Charlie69 Posted February 10, 2016 Report Share Posted February 10, 2016 Here is the Nissan fusible link amperage color code chart. These are my Weber suppliers for decades Peirce Manifolds. Watch their videos and subscribe to their You Tube Channel. https://www.youtube....piercemanifolds 4 Quote Link to comment
Charlie69 Posted August 5, 2016 Author Report Share Posted August 5, 2016 Here are the facet Fuel pump replacement options for the Nissan 720 electric fuel pump Part #: 17020-10W00 Cube Part # FEP42SV Posi-Flo Part # FEP04SV Gold-Flo Part # FEP60SV Scroll down to locate part # desired. http://www.pilotshop.com/catalog/eppages/facetgoldflo.php?utm_source=google&utm_medium=cse&utm_term=05-01250&gclid=CNPmk8blqs4CFQSVfgodtCsOtQ 3 Quote Link to comment
Charlie69 Posted November 7, 2016 Author Report Share Posted November 7, 2016 Here is a video showing the installation of the Weber DGEV throttle shaft bearing kit. 2 Quote Link to comment
datzenmike Posted November 7, 2016 Report Share Posted November 7, 2016 Always thought it would have been a bushing more than a bearing. Thanks for sharing and clearing this up Charlie. That 'bearing' looks like a Dodge door hinge bushing. 1 Quote Link to comment
Charlie69 Posted November 11, 2016 Author Report Share Posted November 11, 2016 The Weber DG series come stock with I believe a nylon bushings. These wear over time and cause a vacuum link. The bearings are an up grade that helps to not have a vacuum leak at the throttle shaft. Also smoother action than the bushing. Quote Link to comment
MaxChlan Posted January 21, 2017 Report Share Posted January 21, 2017 By request, here are pulley part numbers: Power Steering Idle Pulley. This is the pulley on the driver's side of the vehicle: Gates 38037 Belt Drive Pulley Air Conditioning Idle Pulley: This is the pulley on the underside of the vehicle: Hayden Automotive 5007 Idler and Belt Tensioner Pulley The bearing inside the factory pulley is a 6203z, but the Gates pulley contains a 6203-rs, I believe. When replacing both pulleys outright, you will need to press out the most inner portion out of the bearing, and press it into the new pulley. This is a sleeve, and allows for the pulley to go on the bolt without any gap. It also allows for the convex blue dust jacket to be placed nearest the block without it rubbing on the pulley. As I replace the pulleys over time, I will update this so that people are able to find the correct replacement pulley. 4 Quote Link to comment
MaxChlan Posted May 27, 2017 Report Share Posted May 27, 2017 Here are part numbers for all of the belts: Air Conditioning (innermost): Duralast 15365 Alternator and fan belt (second): Duralast 17335 Power Steering (outermost): Duralast 17465 All of these are V-belts. 3 Quote Link to comment
mx71 Posted December 8, 2017 Report Share Posted December 8, 2017 Part number for bolts bolting front brake rotors to hub: 01111-00312 3 Quote Link to comment
datzenmike Posted December 8, 2017 Report Share Posted December 8, 2017 The latest superseded number is 40209-22000 and was used on every Datsun PL510, HL510 240/260/280z, 610, 710, B210, 210, 310, 620, 810/Maxima, S10/S110 that had disc brakes. Very common part. This will widen your search. 3 Quote Link to comment
MaxChlan Posted February 27, 2018 Report Share Posted February 27, 2018 For those who live in the ice box: a block heater that goes into the driver's side rear freeze plug: Kat's 11401 3 Quote Link to comment
datzenmike Posted February 27, 2018 Report Share Posted February 27, 2018 You can use more than one if you want. I've used one in Ontario and a heater blanket for the battery.... and 10W oil. It was a B-210 and 10W30 was too think below zero. 3 Quote Link to comment
