72MAMBA Posted January 14, 2016 Report Share Posted January 14, 2016 My shift knob is stuck in 4th gear . I Can get it to go to neutral . It feels like it is jammed . How can infix this problem Quote Link to comment
TENDRIL Posted January 14, 2016 Report Share Posted January 14, 2016 kick or yank until it breaks free Quote Link to comment
72MAMBA Posted January 14, 2016 Author Report Share Posted January 14, 2016 Didnt work . Any ideas of what can it be ? Quote Link to comment
flatcat19 Posted January 14, 2016 Report Share Posted January 14, 2016 New clutch, yo. Get to work. Quote Link to comment
Stoffregen Motorsports Posted January 14, 2016 Report Share Posted January 14, 2016 Stuck while engine running or engine not running? If it's stuck while the engine is not running, you could have some problem with your shift rods inside the tailshaft of your transmission, or a broken roll pin at a shift fork. Quote Link to comment
72MAMBA Posted January 14, 2016 Author Report Share Posted January 14, 2016 Truck is running just stuck in fourth gear . Can get it back to neutral. I think there is something stuck inside the shift rods. How can i remove the knob to check? Quote Link to comment
Stoffregen Motorsports Posted January 14, 2016 Report Share Posted January 14, 2016 Does it shift when the engine is not running? 1 Quote Link to comment
datzenmike Posted January 14, 2016 Report Share Posted January 14, 2016 I had the (more or less same F4W63 used in the PL510 and the early 620) stuck in 4th gear 50 miles from home. Good news is you can drain and unbolt the oil pan on the bottom and take a look up in there. Quote Link to comment
