That4doorKiD Posted November 22, 2016 Author Report Share Posted November 22, 2016 Hopefully it's not making a fire. 2 step is in the making. MSD box Quote Link to comment
That4doorKiD Posted November 22, 2016 Author Report Share Posted November 22, 2016 Just need to relocate oil drain bung and rebuild the Weber with my parts Quote Link to comment
datzenmike Posted November 25, 2016 Report Share Posted November 25, 2016 yes... Quote Link to comment
That4doorKiD Posted January 7, 2017 Author Report Share Posted January 7, 2017 Finally Welded this thing up! My new job has kept me busy these last few months..But added wastegate flange to collector AND the external wastegate clears. This whole manifold suprisinly is able to clear everthing...which was my goal. Anwyays here ye go... As you can see before I almost gave up on this project a few weeks ago, I was so pissed my machine could not make a bead with the bad settings I had it on. I got so mad and went crazy lol....shitted all over the manifold with the trigger and threw it on the floor after haha. Then continued the Friday after Grinded all the welds and my anger off of it... for like 2 hours:/ Finished it today So close to getting my ZX struts done. Just need to buy fresh calipers and pick up MR2 inserts. Also need to shorten my strut.. I've accumulated all these parts in the past 2 months (suspension stuff was this week :) and making room Side project to fit 15x9 0 offset in the rear. In the middle of cuting and welding the inside of wheel well and lip to make room :) I just need to decide which ebay rims I want and buy the first single wheel... at a time. Front will be 15x8 0 offset 1 Quote Link to comment
mattyhacks71 Posted January 8, 2017 Report Share Posted January 8, 2017 Good looking pile of parts there. Keep it up! 1 Quote Link to comment
Draker Posted January 8, 2017 Report Share Posted January 8, 2017 Solid collection! 1 Quote Link to comment
Stoney Posted January 10, 2017 Report Share Posted January 10, 2017 I suggest making a support mount for that manifold, there looks to be a fair weight to it, and once you add a turbo and wastegate as well, and that far from the cylinder head, plus only using M8 studs in the head, making a support from the block to the flange would be worthwhile to help prevent cracking or more likely, exhaust gasket leaks.Solid selection of parts you have accumulated. Looking good 1 Quote Link to comment
That4doorKiD Posted January 10, 2017 Author Report Share Posted January 10, 2017 I suggest making a support mount for that manifold, there looks to be a fair weight to it, and once you add a turbo and wastegate as well, and that far from the cylinder head, plus only using M8 studs in the head, making a support from the block to the flange would be worthwhile to help prevent cracking or more likely, exhaust gasket leaks. Solid selection of parts you have accumulated. Looking good Yes brace will be added forsure. Quote Link to comment
The Taterhead Posted January 11, 2017 Report Share Posted January 11, 2017 Second parts pile pic has orange wheel in it; why not use those. Quote Link to comment
cleverusername Posted January 11, 2017 Report Share Posted January 11, 2017 Scholppy lmao. Keep up the good work, it ain't easy to build sweet cars when you're in school. I speak from experience. 1 Quote Link to comment
That4doorKiD Posted January 11, 2017 Author Report Share Posted January 11, 2017 Scholppy B) lmao. Keep up the good work, it ain't easy to build sweet cars when you're in school. I speak from experience. *Scultpy B) *Sculpturish B) (just to clarify he's not saying sloppy and not making fun of me hehe) Thanks, Yeah I got almost no time Quote Link to comment
cleverusername Posted January 12, 2017 Report Share Posted January 12, 2017 *Scultpy B) *Sculpturish B) (just to clarify he's not saying sloppy and not making fun of me hehe) Thanks, Yeah I got almost no time I mean I was saying sloppy. But more in reference to the splatter you threw all over it. Quote Link to comment
That4doorKiD Posted January 12, 2017 Author Report Share Posted January 12, 2017 Wow nvm Quote Link to comment
mattyhacks71 Posted January 12, 2017 Report Share Posted January 12, 2017 I mean I was saying sloppy. But more in reference to the splatter you threw all over it. Hey man, if it doesn't leak then who cares. 1 Quote Link to comment
cleverusername Posted January 13, 2017 Report Share Posted January 13, 2017 Oh lord. I'm not being a dick I'm just fucking around. I love this build, and that manifold is tight. 1 Quote Link to comment
That4doorKiD Posted January 24, 2017 Author Report Share Posted January 24, 2017 Just bought a boost retard box. Looking for a 6al now or something I can make out of for a rev limiter. Anyone try the tach shift light wired up with your distributor? I want flames and backfire coming out of my 3 inch pipe!! It's gonna be awesome. Would anyone recommend 2 Quote Link to comment
That4doorKiD Posted March 25, 2017 Author Report Share Posted March 25, 2017 it's alive 1 Quote Link to comment
HOGIE Posted March 25, 2017 Report Share Posted March 25, 2017 it's alive Fuckin teaser This really isn't enough info Quote Link to comment
That4doorKiD Posted March 29, 2017 Author Report Share Posted March 29, 2017 pulled out running L16 /210 motor with Josh (shacksBoY) tried to replace much gaskets as possible except rear main and headgasket. cleaned everywhere sealer everywhere test fit and didn't need hammers but i like space $$$ Rebuilt with 2.5mm needle seat, nitrophyl floats, and boost actuated power valve,,,,to enrich under boost instead of vacumm. (Opposite of NA spring positioned) Sealed bonnet keeper with copper RTV Spark plug almost died, plug chaser came in clutch going for an all new ugly look until someone wants to donate a proper intercooler. 1 Quote Link to comment
That4doorKiD Posted March 29, 2017 Author Report Share Posted March 29, 2017 https://instagram.com/p/BSF-g-1Az47/ Major vacuum leak lmaoo...can't upload properly running cause Photobucket is ass... no charge pipes yet till I fix my oil leak from stupid head gasket 1 Quote Link to comment
wayno Posted March 29, 2017 Report Share Posted March 29, 2017 That turbocharger looks huge, how did you decide that this turbocharger was the right size for a 1600cc engine, or has this already been discussed? I am using a 1600cc gasser turbocharger on my 2500cc Nissan SD series diesel engine, and it is significantly smaller than the one you are using. 2 Quote Link to comment
datzenmike Posted March 29, 2017 Report Share Posted March 29, 2017 The only place oil can leak form the head is directly above the pressure sender. Anything else is the valve cover gasket, the timing chain inspection cover at the front and the fuel pump . It should have pump, gasket, plastic spacer, gasket, head. Also on the pump is a pivot pin for the arm inside... they sometimes weep oil. Clean and put a dab of RTV on to cover. Quote Link to comment
That4doorKiD Posted March 29, 2017 Author Report Share Posted March 29, 2017 Top of timing cover where head bolts to. That's where the head gasket is leaking Quote Link to comment
