ID this Nissan turbo???
I didn't put this in the Z car forum because I don't know for sure what it's off of. Outlet pipe is cast and has thee studs for down pipe mounting. Compressor says NISSAN o MOTOR Part number 14420-P9001 made in USA GARRETT   (small letters, I think this is what it says) also 410581-7 and MG 0492.
14420-P9001 is a Nissan parts code
14 signifies 'manifold'
The P is often used on 280zx/300zx parts.
  • Replies 5
3 wire 02 and cast down pipe says Z31 T3
does it have water and oil lines for the center section
Oil only, in the top out the bottom. The early one has a round compressor outlet. The water cooled was from '87 up and had a triangular three bolt flange on the compressor outlet. I only saw the triangle one and stopped looking under the 300zxt.
Googling the part number says 1984 300ZX.
I have my own parts look up and it didn't come up so I quit.
Well this is the one alright... http://www.diamonddiesel.com/1984-nissan-300zx-turbocharger-oem-14420-p9001-dd-14420-300z-14420-300z-rx
14420-300z-rx-1984-nissan-300zx-turbocha
Thanks gentlemen...
  • 2 months later...
