Kytoaster Posted October 26, 2015 Report Share Posted October 26, 2015 holy COW.Amazing difference, definitely recommend if you've been thinking about replacing your shift bushings!Before (No bushings at all), I could move the shifter in roughly a basketball sized circle while in any gear.Now, I hardly have any play at all while in gear, and it clicks solidly into each gear. I grabbed This guy:Put these into the shifter using a viceHad to grind down the sides of them to get it to fit using a file (around 5 min of filing).The pin that holds the shifter in place will JUST fit into the bushings with a good amount of lube (I used anti-sieze and a c clamp) to get it through.Doing a bit of light filing to widen the new bushings would have been easier, but I was cold and it was getting dark out.Took around an hour between going to 3 different parts stores to find the right door hinge set, removing, pressing them in, filing to fit and c clamping the pin back in. Totally worth it, here's the original post I found the info on, just wanted to share with everyone in case someone hadn't seen it!http://atlanticz.ca/zclub/techtips/shifterbushing/index.html 7 Quote Link to comment
Draker Posted October 26, 2015 Report Share Posted October 26, 2015 Good info! Thanks for sharing. Quote Link to comment
jesusno2 Posted October 26, 2015 Report Share Posted October 26, 2015 You can buy the originals for around 15 bucks on ebay and ya dont gotta do a buncha extra work. Quote Link to comment
Draker Posted October 26, 2015 Report Share Posted October 26, 2015 I think the idea is the brass bushing will last longer and perhaps offer a bit more crisp shift. 1 Quote Link to comment
Draker Posted October 26, 2015 Report Share Posted October 26, 2015 I've got the OEM replacements in my car, they are fine and you get a bunch(5?) of them in the package. Quote Link to comment
MicroMachinery Posted October 26, 2015 Report Share Posted October 26, 2015 Thanks for the info, OP. Been looking to do this but didn't know what set to buy. Quote Link to comment
kelowg Posted October 27, 2015 Report Share Posted October 27, 2015 Yes, these work great. U forgot to mention,u have to cut thru them so they can be pressed in. I didnt have to file anything down tho. Being metal,they will last much longer,tho makes for bit more powertrain noise. Quote Link to comment
datzenmike Posted October 27, 2015 Report Share Posted October 27, 2015 Mine was tight in the shifter and loose on the pin... So I made one pass through them with a hacksaw. Perfect fit no pressing and they fit the pin snug. 2 Quote Link to comment
red13 Posted October 27, 2015 Report Share Posted October 27, 2015 No need to cut mine pressed in just fine then filed out the center. Quote Link to comment
Kytoaster Posted October 27, 2015 Author Report Share Posted October 27, 2015 Yes, these work great. U forgot to mention,u have to cut thru them so they can be pressed in. I didnt have to file anything down tho. Being metal,they will last much longer,tho makes for bit more powertrain noise. I actually didn't cut mine? I just pressed them in on my vice with a little anti-sieze on them. That said, it would have probably helped to have made a tiny cut through them. Quote Link to comment
