LUIS COLCHETE Posted December 2, 2015 Report Share Posted December 2, 2015 Hi! I have a intake Harada and i want a best compatible header for it... I ve grind a stock a14 one but is to heavy and im afraid from high temperatures, there ar minimal clearence betewwen them. Please let me know a best choice. Some members advice me a H89 but i think, i will have the same problem the exhaut hit the the intake this one is on net market to sell... Some people have headers made on inox (short durability?) What do you think? Share with me what you have in yours Datsun 1200....... Many thanks on advance Luis Quote Link to comment
datzenmike Posted December 3, 2015 Report Share Posted December 3, 2015 Unless racing and needing every possible amount of power the only advantage to a 'header' is it is lighter. What a header is, is... Noisy Runs hotter under hood temperatures. Almost always poorly made and have poor fit and leak. They rust out. Expensive. You will never 'feel' the difference driving around town. If there is a HP gain, it is all at the top RPM end of the spectrum.* * If you have a larger carb or carbs, modified (ported) intake and exhaust with larger valves and a stronger cam you will see more results than with a stock engine. For the most part, the money spent on a header could be better spent on something else. Other than weight how is a header worth the bother? Tell the truth most of the gains are in the driver's head. Quote Link to comment
Burabuda Posted December 3, 2015 Report Share Posted December 3, 2015 what he said ^ i think the only time a header makes sense on an a-series if it's on a race car if you do it anyway be aware some headers foul the intake Quote Link to comment
LUIS COLCHETE Posted December 3, 2015 Author Report Share Posted December 3, 2015 I ve just grind it a bit, to join the header to the head surface, but it is a quite grind... there is a litle break, but the gasket will cover it... Exist a header which that i dont need to grind to much? Quote Link to comment
LUIS COLCHETE Posted December 5, 2015 Author Report Share Posted December 5, 2015 I have just grind the header, and i assembly them in cylinder head. I have a doubt, if you see the picture the intake is to closed to header. Im afraid when the header get it hot becames closer to the intake and broke it, there is a smalll clearance between them Give me your opinions... and advices Many thanks on advance Luis Quote Link to comment
datzenmike Posted December 5, 2015 Report Share Posted December 5, 2015 Yes that combination is a bit close. You could remove some metal from the aluminum intake as well. Paint the exhaust and the intake silver or white to reduce radiated heat. Is it possible that the two intakes are swapped and on the wrong side??? Could moving them give more clearance? Quote Link to comment
LUIS COLCHETE Posted December 5, 2015 Author Report Share Posted December 5, 2015 Hi! Thanks Unfortenately the intakes are correctly assembled... i ill grind the header as much it possible... the intake i wont grind it .... it was a quiet spent.... if i cant get a safety clearance i must choose a difrent header..... Any ideias.... Many thanks Luis Quote Link to comment
datzenmike Posted December 5, 2015 Report Share Posted December 5, 2015 I don't like them but you may have to go with a tubular header... Quote Link to comment
LUIS COLCHETE Posted December 12, 2015 Author Report Share Posted December 12, 2015 Next week i will buy this header, i will see if makes longer kms and years with no problems.... Quote Link to comment
LUIS COLCHETE Posted December 14, 2015 Author Report Share Posted December 14, 2015 Hi! Please let me me know the best choice: I ve see this picture from a menber and i decide to find a similiar one in my country and i find it. What do you think it is better than the another? Less wldings an more direct. The seller told the header fits with weber carbs, i told them i have a harada intake they fit with weber and solex. My problem still the clearance again? I ve made several changes in engine datsun 1200, i dont know how much hp it males, but maybe 85 or 95. The header i ve find has 1.5" tubular pipe. Let me know if 1.75" is a better choice for exhaust piping? " or keep 1 1/2" stndard? Many thanks on advance Luis Quote Link to comment
