black_bomb510 Posted January 6, 2016 Report Share Posted January 6, 2016 I'm trying to upgrade the 2.4 liter 6 cylinder in my Nissan maxima. Found a 2.8 from a 1978. noticed after purchase of motor that the oil sumps are in different locations. Anyone know what year Datsun started producing a 280zx with a front oil sump instead of the rear sump like the 1978 model. Also if I happen to strike out and re-use the 2.4 anyone know a head that would increase my compression since the 2.4 is dished piston engine. Quote Link to comment
Lockleaf Posted January 6, 2016 Report Share Posted January 6, 2016 Do the oil pan and pickup tube not interchange between those two engines? I would think you could simply use your existing oil pan on the new engine. Quote Link to comment
black_bomb510 Posted January 6, 2016 Author Report Share Posted January 6, 2016 the maxima 2.4 has a front mounted oil pickup which is 4 to 6 inches forward from the typical 2.8 liter 280z. The 2.8 liter from a 280z has the front pickup casted in the block but is not tapped or drilled. yes I could have a machine shop tap and drill the casting but with labor prices it's almost cheaper to throw some flat top pistons into that 2.4 and keep it semi-original. I assume it's because the maxima uses a rack and pinion steering and the 280 needs that space for the steering links and steering box. anyone know when the z cars had rack and pinion steering? Quote Link to comment
MicroMachinery Posted January 6, 2016 Report Share Posted January 6, 2016 The pickup is cast into the block? Are you sure about that? Doesn't sound right... Quote Link to comment
black_bomb510 Posted January 6, 2016 Author Report Share Posted January 6, 2016 no the spot where you bolt on the pickup is cast into the block but is not tapped for the bolt threads nor is the center drilled out so it actually flows oil. Quote Link to comment
flatcat19 Posted January 6, 2016 Report Share Posted January 6, 2016 It's an L. I bet it's bolted in like every motor before and after it. Quote Link to comment
bananahamuck Posted January 6, 2016 Report Share Posted January 6, 2016 You have to extend the pickup using pieces of both so it goes to the right spot... Send a PM to member Qtip as i can't find pumpkin210s maxima engine transplant thread in any of his content.. OR send PM to moderator Datzenmike or Redeye ,, or even Skib to help find it.. There is pictures of the welded pickup in that thread. Qtip http://community.ratsun.net/user/2181-q-tip/ He might remember the thread title. And he was there when it happened I would say contact Dave but he is mostly only ever on facebook ,,,,,,,,,,,,,,,,,,,,,,,,,, mostly Quote Link to comment
tr8er Posted January 6, 2016 Report Share Posted January 6, 2016 no the spot where you bolt on the pickup is cast into the block but is not tapped for the bolt threads nor is the center drilled out so it actually flows oil. Pictures. Quote Link to comment
datzenmike Posted January 7, 2016 Report Share Posted January 7, 2016 I'm trying to upgrade the 2.4 liter 6 cylinder in my Nissan maxima. Found a 2.8 from a 1978. noticed after purchase of motor that the oil sumps are in different locations. Anyone know what year Datsun started producing a 280zx with a front oil sump instead of the rear sump like the 1978 model. Also if I happen to strike out and re-use the 2.4 anyone know a head that would increase my compression since the 2.4 is dished piston engine. The compression is probably already around 8.5. Why would you want more? the maxima 2.4 has a front mounted oil pickup which is 4 to 6 inches forward from the typical 2.8 liter 280z. The 2.8 liter from a 280z has the front pickup casted in the block but is not tapped or drilled. yes I could have a machine shop tap and drill the casting but with labor prices it's almost cheaper to throw some flat top pistons into that 2.4 and keep it semi-original. I assume it's because the maxima uses a rack and pinion steering and the 280 needs that space for the steering links and steering box. anyone know when the z cars had rack and pinion steering? You're never going to " throw some flat top pistons into that 2.4" cheaper than drilling and taping two holes. They all had R&P even the zx. The '78 and up zx also had R&P and non R&P power steering boxes. Quote Link to comment
ArchetypeDatsun Posted January 9, 2016 Report Share Posted January 9, 2016 All Z cars came rear sump. Quote Link to comment
