720 Part # Thread
Charlie69
On 12/15/2022 at 8:22 PM, datzenmike said:
Yup.... you did say gearbox.
It's also known as a rag joint. On an '85
48071-01W00 for 2wd manual steering.
48070-19W05 power assist, tilt steering and 4x4
48070-19W05 looks to be discontinued. Where are people getting there's at?
  • Replies 84
It's likely to be NLA on an almost 40 year old truck. Different if a consumable like brake shoes, water pump, alternator.
First I would start a want ad here... https://ratsun.net/classifieds/category/9-datsun-parts/ ... someone may have one, can't be worth much and shipping it is inexpensive.
Next I would get one off another 720 in a wrecking yard.
Next I would look at other sources that might also fit and work or could be modified, such as from a Toyota.
Last I would make my own from a piece of 7/8" thick conveyor belt.... and this is what I did on my 620. Hell you could cut one out of the side wall of a truck tire.
Can 48071-01W00 be modified to fit like 48070-19W05?? I can find 48071-01W00 on ebay.
Edited by 85"720
  • 3 weeks later...
  • 3 months later...
I think I would create my own thread and post this question.  You will find that some, has entire custom heating cooling system, others have added AC from a junkyard or parts truck.
What you won't hear recently, is that one has purchased any significant parts from the dealer.  Those are all long gone by now.
  • 3 weeks later...
  • 5 months later...
In my search for a suitable anti-backfire valve for my 1984 truck, I started referencing some other models that may use the same valve. I was able find one on RockAuto that's for a 1984 Nissan Stanza. The two part numbers I was able to find for that year of Stanza are: 14835-D1800 and 14835-D1801. It seems that these part numbers are only compatible with 1983 trucks, but for 24 bucks I thought I'd give it a shot.
https://www.rockauto.com/en/moreinfo.php?pk=45927&cc=1213221&pt=10192&jsn=850
I had to ship to a friend outside of CA because of Prop 65, but she said it's a genuine Nissan part with ABY79-3 on the cap. I'll confirm when I get in in the mail from her next week!
Got the part today!
https://imgur.com/EXheEG0
I'm not sure exactly how it works, though. I can apply vacuum to the small port, but it slowly loses vacuum over time. However, if I apply vacuum quickly I can feel the valve pop open for a second, then close. I need to pick up a vac gun to some more precise testing. Either way, this thing was pretty cheap!
  • Thanks 1
  • 2 months later...
On 11/8/2023 at 9:07 PM, Sephakrid said:
Got the part today!
My 86 has the exact same backfire valve I just took it off
  • 1 month later...
1985 720 4x4 front R-180 differential.
Front Differential axle shaft "Side Oil Seal" (driver and passenger sides) Part # 38342-21001
Front Differential Bearing Cover O-Ring (Pictured below green arrow) Part # 38343-21011
Edited by IZRL
  • 4 weeks later...
  • 1 month later...
How about front inner and outer wheel bearings for the 4WD? . Currently searching but hard to find complete sets!
Im surprised how easy it is to just buy the race or the bearing but harder to find sets . Even harder to find all 4 bearings in a set .
I own a 83.5 so what year do I get ? I see listings for 80-83 and then 1983-1986
Edited by Madkaw
83.5.... what's the build date that's more accurate. The '83 model year began Nov. '82 I think.
 Up till 12 '82
Inner............ 40210-41W00 (I can't make sense of this, the inner and outer may be the same bearing?)
Jan '83 and on
Inner............ 40210-50W00
Outer........... 40215-D0100 to 06'83 and 40215-50W00 from 07'83 (different outer possibly fro switch to auto locking hubs? I don't know)
  • 4 weeks later...
Echlin part# 2-4131
The box contains two diaphragms, which are needed to repair the B.C.D.D. on some of the DFP384 carburetors. I haven't tried to install them yet, but they appear to be identical to the ones I took off my parts carburetor.
Edited by Sephakrid
Did not insert pictures correctly.
  • 3 weeks later...
  • 1 month later...
26 minutes ago, whiffy said:
Here's one for you
The turn signal switch assembly for a 85 720 King Cab. I pulled this one of my truck since it wasn't working properly, but I cannot find it online anywhere. The ones I find don't match the wiper stalk. Anyone got a part # or matching part?
Link to Google Drive
Whiffys pic for reference
