Cardinal Grammeter Posted March 24, 2016 Report Share Posted March 24, 2016 L18: The bottom radiator hose fitting: the bottom bolt breaks into the nearest water pump bolt. Some YaHoo, put the the wrong bolt (too long) in the fitting flange, ground it into the WP bolt, then got a shorter bolt and put it in. Turns out this 2nd bolt was too long too: I removed the WP bolt and it tore of all the threads on the WP bolt when I removed it. It felt a little stiff removing, but nowhere near worrisome. Took me a while to realize this SNAFU. Only good news was nothing was stripped, but I lost some OE bolts in the process. Shame on you Datsun. Quote Link to comment
Draker Posted March 24, 2016 Report Share Posted March 24, 2016 Uh, just make sure you use the right bolts and there won't be an issue. 1 Quote Link to comment
Rick-rat Posted March 24, 2016 Report Share Posted March 24, 2016 It's kind of strange that everything that happens, some the other YaHoo screwed something up 1 Quote Link to comment
Rjawm Posted March 24, 2016 Report Share Posted March 24, 2016 So let me get this straight, someone else screws up the bolts being in their correct holes and Datsun is to blame? Maybe if shadetree hacks took the time to organize the bolts they remove this wouldn't be an issue. 1 Quote Link to comment
bilzbobaggins Posted March 24, 2016 Report Share Posted March 24, 2016 I find jesus is to blame ten times of nine. 4 Quote Link to comment
datzenmike Posted March 24, 2016 Report Share Posted March 24, 2016 I used the wrong length head bolt once and now there's a hole in the oil pan. Damn you Nissan engineers. 1 Quote Link to comment
thisismatt Posted March 24, 2016 Report Share Posted March 24, 2016 Beware of intersecting butt holes. Lots of those around, too 2 Quote Link to comment
HOGIE Posted March 24, 2016 Report Share Posted March 24, 2016 Dam it doesn't look like your getting a pass or the sympathy you were looking for on this one. I'm sure half these guys have fucked something up, just like you did, but aren't going to post it on a public forum. stab :poke: :poke: stab :poke: stick stab :rofl: :D 2 Quote Link to comment
Cardinal Grammeter Posted March 24, 2016 Author Report Share Posted March 24, 2016 Hey, any car maker that intersects bolt hols and does not boss threaded holes exposing them to coolant is full of shit and their designs are crap because they wanted to save $1.19 on the machining operations of the block. You won't find Mercedes doing that - or Studebaker for that matter. Datsun has some good points but here they are ass hats. Quote Link to comment
Rick-rat Posted March 24, 2016 Report Share Posted March 24, 2016 Just get rid of your ass-hat Datsun and you won't have any more problems. Go buy a Honda 1 Quote Link to comment
bananahamuck Posted March 24, 2016 Report Share Posted March 24, 2016 You know i was down at the Studebaker dealership this morning and the old guy that works at the blacksmiths shop next door said they went out of business some time ago. 4 Quote Link to comment
bilzbobaggins Posted March 25, 2016 Report Share Posted March 25, 2016 It's kind of strange that everything that happens, some the other YaHoo screwed something up where have I heard you say this??? Was it a white truck or........ 3 Quote Link to comment
Dolomite Posted March 25, 2016 Report Share Posted March 25, 2016 You know i was down at the Studebaker dealership this morning and the old guy that works at the blacksmiths shop next door said they went out of business some time ago. Was that the one down the street from the apothecary and the cobbler? OP, Studebaker had wonderful revolutionary ideas like putting the starter button under the clutch that ends up getting bumped when you shift and the brilliant overdrive that only engages when you let off the throttle for long enough to have to downshift immediately. Yeah, shared bolt holes are way less intelligent than the above dumbassery. Man, I loved the 25 second 0-60 time we got with our Champion back in the day, that's why it ended up getting a 5.0 with legit overdrive. 2 Quote Link to comment
KoHeartsGPA Posted March 25, 2016 Report Share Posted March 25, 2016 Hey, any car maker that intersects bolt hols and does not boss threaded holes exposing them to coolant is full of shit and their designs are crap because they wanted to save $1.19 on the machining operations of the block. You won't find Mercedes doing that - or Studebaker for that matter. Datsun has some good points but here they are ass hats. You clearly haven't had to work on a modern car.....took me 2 hours to do a simple wiper motor replacement on my 07 mustang.....trying to get the cowl out without breaking any of the clips on it (there are no replacement for them, you'll have to purchase the entire cowl and it's not cheap) then I find out there's metric bolts everywhere when I already had my standard tools ready to work....oh but its not so simple....you need to fix the Ford engineering fuck up that lead to the wiper motor failure before you install the new one! Ford.... They circled the problem... Quote Link to comment
thisismatt Posted March 25, 2016 Report Share Posted March 25, 2016 Just get rid of your ass-hat Datsun and you won't have any more problems. Go buy a Honda 1 Quote Link to comment
MikeRL411 Posted March 25, 2016 Report Share Posted March 25, 2016 Whenever I have to disassemble ANY part of my engine or drive train, I get an 12 egg empty egg train and a grease pencil and carefully disassemble and mark the exact location and torque spec of the removed part! Screw memory! Log it in and live to drive your antique or soon to be jewel! Works for me! 2 Quote Link to comment
Stoffregen Motorsports Posted March 25, 2016 Report Share Posted March 25, 2016 Whenever I remove bolts, they go straight to the tumbler for cleaning. If there's a question, I take digital pics for reassembly reference. 2 Quote Link to comment
HRH Posted March 26, 2016 Report Share Posted March 26, 2016 Oh, don't get me started! Fucking Datsuns! I hate those shoddy quality trash cans! I only have 160,000 original miles on my '84 Datsun Maxima and those assholes made my water neck housing bolts break when I took it off to seal a leak! It took me 3 hours to re-stud the damn thing! What a bunch of horrible, horrible people! And the motor runs like a raped ape with 160,000 too! Bastards!!!! :D 1 Quote Link to comment
tr8er Posted March 26, 2016 Report Share Posted March 26, 2016 No FMD threads 1 Quote Link to comment
datzenmike Posted March 26, 2016 Report Share Posted March 26, 2016 I think Rose needs to come over 1 Quote Link to comment
