cruznude Posted January 7, 2016 Report Share Posted January 7, 2016 finally a datsun at u pull it here in Albuquerque, going down tomarrow to get all I can. Anyone need anything? oh yes its a 79 Quote Link to comment
cruznude Posted January 7, 2016 Author Report Share Posted January 7, 2016 going to you pull it tomarrow. finally a datsun 620. anyone need anything? Its a 79 Quote Link to comment
bananahamuck Posted January 7, 2016 Report Share Posted January 7, 2016 Do you know if it's a 79? 1 Quote Link to comment
datzenmike Posted January 7, 2016 Report Share Posted January 7, 2016 Only the '79 had the radio antenna on the driver's side. Things to get... The EI matchbox dizzy The H-190 is a 4.11 on the '79. The 5 speed is an option but is a wide ratio box. Check out the rubber insulator around the carrier bearing. Rad may be 3 core. Alternator is internally regulated. May have the nicer looking pre '78 grill on it Windshield? Taillights? May have clock or tach option. Dash pad may be uncracked... yeah right in NM. Fuel pump, carb, clutch master, brake master, water pump/clutch fan and shroud. . Quote Link to comment
KoHeartsGPA Posted January 7, 2016 Report Share Posted January 7, 2016 Just strip it to the bone if you can afford to and have the space to store it all. Quote Link to comment
Ratwagon1600 Posted January 7, 2016 Report Share Posted January 7, 2016 Pics or it isnt a 79 ! 1 Quote Link to comment
gene knight Posted January 8, 2016 Report Share Posted January 8, 2016 Dash plastic bezel, if not broken. Door locks, handles, ignition switch Quote Link to comment
HOGIE Posted January 8, 2016 Report Share Posted January 8, 2016 Well you said yesterday you were going to see the 79 620 today. It's today so where are the pics? Did it have the tan interior? 1 Quote Link to comment
datzenmike Posted January 8, 2016 Report Share Posted January 8, 2016 Remove steering wheel and get the turn signal switch assy. There were three different style used on the 620. The 620 shares the brake and turn signal lamps in the rear. The turn signal switch has the job of disconnecting the brake light and connecting the flasher unit to it so they don't conflict each other. Quote Link to comment
cruznude Posted January 8, 2016 Author Report Share Posted January 8, 2016 So, I go to U pull it to look at this 79 datsun and its just horrible. Its basically just a shell. There was no dash at all, no motor, the body was so beat up they should of just scraped it all together. The only stuff that I saw that was half descent were the glass. Just to say I was disappointed. Quote Link to comment
fritzdixxon Posted January 8, 2016 Report Share Posted January 8, 2016 Sounds like someone beat you to it lol 1 Quote Link to comment
MicroMachinery Posted January 8, 2016 Report Share Posted January 8, 2016 One question.. Is it a 79? Quote Link to comment
Jayden71 Posted January 9, 2016 Report Share Posted January 9, 2016 I have a Datsun...... Its a '79 Quote Link to comment
