FrankRizzo Posted March 19, 2016 Report Share Posted March 19, 2016 Hey guys, my windows rattle like heck when they are down. I popped off the door cards and checked it out and the channels that hold the glass when in the down position are not holding the glass very well. It looks like the channel felt is missing on one side and the other side is worn. Has anyone ever replaced the channel felt inside the door? it looks like there are two different sizes...I can find the rear stuff on line, but the front channel is larger and I can't find a match. Here is the rear one that I can find on line: The problem is this front facing one. Anybody have a line (part number) or knowledge to share? Edit - this is what I found in the bottom of the door for reference: Thanks in advance for any help (Mike - I searched for over an hour...) . 1 Quote Link to comment
UnderControl Posted March 19, 2016 Report Share Posted March 19, 2016 There is a thread on here somewhere that lists a part number for an alternative. I'll see if I can find it again. Edit http://community.ratsun.net/topic/62436-620-window-squeegee-and-felt-fuzzies-and-channel-felt/ 2 Quote Link to comment
FrankRizzo Posted March 19, 2016 Author Report Share Posted March 19, 2016 Thanks, I found that thread but I think that is the felt in the exterior window frames when you roll up the window. Im looking for the channel felt that goes inside the door when you roll down the window. For what its worth, my measurements say that the rear rail will take the AS 1264: http://www.dannoenterprises.com/AS1264Page.htm but that weird felt channel for the front rail in my last picture is the one I can't not seem to match up. . 1 Quote Link to comment
UnderControl Posted March 20, 2016 Report Share Posted March 20, 2016 Ah, as I understood it it was a single channel that ran around the whole thing. 1 Quote Link to comment
datzenmike Posted March 20, 2016 Report Share Posted March 20, 2016 Rubber glass run front.... 80337-B5001 Rubber glass run rear..... 80338-B5000 (ignore the word rubber) My picture does not show where they meet... possibly at the top of the vertical front run. 2 Quote Link to comment
KoHeartsGPA Posted March 20, 2016 Report Share Posted March 20, 2016 I went to a local hotrod shop and matched one up from their aftermarket options, it was perfect fit and by the foot purchase, try that. 2 Quote Link to comment
FrankRizzo Posted March 20, 2016 Author Report Share Posted March 20, 2016 Rubber glass run front.... 80337-B5001 Rubber glass run rear..... 80338-B5000 (ignore the word rubber) My picture does not show where they meet... possibly at the top of the vertical front run. Thanks but...Im having a hard time matching up those numbers, but what I can find looks like the door rubber weatherstripping around the perimeter of the door. 1 Quote Link to comment
Jersey Posted March 20, 2016 Report Share Posted March 20, 2016 I had the same issue a few years back with my front channel...I went to the junkyard and grabbed one out of a Nissan Hardbody it wedges in perfectly! The Hardbody uses a one piece setup for the whole door if I remember correctly...I just cut it a little bit longer than I needed from the front of the door and then trimmed it to fit my channel. It works perfectly! No window rattles! 2 Quote Link to comment
FrankRizzo Posted October 5, 2016 Author Report Share Posted October 5, 2016 If anyone is reading this looking for the same stuff, the AS1264 I mentioned above will work for the rear lower glass "anti-rattle". It is not quite as tall as the factory felt channel, but the nylon runners fit in it fine and works great. It also looks like you could use the same stuff for both the front and back channels, they are both 9/16" wide. Now I can drive around with the windows down!!! . 2 Quote Link to comment
Farmer Posted October 7, 2016 Report Share Posted October 7, 2016 Tagged for future use 1 Quote Link to comment
Draker Posted October 7, 2016 Report Share Posted October 7, 2016 Tagged for future use Like.. 6 months from now or.. 6 years? :poke: 3 Quote Link to comment
Farmer Posted October 7, 2016 Report Share Posted October 7, 2016 The latter. lol 1 Quote Link to comment
G-Duax Posted October 7, 2016 Report Share Posted October 7, 2016 LoL, I bought some of the taiwan junkoff eBay. Too short, but did fit in the channel. But has so little tension on the glass, the window rolls it's self down as I drive....... Quote Link to comment
Scgreen620 Posted March 2, 2017 Report Share Posted March 2, 2017 Hey guys, my windows rattle like heck when they are down. I popped off the door cards and checked it out and the channels that hold the glass when in the down position are not holding the glass very well. It looks like the channel felt is missing on one side and the other side is worn. Has anyone ever replaced the channel felt inside the door? it looks like there are two different sizes...I can find the rear stuff on line, but the front channel is larger and I can't find a match. Here is the rear one that I can find on line: The problem is this front facing one. Anybody have a line (part number) or knowledge to share? Edit - this is what I found in the bottom of the door for reference: Thanks in advance for any help (Mike - I searched for over an hour...) . There is a thread on here somewhere that lists a part number for an alternative. I'll see if I can find it again. Edit http://community.ratsun.net/topic/62436-620-window-squeegee-and-felt-fuzzies-and-channel-felt/ This! The member that posted (dude surfing) works pretty good with the inside of the channel and outside .. I only paid 7 bucks for it ...I would put that glue he mentions as well Quote Link to comment
silroc Posted July 19, 2019 Report Share Posted July 19, 2019 I was looking to replace the front felt, so found this thread to follow. I purchased the AS1198 rubber from Restoration Specialties. To me it seemed much smaller than the original felt - being loose in the metal channel and not holding the glass as tight or deep. So thought I'd try the AS1395 instead. It's only slightly bigger dimensionally, but that makes a big difference. The only thing is I'm going to take a razor and trim off the little ridge sticking our on both sides. That made it conform to the square channel better. Also, this one fits so tight I can't imagine it needing any glue - but we'll see! https://imgur.com/a/ZeqmpBb 2 Quote Link to comment
FrankRizzo Posted July 21, 2019 Author Report Share Posted July 21, 2019 its been a while, but the part# I posted above has been in there since Oct 2016 with no problems. AS1264 2 Quote Link to comment
