Charlie69 Posted April 14, 2016 Author Report Share Posted April 14, 2016 Thanks Mark. The medical equipment will be on loan for free. I can keep it up to 90 days. so I will return it as soon as I can and go get it just before the second knee replacement. All the parts came in from Rock Auto today. It pisses me of when you order tie rods and ball joints and some come in with zerk fittings and some do not have them. But at least they are new and should last a good long time. See you when you get here. Quote Link to comment
Charlie69 Posted April 17, 2016 Author Report Share Posted April 17, 2016 Tom, Gene, and I worked on the ST today. First we installed the windshield. Getting the old one out was a pain. The last glass company that installed it use Butyl sealer all the way around inside and out. What a mess to scrape off. Gene installed the AC condenser and the head lights. He also helped Tom and I with the windshield install. After Tom left Gene and I worked on the drive line, new U-joints and a new carrier bearing. I picked up all the cleaning supplies, oils land lubricants. went to install the new slave cylinder and it was wrong. Picked up a new copper crush washer for the hydraulic line and the correct slave cylinder. Gene and I installed the drive line and the slave and hydraulic hose. Tomorrow we will tear apart the front end and while I put the front end together Gene will do the tune up. after we finis that we will install the new clutch master and bleed the clutch. We will hopefully get the Brakes bleed and working also. I will probably install the new loaded calipers, rotors, and wheel bearings during the front end rebuild. If the brakes work I will send the pars with Mark to do the rear bakes. I will also be looking into getting the title from a third party MVD store. Quote Link to comment
gene knight Posted April 17, 2016 Report Share Posted April 17, 2016 I'm going to help out for a few hours before I have to go to work at 3pm. Idk if we will get anything bled, but maybe just the clutch system, and maybe get the tune up done 1 Quote Link to comment
Charlie69 Posted April 18, 2016 Author Report Share Posted April 18, 2016 Gene replaced the taillight pigtail and the tail lights. He also replaced the front fender lights . He installed the radiator and the fan shroud. He will do the tune up tomorrow. I chase small parts and hardware and then I tore the front suspension and steering apart. I managed to get the drivers side ball joints installed and and the passenger side tore down. I hate under coating, it really slows things down. This is the old style hardening under coating. I will work on it tomorrow evening. I hope to finish the front end. Quote Link to comment
Charlie69 Posted April 19, 2016 Author Report Share Posted April 19, 2016 Gene picked up the rebuilt radiator today. Gene worked on the truck today and got the center link changed and the strut rod bushings done. I put the lower ball joint on the right side and the top ball joint is the wrong one so I will see what I can find local tomorrow. I will clean the hubs, repack the bearings as they are in great shape and install new seals and rotors. The calipers are working fine so I will install new pads. Hopefully be able to finish the front end work and get the alignment done on Friday. I will add the flush and water to the radiator when I am ready to drive it to the alignment shop. I will drive the truck all day Friday to check for any problems. Mark will have to fix the bad muffler in Bullhead as I am running out of time and money. Wednesday Gene and I will rebuild the rear brakes and bleed them and the clutch. I went to a third party today and got a title for $17. All I have to do know is when Mark comes down on Saturday is take him and the title to a third party MVD and transfer the title to him. Mark with proof of insurance and about $60 will be able to title, register, and plate the truck. Mission accomplished. It is titled Yay!!! Total Bonded Title coast was $134. Saved about $141 over having the 3rd Party MVD do it. It was a hassle but it is done now. Quote Link to comment
Charlie69 Posted April 19, 2016 Author Report Share Posted April 19, 2016 Oh by the way Mark I am going to drive your truck like I stole it. LOL 1 Quote Link to comment
gene knight Posted April 19, 2016 Report Share Posted April 19, 2016 You hope 2 Quote Link to comment
KoHeartsGPA Posted April 19, 2016 Report Share Posted April 19, 2016 Oh by the way Mark I am going to drive your truck like I stole it. LOL Don't forget to get video! 1 Quote Link to comment
gene knight Posted April 20, 2016 Report Share Posted April 20, 2016 Well i changed out the center link bar, replaced both inner /outer tierods replaced rotors, and greased up inner/outer hub bearings..hopefully finish the front end, and get it bleed 1 Quote Link to comment
Charlie69 Posted April 20, 2016 Author Report Share Posted April 20, 2016 I watched! LOL Quote Link to comment
Pacific coast Datsun Posted April 21, 2016 Report Share Posted April 21, 2016 TY guys for all the hard work. Charlie ill be at.your place Sat evening & I.got your Vin # email thanks. 1 Quote Link to comment
gene knight Posted April 21, 2016 Report Share Posted April 21, 2016 Finally finished the front suspension, replaced spark plugs and wires, clutch master cylinder, and brake master cylinder 1 Quote Link to comment
Charlie69 Posted April 22, 2016 Author Report Share Posted April 22, 2016 I watched! LOL Quote Link to comment
gene knight Posted April 23, 2016 Report Share Posted April 23, 2016 Well we got it drivable took it for a drive, 2 Quote Link to comment
Charlie69 Posted April 23, 2016 Author Report Share Posted April 23, 2016 Well took it to Jack's Alignment and found out the frame is bent and it can not be aligned. My brother Garret has a friend that has a frame straightening jig and equipment so I will get an estimate and if it is not to expensive I will have the frame straightened. Quote Link to comment
gene knight Posted April 23, 2016 Report Share Posted April 23, 2016 Hopefully we don't have to remove everything in order to fix the frame 1 Quote Link to comment
Pacific coast Datsun Posted April 24, 2016 Report Share Posted April 24, 2016 TY guys for all the hard work.and time youve put into the 720. 1 Quote Link to comment
gene knight Posted April 24, 2016 Report Share Posted April 24, 2016 It sucks that you couldn't make it out here Mark for that only reason 1 Quote Link to comment
Charlie69 Posted April 28, 2016 Author Report Share Posted April 28, 2016 Survived the first knee replacement, now get it healed up and get the other one done. 1 Quote Link to comment
KoHeartsGPA Posted April 28, 2016 Report Share Posted April 28, 2016 I'm glad that sexy nurse took good care of you, Charlie :thumbup: 1 Quote Link to comment
Charlie69 Posted April 29, 2016 Author Report Share Posted April 29, 2016 Had 7 hot nurses and now a case of blue balls!!! LOL Quote Link to comment
gene knight Posted May 30, 2016 Report Share Posted May 30, 2016 Well I took out the radiator that we installed when taking it to alignment shop and will get it cleaned up 1 Quote Link to comment
Charlie69 Posted May 30, 2016 Author Report Share Posted May 30, 2016 Thank you Gene I appreciate it. Quote Link to comment
720inOlyWa Posted May 31, 2016 Report Share Posted May 31, 2016 Get well, Charlie! 1 Quote Link to comment
Charlie69 Posted June 1, 2016 Author Report Share Posted June 1, 2016 5 weeks out of surgery and doing great. It is a slow process. I think the hardest part will be desensitizing my knee for kneeling. It is painful to kneel on my fake knee. 1 Quote Link to comment
