Rick-rat Posted November 16, 2015 Report Share Posted November 16, 2015 No Rick, see the block in your mind, then you tell us what it is. That doesn't make any sense at all, can't really tell by the thread title, don't like to read in something that is not there 1 Quote Link to comment
Draker Posted November 16, 2015 Report Share Posted November 16, 2015 Literal-Rick 2 Quote Link to comment
Rick-rat Posted November 16, 2015 Report Share Posted November 16, 2015 I have taken everything literally since my last stroke, just ask my wife 1 Quote Link to comment
TENDRIL Posted November 16, 2015 Report Share Posted November 16, 2015 im premature sure that everyone knows what a small block is 1 Quote Link to comment
Rick-rat Posted November 16, 2015 Report Share Posted November 16, 2015 Briggs and Stratton- small block. L-16- small block, 265 to 400 Chevy- small block, 260 to 351 ford- small block, 427 engines- big block. As I said I don't read anything into the title of the thread. 1 Quote Link to comment
banzai510(hainz) Posted November 16, 2015 Report Share Posted November 16, 2015 I have the same grenn color 521 I guy told me to do what you are doing right now.Said it was EZ I notice he was driving a Honda Accord so I didnt put to much weight in what he said. In the end these get put off on the side of the house as they not practicle to drive. Get HOT ect...... But I will see if you finnish. Then 3 yrs from now it will be on Ebay(to fund the next project) A nissan KA motor woud be more practicle but havent seen to many of them finnished either(most are projects in the Sale section) 4 Quote Link to comment
Anderson521 Posted November 16, 2015 Author Report Share Posted November 16, 2015 I have the same grenn color 521 I guy told me to do what you are doing right now.Said it was EZ I notice he was driving a Honda Accord so I didnt put to much weight in what he said. In the end these get put off on the side of the house as they not practicle to drive. Get HOT ect...... But I will see if you finnish. Then 3 yrs from now it will be on Ebay(to fund the next project) A nissan KA motor woud be more practicle but havent seen to many of them finnished either(most are projects in the Sale section) Now just curious do you actually know someone who has done this build and can provide insight whether these allegations are true? I don't keep vehicles forever and will eventually sell it but certainly not before I finish it and slay some tires 2 Quote Link to comment
banzai510(hainz) Posted November 16, 2015 Report Share Posted November 16, 2015 NO was just a guy talking far as I was concerned.(if talking V8) If it was so EZ he would have been driving it instead of the Honda KA install there has a been a few on craigslist be most wer not running. Installed motor and then go Bankrupt!!!!!! and cant figure out the wiring 3 Quote Link to comment
Anderson521 Posted November 17, 2015 Author Report Share Posted November 17, 2015 Certainly another reason I went with the older motor, just a starter and distributor 1 Quote Link to comment
BlueCoupe Posted November 18, 2015 Report Share Posted November 18, 2015 Hope to see this come through, we need more V8 datsuns up in here! Lol 1 Quote Link to comment
TENDRIL Posted November 18, 2015 Report Share Posted November 18, 2015 no we dont 8 Quote Link to comment
DaBlist Posted November 18, 2015 Report Share Posted November 18, 2015 Never have seen a 521 small block, have seen 488 small blocks. Is this GM, Ford, or Mopar small block to start with? A small block is a type of vegetable juice 2 Quote Link to comment
Anderson521 Posted November 19, 2015 Author Report Share Posted November 19, 2015 7 Quote Link to comment
Anderson521 Posted November 19, 2015 Author Report Share Posted November 19, 2015 So got the lights hooked up, wiring harness was pretty chewed up from previous owners. Poked around with gator clips for a bit. Still working on rear running lights and blinkers. 1 Quote Link to comment
paradime Posted November 19, 2015 Report Share Posted November 19, 2015 As far as I know, there is quite a bit more to a V8 swap than cutting the fire wall and wiring lights. Can you fill us in on the motor mounts, transmission mounts, drive shaft, steering, suspension upgrades, breaks, exhaust, etc. 2 Quote Link to comment
mrbigtanker Posted November 20, 2015 Report Share Posted November 20, 2015 Love it lookimg good. Quote Link to comment
paradime Posted November 23, 2015 Report Share Posted November 23, 2015 As far as I know, there is quite a bit more to a V8 swap than cutting the fire wall and wiring lights. Can you fill us in on the motor mounts, transmission mounts, drive shaft, steering, suspension upgrades, breaks, exhaust, etc. Oh... Please? Quote Link to comment
KdotGong521 Posted November 23, 2015 Report Share Posted November 23, 2015 I wanted to do a small block for my 2nd option but stuck with nissan and got a KA on the stand now. Quote Link to comment
Anderson521 Posted November 29, 2015 Author Report Share Posted November 29, 2015 What did you do for braking? I've been trying to look in the different sections but I'm wondering if you have a link or suggestion as to which rotors, calipers etc to get that will bolt on Quote Link to comment
datzenmike Posted November 29, 2015 Report Share Posted November 29, 2015 The 10" rear drums are plenty good enough except for the obvious drawbacks, like keeping them adjusted. I won't mention brake fade as I don't expect you will be canyon carving or driving hard enough or long enough to require rear discs. Fronts do not have any bolt in discs and calipers but there are conversion kits made by members here. Type disc brakes for 521 or 521 disc brakes or disc break conversion for 521 into our search and start reading. Quote Link to comment
datson4life Posted November 29, 2015 Report Share Posted November 29, 2015 The wilwood setup is really easy and bolt on, no cutting or welding, but the other setups are legit aswell, from mklotz and beebani Quote Link to comment
Anderson521 Posted November 30, 2015 Author Report Share Posted November 30, 2015 Sweet ill look into it more, thanks for the direction! Wildwood is loot but you get what you pay for Quote Link to comment
Anderson521 Posted November 30, 2015 Author Report Share Posted November 30, 2015 Got a drive shaft with yoke and a slave cylinder today from a 95 chevy pickup, both bolt right in an the Drive line has matching splines 1 Quote Link to comment
Draker Posted November 30, 2015 Report Share Posted November 30, 2015 Use IMG code: Quote Link to comment
Anderson521 Posted November 30, 2015 Author Report Share Posted November 30, 2015 2 Quote Link to comment
