criminalslang-810 Posted November 18, 2015 Report Share Posted November 18, 2015 I bought a crown vic police car from a local junkyrad ( thus making me behind on datsun project ). well i wanted to document a build cause the datsun was such a get it done type thing..... 1 Quote Link to comment
criminalslang-810 Posted November 18, 2015 Author Report Share Posted November 18, 2015 so i installed a window first in car after the purchase Quote Link to comment
criminalslang-810 Posted November 18, 2015 Author Report Share Posted November 18, 2015 Then i got some fenders ,but doing the fenders wasnt like a datsun or nissan fenders.........................https://youtu.be/pUo-aEaPm3k Quote Link to comment
criminalslang-810 Posted November 18, 2015 Author Report Share Posted November 18, 2015 So after the fenders i went back to dastun and meshed a 240sx cluster on to a datun dash. https://youtu.be/jSgEuicdyaI Quote Link to comment
criminalslang-810 Posted November 19, 2015 Author Report Share Posted November 19, 2015 I have a plan for the motor.....There will not be a ford motor in it ( later on ) now the theory is if i subtract 4 cylinders and turbo it,, Remember the key is to get 350hp ..the 4.6 internals are weak, i can swap a 5.4, but i will get 250hp with a lot of TQ,.. Now i like to rebuild motors start fresh.... and the budget oh heads and gaskets and apr studs, then a 350 to 500 tune...Now that $3,910 left to spend and i cant do suspension and wheels... ( i need some wheels ).....So i have a motor in my Datsun ( that stays ) but i have a spare motor with cams, and springs and the crank can hold 1,000hp so get some pistons and rods and a tune ( right? ) So you know where i am going..... going to do some math and numbers later and post a vid up...Once i get the facts in order...for now have to get the front end worked on.....and shave some pounds off the car, but not make it too ratish i have the Datsun for that...... Quote Link to comment
criminalslang-810 Posted November 19, 2015 Author Report Share Posted November 19, 2015 Crown Victoria weights around 4000lbs around also a Q45 1st Gen.................. 4.6 with trans weights around 520lbs My selected 4 bagger said to weights around 461lbs i know, but i can make more power cheaper thus the point....Now this may change if i find a deal but i dont think i am changing cause i am curious how slow it would be or fast, but more on the slow side... Quote Link to comment
datzenmike Posted November 20, 2015 Report Share Posted November 20, 2015 I have a plan for the motor.....There will not be a ford motor in it ( later on ) now the theory is if i subtract 4 cylinders and turbo it,, Remember the key is to get 350hp ..the 4.6 internals are weak, i can swap a 5.4, but i will get 250hp with a lot of TQ,.. Now i like to rebuild motors start fresh.... and the budget oh heads and gaskets and apr studs, then a 350 to 500 tune...Now that $3,910 left to spend and i cant do suspension and wheels... ( i need some wheels ).....So i have a motor in my Datsun ( that stays ) but i have a spare motor with cams, and springs and the crank can hold 1,000hp so get some pistons and rods and a tune ( right? ) So you know where i am going..... going to do some math and numbers later and post a vid up...Once i get the facts in order...for now have to get the front end worked on.....and shave some pounds off the car, but not make it too ratish i have the Datsun for that...... Crown Victoria weights around 4000lbs around also a Q45 1st Gen.................. 4.6 with trans weights around 520lbs My selected 4 bagger said to weights around 461lbs i know, but i can make more power cheaper thus the point....Now this may change if i find a deal but i dont think i am changing cause i am curious how slow it would be or fast, but more on the slow side... Four thousand pounds? Four cylinder? Hopefully a large displacement SC or turbo diesel with stump pulling torque. Can't see that being cheaper to make than a gas engine. A gas engine won't make enough torque to move that road barge. You need displacement and torque at low RPMs. 1 Quote Link to comment
Beef Weasel Posted July 15, 2016 Report Share Posted July 15, 2016 Quit Messing around. 427 sohc SC Quote Link to comment
criminalslang-810 Posted December 18, 2016 Author Report Share Posted December 18, 2016 Not on here much i still dont make may way around in this forum well.. I am trying, but no luck lmao Quote Link to comment
criminalslang-810 Posted December 18, 2016 Author Report Share Posted December 18, 2016 As far as a 4 cylinder in a Full size car ( it is stupid ) , but to see it done i am willing to do it would be quite a strange ride ( would it move ) off the line like stock in turbo form . These things i wonder about Quote Link to comment
criminalslang-810 Posted December 18, 2016 Author Report Share Posted December 18, 2016 Sorry dont know how to work this thing..................In the video you can see my Datsun 810 build with a ka24det motor in it ( it runs ) 11:00 video marker Quote Link to comment
