Datsun 720 OEM tach
Macraja
Hi I have 1984 Datsun 720, Z24, 4WD. My OEM tach quit working. I replaced resister with New OEM. At the three prong plug  ( that plugs into the back of OEM tach)I have 12V in one leg when ignition on.
I plugged tachometer in other two legs and it does register RPM. Any suggestion please.
What  I meat to say is that when  disconnected oem tach ( three prong plug) # 1 wire from resister, # 2 wire from ignition when hot and I assume # 3 wire is ground,I  hooked up external Tach/ dwell meter from Sears to # 1 and # 3
Tach/dwell meter did work.,
  • Replies 10
So..... you're saying that it works????
Take the factory one out and have a look at it. Not much you can do but blow the dust off of it. Does it move freely? Look for a broken or loose solder track on the printed circuit.
I did take gauge out. Blow dust out with compressed air at 5 PSI. Looked at solder joints. Needle moves freely. Nothing visible crack. Reinstalled gauge . same issue it did not work.
Installed another OEM  tach. This one does not work. No needle movement when truck started.
Seems to me that it's very unlikely that you would happen to have two tachs that do not work.
Check that both coils are firing. Got spark????
