For those wanting to replace body mounts
Elkie
Seen a few people asking about replacements. This is the solution I found. Overall I think I measured it to raise the cab ~1/4".
Energy Suspension bushings
2x 9.4101 (2 per pack) 4 cab corners
1x 9.9531 (8 per pack) Core support
This is the 9.4101 kit
I run the big washer inside the cab, but here's a mounted pic. I ran a grinding wheel around the stock hole a few times to get it to slide in smoothly.
For the front core support I used 9.9531 They are just round poly discs I added washers to.
Mounted, the notched washer goes on top of core support.
  • Like 5
  • Replies 11
  • 3 years later...