DIY 1985 Posted March 5, 2018 Report Share Posted March 5, 2018 By request, here are pulley part numbers: Power Steering Idle Pulley. This is the pulley on the driver's side of the vehicle: Gates 38037 Belt Drive Pulley Air Conditioning Idle Pulley: This is the pulley on the underside of the vehicle: Hayden Automotive 5007 Idler and Belt Tensioner Pulley The bearing inside the factory pulley is a 6203z, but the Gates pulley contains a 6203-rs, I believe. When replacing both pulleys outright, you will need to press out the most inner portion out of the bearing, and press it into the new pulley. This is a sleeve, and allows for the pulley to go on the bolt without any gap. It also allows for the convex blue dust jacket to be placed nearest the block without it rubbing on the pulley. As I replace the pulleys over time, I will update this so that people are able to find the correct replacement pulley. The factory pulley for the idler has a bearing pressed in and locked with a retaining ring. My pulley is good, but the v-shape is grooved heavily. The Gates pulley has no retaining ring and sits too close to the tensioning mechanism (but suppose that I could insert a washer) Was the idea to replace the pulley bearing, or both the bearing and pulley? 2 Quote Link to comment
MaxChlan Posted March 18, 2018 Report Share Posted March 18, 2018 The factory pulley for the idler has a bearing pressed in and locked with a retaining ring. My pulley is good, but the v-shape is grooved heavily. The Gates pulley has no retaining ring and sits too close to the tensioning mechanism (but suppose that I could insert a washer) Was the idea to replace the pulley bearing, or both the bearing and pulley? Sorry I didn't get to this sooner, but I replaced the bearing and pulley 1 Quote Link to comment
Charlie69 Posted May 21, 2018 Author Report Share Posted May 21, 2018 These are great tools to have and carry to wrecking yards. Holds flywheel or flex plate for crankshaft bolt removal http://www.mtmfg.com/part/view/flywheel-lock-our-universal-flywheel-lock-has-been-designed?part=5003&gclid=EAIaIQobChMIj_-_0NiX2wIVGbjACh2ZpgTaEAQYBSABEgJx4_D_BwE 2 Quote Link to comment
Charlie69 Posted May 26, 2018 Author Report Share Posted May 26, 2018 720 Replacement rocker panels https://tabcoparts.com/amfinder/ 1 Quote Link to comment
Charlie69 Posted June 16, 2018 Author Report Share Posted June 16, 2018 Speedometer Drive Pinions I will update as I find more info. 3 Quote Link to comment
OlDatZMan Posted July 24, 2018 Report Share Posted July 24, 2018 I had to replace my pwr steering idler bearing and finding a x-ref from OEM was hard. Eventually found this: OD 3.1875”, ID 0.46875” Bearing: NTN 6203LUX8 NTN 6203LUX8 replacement is the 6203LLB NTN search NTN# via main page search, then on the next page search by competitor part number, listing 3: Note the different max rpm of bearings of the same size--the idler spins faster than crank speed 6203ZZ, 6203LLB, and 6203LLU, all the same dimensions and load capacities 6203ZZ is no seal, double shielded 6203LLB is double sealed nitrile rubber, non-contact type seal, 180000rpm 6203LLU is contact type seal nitrile rubber, 12,000 rpm 3 Quote Link to comment
Charlie69 Posted October 19, 2018 Author Report Share Posted October 19, 2018 This might be an option for the 1980 720 with the L20B engine. I have not tried using this in a 1980 720 with the L20B engine, if any one tries it please post as to how it fits and if using on a 2 wd or 4x4. This is using the Mike Klotz flange design. L engine flange and down pipe. Down pipe outlet 2". Contact Martin Guerra at clevermartin01@gmail.com 1 Quote Link to comment
CicliDevotion Posted December 23, 2018 Report Share Posted December 23, 2018 Anyone know if the floor pan drain plugs are a standard size? The holes look to be about 1" in diameter. Do I need to find a NISSAN specific plug? 1 Quote Link to comment
datzenmike Posted December 23, 2018 Report Share Posted December 23, 2018 The ones in the front? There are two different ones behind the seats. The fronts are 01658-00551 2 reqd. Used on 720, Maxima, Sentra/Pulsar/Stanza, S12 200sx, S14, 300zx, Altima, Titan, Murano, WD21 Pathfinder, D21 Hardbody 2 Quote Link to comment
CicliDevotion Posted December 23, 2018 Report Share Posted December 23, 2018 Awesome, thanks. Found 'em and bought 'em! 1 Quote Link to comment
CicliDevotion Posted March 22, 2019 Report Share Posted March 22, 2019 There are two plastic clips that mount to the rear wall of the cab, behind the seats. They hold the tool used to lower the spare from under the bed. What are these clips called? And does anyone have a part number for them? 1 Quote Link to comment
CicliDevotion Posted March 22, 2019 Report Share Posted March 22, 2019 “Jack clamp”? 1 Quote Link to comment
CicliDevotion Posted March 22, 2019 Report Share Posted March 22, 2019 99603W ? 1 Quote Link to comment
datzenmike Posted March 22, 2019 Report Share Posted March 22, 2019 79832-01W01 3 Quote Link to comment
