How big a tire?
  • Replies 5
What is the largest tire you can run on a 13 x 8 or 15 x 8 wheel with out stretching the tire? Thanks for your help.
Define 'largest'. Tallest, widest, or the tallest widest?
Define 'stretching'. Is a 7" wide tire on an 8" rim stretched??? Is 6"??
A 265/80R13 is 29.69" tall and 10.43 wide at the tread.
A 160/40R13 is 18" tall and 6.3" wide at the tread.
If the rim is 8" wide you can run tires with tread about 8" wide.
A 205/40R13 is 8" wide at tread
A 205/40R15 is 8" wide at tread.
Here... https://www.rimsntires.com/specspro.jsp mess around with this and see if you find something you like.
