bilzbobaggins Posted May 13, 2016 Report Share Posted May 13, 2016 ^. What he said. Autolites thread funny. 1 Quote Link to comment
Datsunthug Posted May 13, 2016 Author Report Share Posted May 13, 2016 I hate auto lites. This was a picture after the head was cleaned. I got the motor running without changing plugs /wires. Cause I'm cheap as shit apparently. Going to fix that by buying some plugs in my way home and some gas to pour in the tank 2 Quote Link to comment
banzai510(hainz) Posted May 13, 2016 Report Share Posted May 13, 2016 yes no autolites thread funny. Nippndenso or NGK That truck is exactly same as mine. 2 Quote Link to comment
Datsunthug Posted May 13, 2016 Author Report Share Posted May 13, 2016 yes no autolites thread funny. Nippndenso or NGK That truck is exactly same as mine. Bitchin!!! 1 Quote Link to comment
flatcat19 Posted May 14, 2016 Report Share Posted May 14, 2016 Charlie it's numbers 61,62,63. They can still be purchased through Nissan. 1 Quote Link to comment
Datsunthug Posted May 14, 2016 Author Report Share Posted May 14, 2016 They can still be purchased through Nissan. 1 Quote Link to comment
Datsunthug Posted May 14, 2016 Author Report Share Posted May 14, 2016 Thanks flatcat!! Brakes are kinda important. Went around the block in the ride!!!!! Hood off, no muffler rear brake locking up occasionally, and maybe a sticky thermo?! Valve cover seemed way too hot compared to the radiator? Going to Check stuff tomorrow after it cools 1 Quote Link to comment
Datsunthug Posted May 14, 2016 Author Report Share Posted May 14, 2016 The cooling system was burbing like a rookie who chugged a mickeys 40 oz 2 Quote Link to comment
Datsunthug Posted May 14, 2016 Author Report Share Posted May 14, 2016 So close!!! 1 Quote Link to comment
Datsunthug Posted May 14, 2016 Author Report Share Posted May 14, 2016 List of things to do: Find or buy the brake adjuster locking plate/shims Get motor correctly timed Fix broken pipe to muffler Check thermostat in boiling water Go through all disconnected wires and clean them up or pull them if not needed. 1 Quote Link to comment
banzai510(hainz) Posted May 14, 2016 Report Share Posted May 14, 2016 New motor might run hotter since its tight. I drill a 1/8 hole in stat if you don't have a bypass on the intake metal line to lower atat housing. Some early 510/521s have this some don't. brake in bake looks fine maybe you just missing the rubber cover. I cant tell really. if brakes lock upsoemtime a bad cylinder will leak on the shoes. I also had a new master pump up and wont release. I had to pop the valve ever few miles to get home.(taiwain China masters they sell now. always buy 2 of hydraulic parts as they don't last long as the Jap made ones. Have it on hand. I been thru 4 mMaster Cyl in 15 years 2 Quote Link to comment
4perrev Posted May 16, 2016 Report Share Posted May 16, 2016 The cooling system was burbing like a rookie who chugged a mickeys 40 oz Though I was the only idiot to still drink that stuff. Oh wait.....you said rookie. Well, f&^k it, I still like it! Good to see her running again. Do the disk conversion up from and I promise you won't hate yourself for doing it. If I hadn't, I might not have avoided a stray tire off a boat trailer on Friday. Soon much better! 2 Quote Link to comment
Datsunthug Posted May 16, 2016 Author Report Share Posted May 16, 2016 Trying to get the timing right is frustrating?!?! The internals ( timing chain and sprockets) are correct 11/1 lobes up on cam 12 o'clock position Engine tdc Bright links of chain on sprocket marks 42 links between sprockets The problem is the dizzy is either all the way advanced or all the way retarded ( have pulled oil pump 3x trying to get it right) for it to run half wY descent What am I missing? I'm hoping I didn't f*^k up the timing chain?? I double checked it a bunch of times to make sure Maybe I'm just not catching the right spline on the oil pump drive gear? 1 Quote Link to comment
banzai510(hainz) Posted May 16, 2016 Report Share Posted May 16, 2016 you watch my vid ? Its all there. its really closer to 10 and 2 on cam lobes. spindal 11.28position 1 Quote Link to comment
Datsunthug Posted May 16, 2016 Author Report Share Posted May 16, 2016 Watched it about 20 times. I especially like the part about "you have to be a total idiot" to get it wrong. I'm hoping that I'm not. And yes 10 and 2 you're right I'll try again when I get home. Otherwise it's coming together as expected. Got the ngk plugs and replaced the thermo just to be safe. I Jerry rigged the exhaust but it needs everything replaced from the muffler back. Tires are fine for around the block but are cracked out like a junkie needing rehab 1 Quote Link to comment
4perrev Posted May 17, 2016 Report Share Posted May 17, 2016 Nothing worse than a junkie hangin on your tires!!! 2 Quote Link to comment
Datsunthug Posted May 24, 2016 Author Report Share Posted May 24, 2016 Back from Santa Cruz and wanting to get a wrench in my hand. 1 Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 We're all waiting for you to wrench on your junk. 3 Quote Link to comment