datzenmike Posted December 15, 2015 Report Share Posted December 15, 2015 I would stay with the smaller pipe size to keep the gas speed higher. That header look good! Quote Link to comment
LUIS COLCHETE Posted December 15, 2015 Author Report Share Posted December 15, 2015 My will be equal Quote Link to comment
njoz1200ute Posted December 15, 2015 Report Share Posted December 15, 2015 Headers on an A series, why the f not? Don't belittle our beloved A series. They make it sound even better than it already does. Adds a small amount of hp, the stock engine only has about 67hp so any gain is beter than none. If i had 300hp and gained 2hp than who cares. And they look awesome. Go for it. Quote Link to comment
datzenmike Posted December 16, 2015 Report Share Posted December 16, 2015 Have to agree on the header, but only because the stock exhaust manifold does not clear the intake properly. Still maintain that they are... Noisy Runs hotter under hood temperatures. Almost always poorly made and have poor fit and leak. They rust out. They come loose. Live about 3-5 years, with luck and attention. Expensive. You will never 'feel' the difference driving around town. If there is a HP gain, it is all at the top RPM end of the spectrum.* Quote Link to comment
LUIS COLCHETE Posted December 16, 2015 Author Report Share Posted December 16, 2015 Hi! The Iron Cast from A14, has 41mm diâmeter, i think i will order the tubular one with the same size, as well the rest of exhaust pipe. The shop as only 41 mm tubular header What do you think? Quote Link to comment
datzenmike Posted December 16, 2015 Report Share Posted December 16, 2015 Sounds good. Quote Link to comment
LUIS COLCHETE Posted January 3, 2016 Author Report Share Posted January 3, 2016 Hi! I ve just assembly for my early datsun A2 crankshaft, pistons, camshaft, sprockets and chain, i have A12 late bolts for flywheel, DONT FIT... Please confirm me if are the correct reference number that i find, im not sure flywheel bolts 12315-H1001 Thread : 3/8-24-inches. Hex head : 14mm.Thread length: 20mm.Head bottom length: 22mm.Whole length: 29mm. cylinder head I have a A14 cylinder on A12 early block can i buy A14 bolts? 11056-H1000 Thread: M10-P-1.5-metric. Hex head : 14mm.Thread length: 25mm.Head bottom length: 70mmWhole length: 107mm. Many thanks on advance Luis Quote Link to comment
datsunfreak Posted January 4, 2016 Report Share Posted January 4, 2016 I ve see this picture from a menber and i decide to find a similiar one in my country and i find it. That header look good! It's made by Kirk Racing for Nissan Motorsport. It's a race car part, but it's made very well, and not prone to leaking/cracking/rusting like many of the cheaper versions. Maybe see if they will ship you one? http://www.kirkracing.com/headers.html Quote Link to comment
LUIS COLCHETE Posted January 4, 2016 Author Report Share Posted January 4, 2016 Hi! Please confirm me I want to assembly A14 late cylinder head on A12 early Block, but i want buy new 13 bolts. 13 Bolt references. Please confirm me 11057-H5700 OIL bold 11056-H2301 Bold Many thanks on advance Luis Quote Link to comment
LUIS COLCHETE Posted January 5, 2016 Author Report Share Posted January 5, 2016 hI! Can i assembly 13 stamped bolts? In afirmative way, please give the references Quote Link to comment
LUIS COLCHETE Posted January 27, 2016 Author Report Share Posted January 27, 2016 Almost awake... im so curious to hear the sound.... 2 Quote Link to comment
Lockleaf Posted January 27, 2016 Report Share Posted January 27, 2016 Looking good Quote Link to comment
LUIS COLCHETE Posted January 27, 2016 Author Report Share Posted January 27, 2016 Thanks..... Quote Link to comment
datsunfreak Posted January 28, 2016 Report Share Posted January 28, 2016 Very nice. :thumbup: Quote Link to comment
LUIS COLCHETE Posted July 17, 2016 Author Report Share Posted July 17, 2016 hI! I need your advice! It worth it, buy some heater wrap and put on header to avoid high temperatures against carbs? i have no big clearence to increase a metal shield between them. Or do nothing! And pedal to the metal................................................. Quote Link to comment
