Crashtd420 Posted July 30, 2019 Report Share Posted July 30, 2019 2 hours ago, DatsuNissanLove said: Yoh wuhts up everybody.. it's been awhile.. I'm having issues with reinstalling my cam sprocket.. came off easy but the belt seems super tight now I can't get it back on.. any tips? Did you have a wedge holding the tensioner in place when you removed the sprocket? Even if you did the tensioner may have popped out..... 1 Quote Link to comment
Stoffregen Motorsports Posted July 31, 2019 Report Share Posted July 31, 2019 Tensioner most likely fell out. Definitely in the top 10 of Datsun L series mistakes. First on the list is probably the rotation of the distributor and firing order. That would be a fun topic - top ten L motor mistakes. 2 Quote Link to comment
DatsuNissanLove Posted July 31, 2019 Author Report Share Posted July 31, 2019 22 hours ago, Crashtd420 said: Did you have a wedge holding the tensioner in place when you removed the sprocket? Even if you did the tensioner may have popped out..... Yuhp it did.. saw it as right after i wrote on here.. smh.. got new parts coming in as we speak.. 3 Quote Link to comment
Crashtd420 Posted July 31, 2019 Report Share Posted July 31, 2019 Not the worse thing .... at least you know and can move forward..... 3 Quote Link to comment
DatsuNissanLove Posted August 8, 2019 Author Report Share Posted August 8, 2019 Does anyone know the correct torque spec for the chain guides.. chain tensioner.. front cover.. n the two 10mm bolts that are in the front of the head? Been looking on the haynes repair Manuel n can't find em.. 1 Quote Link to comment
Stoffregen Motorsports Posted August 8, 2019 Report Share Posted August 8, 2019 Basic torque specs are universal. 6mm bolt is usually around 6-8 ft/lb 8mm bolt is around 18 ft/lb Remember, 6mm and 8mm refer to the thread, not the socket that fits on it. 6mm JIS bolt has 10mm hex head 8mm JIS bolt has 12mm hex head So when referring to bolts and screws, use the thread size, not the wrench size. 1 Quote Link to comment
datzenmike Posted August 8, 2019 Report Share Posted August 8, 2019 Top Ten in no order... #2 and #3 plug wire reversed. The difference between counter and counter clockwise timing order. Distributor 180 out. Timing tensioner dropping out. Finding an EI dizzy but not getting the base that goes with it. Using a closed chamber head on an L16 or worse, an open chamber letter head. Replacing more than one electrical part at the same time because 'it won't start'. Laying an L head down with the valves facing down. Using a fram oil filter Not using NGK spark plugs ..... 2 Quote Link to comment
Duncan Posted August 19, 2019 Report Share Posted August 19, 2019 BTW, Those Cal roadside smog checks are completely voluntary. I got pulled over once and I told them politely I didn't have time and wouldn't volunteer. There are no fines, tickets, or penalties for refusing to submit to the test. https://www.ocregister.com/2014/01/03/on-the-road-no-penalty-in-skipping-smog-compliance-checkpoint/ 1 Quote Link to comment
DatsuNissanLove Posted October 29, 2019 Author Report Share Posted October 29, 2019 Now I'm having trouble with the fuse that controls the heat n gas gauge.. keeps popping.. I believe it's a 10amp n I put a 15 amp n it still pops it.. am I being stupid if I put a 20 amp? Quote Link to comment
bilzbobaggins Posted October 29, 2019 Report Share Posted October 29, 2019 13 minutes ago, DatsuNissanLove said: Now I'm having trouble with the fuse that controls the heat n gas gauge.. keeps popping.. I believe it's a 10amp n I put a 15 amp n it still pops it.. am I being stupid if I put a 20 amp? \ Yes. Dont do that. The fuse is there to be the weak point and prevent further damage. 1 Quote Link to comment
DatsuNissanLove Posted October 29, 2019 Author Report Share Posted October 29, 2019 47 minutes ago, bilzbobaggins said: \ Yes. Dont do that. The fuse is there to be the weak point and prevent further damage. Fuhkin truck Quote Link to comment
datzenmike Posted October 30, 2019 Report Share Posted October 30, 2019 5 hours ago, DatsuNissanLove said: Now I'm having trouble with the fuse that controls the heat n gas gauge.. keeps popping.. I believe it's a 10amp n I put a 15 amp n it still pops it.. am I being stupid if I put a 20 amp? Not really. Eventually it will catch fire and the problem is solved. 2 Quote Link to comment
DatsuNissanLove Posted November 20, 2019 Author Report Share Posted November 20, 2019 So is der a list of things I should check off as I try n figure out what's going on here?.. my turn signals are not working either.. is der common spots where gauges ground?.. what do u guys think? Quote Link to comment
DatsuNissanLove Posted September 20, 2023 Author Report Share Posted September 20, 2023 It's been 4 years and I'm still waiting for a response...lol 1 Quote Link to comment
RyanC Posted September 21, 2023 Report Share Posted September 21, 2023 ,😀 mine was bad connectors needed cleaning 1 Quote Link to comment
Dusten Posted September 21, 2023 Report Share Posted September 21, 2023 6 hours ago, DatsuNissanLove said: It's been 4 years and I'm still waiting for a response...lol Download the service manual. Look at the wiring diagram for each circuit. Use a multimeter and test for continuity to ground where it shouldn't be. There is no 1 size fits all answer. 1 Quote Link to comment
datzenmike Posted September 21, 2023 Report Share Posted September 21, 2023 There are a lot of things on that fuse. Try unplugging the turn signal and hazard switch under the steering column and your voltage regulator under the hood. If the fuse does not blow, plug them in one at a time till it does and that's the cause. You don't have an automatic do you? 1 Quote Link to comment
DatsuNissanLove Posted September 22, 2023 Author Report Share Posted September 22, 2023 On 9/20/2023 at 11:54 PM, Dusten said: Download the service manual. Look at the wiring diagram for each circuit. Use a multimeter and test for continuity to ground where it shouldn't be. There is no 1 size fits all answer. I actually own the Manual and that's how I got it back running after the whole almost burning it down due to an Incorrect bolt used to tighten the ground wire next to the radiator deal. (Previous owner shenanigans). Maybe I missed some wires that should've been repaired but I looked up and down and was pretty confident that I got to all of them. Idk maybe I need a new harness. SMH. I just want it back on the street. Quote Link to comment
DatsuNissanLove Posted September 23, 2023 Author Report Share Posted September 23, 2023 (edited) On 9/21/2023 at 6:06 AM, datzenmike said: There are a lot of things on that fuse. Try unplugging the turn signal and hazard switch under the steering column and your voltage regulator under the hood. If the fuse does not blow, plug them in one at a time till it does and that's the cause. You don't have an automatic do you? Nope it's a stick. I'll try it when I get time. I actually replaced the fused box with a new one around the time that this was happening and noticed that the plastic on the plug was getting hot and starting to deform from it getting hot. So maybe it was something else. Suhks cuhz I'm not good at electrical stuff. I just don't understand it. Edited September 23, 2023 by DatsuNissanLove Quote Link to comment
