Proportion Vavle
N268510S
I have a 1968 Datsun 510. Does anyone have a proportion valve where all the brake lines meet up with a brake switch. I have one on the car but it leaks. I can't drive the car. The proportion valve does not look right, I might be wrong. I enclosed some pictures of my proportion valve in the link below. I live in Anaheim, CA. Please text me at (714) 457-7099.
PLEASE HELP I'VE BEEN DEALING WITH THIS FOR A FEW MONTHS NOW.
Thx.
[/url]">http://IMG_1335_zpsdu0qgddg.jpg
[/url]">http://http://s483.photobucket.com/user/fijikhan66/media/IMG_1336_zpscybtacgg.jpg.html'>IMG_1336_zpscybtacgg.jpg
  • Replies 7
Always check your post. Those pictures are not showing.
I believe if it has the electrical wire on it, it's the brake warning switch and not a proportioning valve. This unit only senses a loss in brake pressure compared to the other side. The brake warning switch on the 510 is the same one used on the 240/260/280Z car, the 610/710 and the B210 through '78 so there are lots out there
I'm not convinced the 510 even has a proportioning valve and relies on larger or smaller brake cylinders on the back to provide the front / rear bias. The '73 610 does have a proportioning valve and a separate brake warning switch.... perhaps later 510 have them?
So is it a distribution block for the braking system. Does anyone have a picture of one since my photo did not load to the link.
Thx.
It's not a distribution block. I assume you have a dual master cylinder? The brake warning switch keeps the front and rear systems separate but lack on pressure in one side will trigger a switch that lights the brake warning lamp in the dash to let you know there's been a failure.
I'm sure someone will have a spare but to ask it must be done in our classifieds... http://community.ratsun.net/classifieds/category/8-brakes/?sort_key=date_added&sort_order=desc .There is a link to them on every page at the top under the RATSUN.NET logo. You might even find one at the Nissan dealer or an auto supply store.
