85Nissan7204x4 Posted March 19, 2016 Report Share Posted March 19, 2016 I just installed a lift kit and bought new 31x10.5r15 tires. I don't think it will fit on my stock steel rim. I think chevy rally 4x4 rims are 15x8 with a -12mm offset. Has anyone run these on their trucks with 31s? Quote Link to comment
datzenmike Posted March 19, 2016 Report Share Posted March 19, 2016 15" wheel will fit 15" rim but won't 'look' right. Two wheel drive rims are 5" wide but the 720 also uses 5.5 and 6 inch depending on model and year. An 8" rim would be much better. Try the fit at a wrecking yard. Are all chev rally rims the same offset? Quote Link to comment
flatcat19 Posted March 19, 2016 Report Share Posted March 19, 2016 I don't think they're -12et. Closer to zero. I think k I heard +4 somewhere once. Quote Link to comment
85Nissan7204x4 Posted March 19, 2016 Author Report Share Posted March 19, 2016 What rims can i use. I found some pro comp 15x8 with a -19mm offset. I don't know what offset to get to run the 31s Quote Link to comment
]2eDeYe Posted March 19, 2016 Report Share Posted March 19, 2016 You should be able to run them, the 2wd 620 fits them with low profile tires. Quote Link to comment
