bananahamuck Posted November 2, 2015 Report Share Posted November 2, 2015 Not planning on parting it out, the only thing I have taken off is the wiper motor to clean but found out that a piece was broken in the arm assembly, looked to be a brittle copper ot bronze notched washer type piece. May be on the market for a new motor Not sure about the copper thing you're describing but instead of buying "new to you motor" just take your wiper motor into a shop that rebuilds electric motors,,, Pumkin Dave says there is a very good ( and cheap) rebuild shop in Puyallup. here is a motor off of Ebay in Oregon. early http://www.ebay.com/itm/EARLY-1966-DATSUN-411-BLUEBIRD-ELECTRIC-WINDSHIELD-WIPER-MOTOR-REMAN-JIDECO-OEM-/391182158578?hash=item5b14460af2:g:lVQAAOSwu4BVizzd&vxp=mtr Late ,,, same seller http://www.ebay.com/itm/1966-1967-DATSUN-411-BLUEBIRD-ELECTRIC-WINDSHIELD-WIPER-MOTOR-REMANUFACTURED-OEM-/371361775323?hash=item5676e2fedb:g:i8MAAOSw9N1Viz1q&vxp=mtr Quote Link to comment
Bkplunk64 Posted November 3, 2015 Author Report Share Posted November 3, 2015 I will have to look I to that, thanks bananahamuck Quote Link to comment
Bkplunk64 Posted December 15, 2015 Author Report Share Posted December 15, 2015 I hate that I have not been able to do more work on here,but she is about to embark on a 2600 mile journey carrying me home. Quote Link to comment
Bkplunk64 Posted December 15, 2015 Author Report Share Posted December 15, 2015 If anyone sees this in time and is anywhere close to the tacoma, wa area I have a set of horns, 3 hub caps, a rear bumper for 67 411. Quote Link to comment
bananahamuck Posted December 15, 2015 Report Share Posted December 15, 2015 If anyone sees this in time and is anywhere close to the tacoma, wa area I have a set of horns, 3 hub caps, a rear bumper for 67 411. When are you leaving i could come tomorrow , How much for bumper ?? Are you going south I5?? i could meet up along the route Quote Link to comment
Bkplunk64 Posted December 15, 2015 Author Report Share Posted December 15, 2015 Not sure the route I'm gonna take yet, I'm not leave untill the 23rd. Your in Olympia correct bananahamuck? Quote Link to comment
bananahamuck Posted December 15, 2015 Report Share Posted December 15, 2015 Yes.. Quote Link to comment
Bkplunk64 Posted December 15, 2015 Author Report Share Posted December 15, 2015 I make just make a trip down there. One day this week. As for the cost how does free sound? You have been a big help on here. 2 Quote Link to comment
MikeRL411 Posted December 15, 2015 Report Share Posted December 15, 2015 If anyone sees this in time and is anywhere close to the tacoma, wa area I have a set of horns, 3 hub caps, a rear bumper for 67 411. 67 PL411 or RL411? There are dirences! Quote Link to comment
Bkplunk64 Posted December 15, 2015 Author Report Share Posted December 15, 2015 Pl411 Quote Link to comment
bananahamuck Posted January 27, 2016 Report Share Posted January 27, 2016 Now i know you must have gotten this home by now,, :D Now get us some dang side of the road and update pictures.. If update is a few pictures of it at the burger joint down the street,, THAT is more than good enough. Quote Link to comment
Bkplunk64 Posted January 27, 2016 Author Report Share Posted January 27, 2016 Lol ok I'll get on that today, I have been working on putting 280z seats in, got the drives side in. I will say it's nice having a reclining seat again. Quote Link to comment
Bkplunk64 Posted January 27, 2016 Author Report Share Posted January 27, 2016 I need to know the proper placement of the condenser, and wiring, I'm burning my points and I'm going to start with a new condenser Quote Link to comment
MikeRL411 Posted January 27, 2016 Report Share Posted January 27, 2016 I need to know the proper placement of the condenser, and wiring, I'm burning my points and I'm going to start with a new condenser There's a clockwise wire leading from the points plate to a black plastic feedthrough on the side of the distributor. On the outside, you will see a push-on connector for the point ground wire. Loosen the screw,install the capacitor lead and retighten. The capacitor has a ground lug with a hole in it. Bolt this lug to the side of the lower distributor housing, there's a tapped hole for it. Side item, the ground lead at the distributor is a good theft protection device. Unplug it and hide it in the wiring harness. Car won't start without a ground at the points! Much less obvious that pulling the rotor. Quote Link to comment
bananahamuck Posted January 28, 2016 Report Share Posted January 28, 2016 It seems like you posted that you don't have resistor before your coil ,, and maybe even a non-resistor type coil?? When you're running points having a resistor helps the points last longer. Quote Link to comment
Bkplunk64 Posted January 28, 2016 Author Report Share Posted January 28, 2016 I'm planning on picking one up today, I had to take the dizzy out to change the condenser, I'm gonna also put my old ignition coil back on just incase the new oNE has a resistor in it, I could not not get any info about it from the parts guy in Wyoming. Quote Link to comment
Bkplunk64 Posted January 28, 2016 Author Report Share Posted January 28, 2016 2 Quote Link to comment
Bkplunk64 Posted January 28, 2016 Author Report Share Posted January 28, 2016 3 Quote Link to comment
Bkplunk64 Posted January 28, 2016 Author Report Share Posted January 28, 2016 Will have a photo of the 280z seat I have in later. Quote Link to comment
Bkplunk64 Posted April 7, 2016 Author Report Share Posted April 7, 2016 Finally got around to replacing the fuel lines and got rid of the electric pump and started using the mechanical pump that I was told didn't work. Seems fine to me, a hell of a lot better than the electric one. Quote Link to comment
