Mysta2 Posted February 5, 2016 Report Share Posted February 5, 2016 (edited) I bought a '79 today. I've wanted one of these trucks since high school (in the late nineties) I'm sure a lot of you guys were aware of this truck on Craigslist up in Everett. Assuming it isn't stolen it was a heck of a deal. Plans include getting it running, getting it stopping, cleaning up the interior. Lowering it maybe 3" with blocks in the back and adjustments in the front. Adding energy suspensions full bushing catalog, maybe a new radiator or a rebuild with an electric fan. Then rebuilding the wiring harness, cleaning up the engine bay, maybe relocating the battery to under the bed, wheels (undecided between vintage Japanese 15s or something like TE-37s or SW388s), bed liner, and bucket seats. Follow that with a disk brake kit, engine rebuild/swap, sound deadening the interior, simple stereo, maybe even get into some chassis stiffening. I'd love to swap to the earlier grill if this is possible. Is it a direct swap? All of this stuff was in the bed when I bought it, and there are a couple of brackets that I can't identify: I don't know what the cover to the left of the gas cap is, the bracket between the side badge and the rear view mirror, or the bracket between the hub cap and the headlight bracket. Also is the console the stock piece? Edited February 5, 2016 by Mysta2 Quote Link to comment
datzenmike Posted February 5, 2016 Report Share Posted February 5, 2016 Welcome to Ratsun Mysta2. Just so you know the '79 has disc brakes already so you don't exactly need a kit, but to replace them with later 720 or D-21 Hardbody calipers and rotors. Type disc brake swap into 620 into the search and start looking. Stiffening? If you mean the frame no need as it's fully boxed. Stiffer suspension? well it is a truck designed for carrying up to 1,000 pounds so it is fairly stiff as it is. I find that it rides better with a load than empty. The weight makes the ride smoother. Drive it and see. Best thing for improving the quality of the ride is a new set of quality shocks. Yes I find the earlier 620 grills much better to look at and they do pop right on without any changes. 1 Quote Link to comment
Mysta2 Posted February 5, 2016 Author Report Share Posted February 5, 2016 I edited the first post to what it was originally supposed to be. I didn't know they came with disks, thanks for that info King Rat. By stiffening I was thinking about tying a cage into the existing frame and suspension mounts toward the purpose of autocrossing, but that's a far off pipe dream. All new suspension components will surely be on the bill. I just wont be tying too much cash in it until I get the title in my name. I don't think that it is, but if the thing is stolen, I'm anxious to find out. I figure my worst case scenario is that I pay a couple hundred bucks to return someone's stolen truck to them. That sounds worth it. Quote Link to comment
Lockleaf Posted February 5, 2016 Report Share Posted February 5, 2016 Sweet truck. I love the diamond stamped canopy. The rusted cover you are unsure about is the air filter cover for a Weber carb. That may indicate that you already have a Weber under there which is a bonus (usually, other times they are in such bad shape you end up starting over anyway) The U shaped bracket by the rear view mirror may be the bracket for the center console. It would bolt to the body with the legs pointed up and then the center console would slide over it and screw in to the legs on the sides. No idea on the third one. 1 Quote Link to comment
Mysta2 Posted February 5, 2016 Author Report Share Posted February 5, 2016 Thanks, that camper might be up for sale soon :) Could anything in that pile be a battery tray/bracket? It seems to be missing that. Quote Link to comment
Draker Posted February 5, 2016 Report Share Posted February 5, 2016 Welcome to Ratsun!! Love the pictures! There are a lot of Datsun folks around your area. Get out and meet them sometime! 1 Quote Link to comment
]2eDeYe Posted February 5, 2016 Report Share Posted February 5, 2016 With the 79 you can also use drop spindles for the 720 to get 2" lower in the front without altering the control arm geometry. 1 Quote Link to comment
Mysta2 Posted February 5, 2016 Author Report Share Posted February 5, 2016 2eDeYe" post="1348267" timestamp="1454694264"] With the 79 you can also use drop spindles for the 720 to get 2" lower in the front without altering the control arm geometry. Ooh, that sounds promising. I'll definitely look into that. Quote Link to comment
