Burns85 Posted December 29, 2015 Report Share Posted December 29, 2015 http://www.ebay.com/itm/JDM-15-RAYS-ENGINEERING-TE37-FORGED-15x7-43-4x114-3-RIMS-SENTRA-SUNNY-ED327-/321956492242?hash=item4af61a33d2:g:6mwAAOSwYaFWem86&vxp=mtr I realize that the answer is most likely going to be "without major trimming" but figured it cant hurt to check....as maybe Ive got a lingering case of the "mondays". From what Ive read and seen it looks like these will stick out of the fenders quite a bit. Car is running T3 rear coil-overs with stock drums, and front 280 struts w/T3 inserts, ball joint spacers and disc breaks. Anyways, wondering if these will fit without chopping the fenders and I don't see the price as unreasonable. Quote Link to comment
INDY510 Posted December 29, 2015 Report Share Posted December 29, 2015 They won't fit on the other side .... they will hit your front struts, BAD, and your rear control arms too. With 280zx struts, on a 510, you'll need a 15x7 +15 just to clear the struts. Anything near a zero offset starts to hit the fenders. Quote Link to comment
Son_of_a_Datsun_Guy Posted December 30, 2015 Report Share Posted December 30, 2015 15x7 +12 is the magic number if you want to fit a 205/50 tire on the front of your car (with ZX struts). 2 Quote Link to comment
510vg30 Posted January 2, 2016 Report Share Posted January 2, 2016 Sorry for thread jacking. Had a question. Will 15x6.5 +17 fit on a stock fender 2dr 510 with zx struts? 15x7 +12 is the magic number if you want to fit a 205/50 tire on the front of your car (with ZX struts). Quote Link to comment
INDY510 Posted January 3, 2016 Report Share Posted January 3, 2016 Had a question. Will 15x6.5 +17 fit on a stock fender 2dr 510 with zx struts? It should ... you might need a very small spacer if you have big front tires. The back fender lips will leave enough room to fix some of the stock negative camber. Quote Link to comment
510vg30 Posted January 6, 2016 Report Share Posted January 6, 2016 It should ... you might need a very small spacer if you have big front tires. The back fender lips will leave enough room to fix some of the stock negative camber. Thank you for responding. So whats the offset range that works the best for the back and the 280zx front? Using a 15 x 6.5 or 7 in. wide wheel. Quote Link to comment
