itsallgood Posted November 15, 2015 Report Share Posted November 15, 2015 i have one on: exhaust manifold, distributor, and webber carb. i also have one on the air filter that i guess go's to the valve cover. any help would be great. Quote Link to comment
datzenmike Posted November 15, 2015 Report Share Posted November 15, 2015 There is a hose from the valve cover to the air filter housing. It provides filtered 'make up' air removed by the PCV valve system. There is a hose from the ported outlet on the carb to the vacuum advance on the distributor. I think this is all the 520 had. You say J15 so this is a newer Mexican engine used on several later Datsuns normally run with L Series. So at a guess, if the exhaust pipe is a metal one then this is for a much later EGR set up. Pictures??? Quote Link to comment
itsallgood Posted November 15, 2015 Author Report Share Posted November 15, 2015 hear r a few i have on my computer. the truck is in my shop now. so i cant take any pic of the exhaust manifold. now that i think about it the vaccumee is on the intake manifold not the exhaust. 1 Quote Link to comment
