Where to find zx master cyl resivoirs
Anderson521
  • Replies 4
The rear most one from a Nabco master from a 610/710/620 ('77 on) or 810 is the same as the front one on the zx master. So as far as I'm concerned any reservoir will work as long as there is room for it and it does not interfere with the other. The zx uses two fairly large squarish reservoirs. I don't see why you could not use two of them from a 610/710/810.