bilzbobaggins Posted February 5, 2016 Report Share Posted February 5, 2016 Nailed it !!! Get some more pics of the thing between the hubcap and the bucket. Does it have a plaid interior? Quote Link to comment
Mysta2 Posted February 5, 2016 Author Report Share Posted February 5, 2016 It has a crap interior... That's actually a bit of a lie, it's not that bad, I might consider doing plaid, but that might be too Bavarian. One of the POs put a decent bench in there (hence the removal of the console) it's a little damp though, it's loose, and I'm too tall for it. I'd like to put some slimmer buckets in there. It does have a Weber. I'll need to figure out what it is and get a kit for it. I'd show you a picture of it to help me identify, but the upload bar is stalled. Quote Link to comment
G-Duax Posted February 5, 2016 Report Share Posted February 5, 2016 Most likely the DGV, they are the most common. Found several kits on eBay. 1 Quote Link to comment
Draker Posted February 5, 2016 Report Share Posted February 5, 2016 32/36 - Kits are like $25 or so.. Quote Link to comment
Mysta2 Posted February 5, 2016 Author Report Share Posted February 5, 2016 (edited) It's a DGAV 32/36. Also note what it's sitting on :) I was driving through Kent this morning and just happened across the brick and mortar location (the performance shop) for Carbs Unlimited. So I pulled a U turn and picked up a new air cleaner, rebuild kit and power valve for the Weber. I was pretty excited to stumble on that. I still don't have a wrench that I can get to the two inside bolts for the carb though. The outside two were 11mm, but I'm not sure that the inside ones are the same. I see Helicoils in my future. Edited February 6, 2016 by Mysta2 Quote Link to comment
Mysta2 Posted February 6, 2016 Author Report Share Posted February 6, 2016 I apologize if that last picture is upside down. Apple and Windows aren't working together. I'll see If I can fix it. Quote Link to comment
hobospyder Posted February 6, 2016 Report Share Posted February 6, 2016 is that an edelbrock intake? Quote Link to comment
Mysta2 Posted February 6, 2016 Author Report Share Posted February 6, 2016 Yes it is, I didn't notice that till this morning. This thing's like a treasure chest. I love old cars! Quote Link to comment
hobospyder Posted February 6, 2016 Report Share Posted February 6, 2016 nice i'm interested in the center console and hubcap if you ever decide to part with them good score you have here Quote Link to comment
bananahamuck Posted February 6, 2016 Report Share Posted February 6, 2016 I don't understand your statements about title,,,,,,,, BUT ,,,,,,,,,, if you never saw one .. i would put no money whatsoever into that truck until you do.. Getting a title for a non-titled vehicle in Washington can be done ,,but it is quite the commitment to get it done. Quote Link to comment
hobospyder Posted February 6, 2016 Report Share Posted February 6, 2016 did you ever figure out what that last bracket is for? Quote Link to comment
datsunaholic Posted February 6, 2016 Report Share Posted February 6, 2016 The bracket between the mirror and side badge is the console front bracket I believe, or at least part of it. The other one I don't know, but could be part of the relay bracket that went on the passenger side wheelwell. What makes you suspicious that it was stolen? Here in WA, if you didn't get a title with the truck you're going to have a hell of a time registering it. Bill of sale doesn't cut it. 1 Quote Link to comment
datzenmike Posted February 7, 2016 Report Share Posted February 7, 2016 Tan dash was only available on the '79 Small round thing by gas door could be gas cap or oil cap for valve cover. Side mirrors likely after market. Look sort of like zx ones. Quote Link to comment
Mysta2 Posted March 11, 2016 Author Report Share Posted March 11, 2016 Discovered that my pics finally uploaded, so I have some more clues on that mystery bracket Think it's a part off the truck? Or just a floater in the bed? Quote Link to comment
denmarkboy Posted March 11, 2016 Report Share Posted March 11, 2016 Ooo .. Ooo .. I know this one . lol thats core support mounted for the windshield washer bottle . there should be a place on the drivers side next to the radiator . 1 Quote Link to comment
Mysta2 Posted March 11, 2016 Author Report Share Posted March 11, 2016 Awesome. Thanks Quote Link to comment
Mysta2 Posted March 11, 2016 Author Report Share Posted March 11, 2016 ...Small round thing by gas door could be gas cap or oil cap for valve cover. It's a gas cap, but it doesn't fit the truck. It's too big. Could possibly go with the blue gas door, which I'm shot in the dark guessing might be off a 720 or D21 Quote Link to comment
