Lakec423 Posted December 29, 2015 Report Share Posted December 29, 2015 You say you wana do somthing and people find reasons why it won't work well I wana make it work it's a ratsun why tf not make it work lol Link to comment
hobospyder Posted December 29, 2015 Report Share Posted December 29, 2015 So prove them wrong Fucking duh 2 Link to comment
HRH Posted December 29, 2015 Report Share Posted December 29, 2015 No, it can't be done. Self-defeating original poster is self-defeating original poster. Maybe you wanted to make a chopped, lowered, rusty 620? No one's ever done that before! :D Link to comment
flatcat19 Posted December 29, 2015 Report Share Posted December 29, 2015 You're in Florida. No Datsun parts available. Maybe...maybe, its more of a "just because you can doesn't mean you should" kind of thing. Link to comment
hobospyder Posted December 29, 2015 Report Share Posted December 29, 2015 I know I saw the thread but can't remember what it was. I don't think there were pictures so I got bored Link to comment
jesusno2 Posted December 29, 2015 Report Share Posted December 29, 2015 Because every other jabroni that comes on says they are gonna do this and do that, maybe even starts up a build thread that goes 13 pages of absoloute bullshit then dissapears. Seen it a buncha a times 2 Link to comment
hobospyder Posted December 29, 2015 Report Share Posted December 29, 2015 Because every other jabroni that comes on says they are gonna do this and do that, maybe even starts up a build thread that goes 13 pages of absoloute bullshit then dissapears. Seen it a buncha a times hey I'm a jabroni with a thread that's maybe made it 14 pages of absolute bullshit. Haven't gotten that far 1 Link to comment
maltese Posted December 29, 2015 Report Share Posted December 29, 2015 What'd I miss? Link to comment
KoHeartsGPA Posted December 29, 2015 Report Share Posted December 29, 2015 Nothing much just jibberish Link to comment
bananahamuck Posted December 29, 2015 Report Share Posted December 29, 2015 Know what's weird ?? You started a thread about your dream of putting 1/2 ton chevy axles under your 720 and i assumed you got a ration of shit ,, hence this thread........... I see nothing but guys giving you help man .. With steering box choices and crunching tire size / gear ratio numbers in a attempt to help you out... So what gives ?? http://community.ratsun.net/topic/68288-putting-12-chevy-axels-under-my-81-datsun/ Was your dream to be talked out of swap :confused: 5 Link to comment
Rick-rat Posted December 29, 2015 Report Share Posted December 29, 2015 People have been giving you suggestions, but you could get more support if you would reveal what you plan to do with this truck, i.e. strictly off-road, highway and off road, rock climber? It would also be nice to have an idea of your skills or available help, this will take a lot of mods to accomplish this. Good luck, and don't give up 1 Link to comment
HRH Posted December 29, 2015 Report Share Posted December 29, 2015 Hey, just don't try and make a 1st gen Maxima an autocross car. It can't be done. ;) 3 Link to comment
datzenmike Posted December 29, 2015 Report Share Posted December 29, 2015 Assume it's about this... http://community.ratsun.net/topic/68288-putting-12-chevy-axels-under-my-81-datsun/ No one can tell you what to dream. Dreams are killed from not researching and overcoming problems first and then getting half way through and having to giving up. That's really bitter. Good research will allow you to discount many unproductive ideas or find a way around them. If someone puts a roadblock in your way navigate around it ,don't turn around and go home. If you did enough research you would find the same problems with gearing. Larger diameter tires reduce gearing. This is great for high speed if you have the power to turn them, but terrible on a 4x4 that needs lots of torque at low speeds.To compensate for this the differential needs to be changed. To run 35" tires you will need a 5.67 differential to keep everything the same. If running a larger engine, this can be reduced some. The Chev 4x4 will work.... but only because anything can be done (with enough money and effort) however it will still look and be a 720 on a chevy 4x4 axles with the tires sticking out over a foot on either side. Just because the axles are available doesn't necessarily make them the best choice. Toyota 4X4 or even better a Toyota Land cruiser have huge 9 1/2 diameter ring gears and around 60" wide. 1 Link to comment
Ratwagon1600 Posted December 29, 2015 Report Share Posted December 29, 2015 This place normally shuts down bullshit waste of time threads....... Somewhat like this one. DM, lift your game, holidays are making you soft :) 2 Link to comment
paradime Posted December 29, 2015 Report Share Posted December 29, 2015 IBTL How is it this guy thinks he can reinvent the wheel, but can't even figure out how to post a picture of his truck? 1 Link to comment
fritzdixxon Posted December 29, 2015 Report Share Posted December 29, 2015 C-clip axles suck Chevy guys throw away 10bolts, from my jeep days I get wanting to do the solid axle swap. Just what is available isn't always the best thing to use. In both threads he started there was lots of help given just not the answers he wanted. Link to comment
Rjawm Posted December 29, 2015 Report Share Posted December 29, 2015 Look at it this way, a paid automotive designer thought this was a good design, so much so that Fiat put it into production. I doubt you grabbing a welder and doing work to hang 1/2 ton Chev axles under a 720 is all that much worse. Although if I was going through that much effort I'd go with 1-ton axles, a Dana 60 front and a 14 bolt rear, and make it worth the time spent. 2 Link to comment
Ranman72 Posted December 29, 2015 Report Share Posted December 29, 2015 . http://community.rat...r-my-81-datsun/ all I see here is helpful suggestions if you have killed your project in your mind before you even started then any and all suggestions are doomed from the beginning GRAB YOUR BALLS AND GET BACK TO WORK :devil: :devil: :devil: :devil: :devil: :devil: LETS SEE SOME PICS TOO :thumbup: 2 Link to comment
paradime Posted December 29, 2015 Report Share Posted December 29, 2015 Dry heaves... I hate those. Link to comment
datzenmike Posted December 29, 2015 Report Share Posted December 29, 2015 Spit on it first. 3 Link to comment
ratpatrol66 Posted December 29, 2015 Report Share Posted December 29, 2015 Ghost rape? 1 Link to comment
RatVonDude Posted December 29, 2015 Report Share Posted December 29, 2015 I sealed my window with oil based bomb putty, yes you can do it brotha!!! Link to comment
KoHeartsGPA Posted December 29, 2015 Report Share Posted December 29, 2015 The invisible man is porking her Link to comment
