DatsuNissanLove
HAS ANYONE USED LUCAS GEAR OIL ?
I guess read the Lucas label or contact them about being compatible with copper/brass/bronze alloys.
Share this post
Link to post
My question is on the same lines but with regards to gear oil weight. I live in southern AZ and do some 1 1/2 hour  highway driving during the summer where the temp gets to 115f  ambient.  I am concerned about trans and diff temps so I am thinking 85w140.  It doesn't really get cold here so I am not overly concerned about the lower temp thickness.  Does anyone have any recommendations for gear oils in this region of the hot ass SW?
Share this post
Link to post
140 w is good to 50F and is a bit thick below that till it warms up from use. Probably ok in the diff. Get and us GL5 if you do.
140 w in a transmission may cause hard shifting when cooled down or cold. I would look at GM Delco Synchromesh Transmission oil. It's GL-4 rated, synthetic so very resistant to heat breakdown and quite thin so easy shifting when cool or cold. I used it last winter at about -5C or 20F with no noticeable changes.
Share this post
Link to post
I just got done changing both trans & diff out to 85w140, since it's rather warm here in Texas.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
