 18, 2016 Sorry, you said it came with factory air. Or was everything removed? If just an engine swap, then the compressor may be out but everything else is likely there. What about the condenser? the rad in front of your engine rad. The cooler unit under the dash? If half missing then any replacement air con kit will do. It's not engine specific. The L24 and L26 are identical on the outside. The factory system would be best. Quote Link to comment
CGraves Posted May 18, 2016 Author Report Share Posted May 18, 2016 @Mike It did but he removed most of the air stuff for weight savings I guess? I just checked my parts box and I have a compressor, condenser and all the stuff under the dash. I need all the mounting brackets etc. Edit: the condenser looks beat to shit so I might buy a new one cause this one is ROUGH. Quote Link to comment
datzenmike Posted May 20, 2016 Report Share Posted May 20, 2016 Well anything that will fit the L24 will fit the L26. Quote Link to comment
