Hardbodykade Posted October 21, 2015 Report Share Posted October 21, 2015 Does anyone here know if a after market stearing wheel for a 240sx s13 will fit in to a 88 HB??? let me know something please Link to comment
KoHeartsGPA Posted October 21, 2015 Report Share Posted October 21, 2015 G O O G L E I T . Link to comment
hobospyder Posted October 21, 2015 Report Share Posted October 21, 2015 I'm gonna take a shot in the dark and say no just because you want it to 3 Link to comment
hobospyder Posted October 21, 2015 Report Share Posted October 21, 2015 On second though, buy the wheel and let us all know the answer. I'm assuming (probably falsely ) that you've already tried finding the answer on your own which means nobody has tried it, or if someone has tried it they weren't part of the current community and the knowledge on fitment is lost. Or you could take your whining elsewhere before the trolls come and eat you up. Although I really kinda want to watch that right now. Yes, you might have to spend money but sometimes that's the only way to get an answer to the question. 1 Link to comment
fritzdixxon Posted October 21, 2015 Report Share Posted October 21, 2015 Aftermarket wheel one that has 6 mounting bolts? If so they need an adapter ring that fits the splines on the steering collom, check part numbers at momo site if the ring is the same part number then the splines should be the same. Or if you can get your hands on the wheel ask seller if you can test fit it, pre pull your wheel then reinstall before you go to where the wheel is that way any hiccups get dealt with in advance and you will have all the tools you need at the ready Link to comment
Hardbodykade Posted October 21, 2015 Author Report Share Posted October 21, 2015 Thanks for your answer fritzdixxon appreciate Link to comment
flatcat19 Posted October 21, 2015 Report Share Posted October 21, 2015 Fit...probably. Will your spiral cable be compatable with the truck? Probably not. Welcome to Ratsun. Most things known started out as a trial and air whim. Derp. I really need to read threads twice before I post. The wheel is not the concern. It's the hub that means everything. Fritz hit it perfectly. Link to comment
hobospyder Posted October 21, 2015 Report Share Posted October 21, 2015 Hobo had a toss fit Hobo apologizes. Sorry Link to comment
flatcat19 Posted October 21, 2015 Report Share Posted October 21, 2015 Thinking back...I really think the hubs between an S13 and a D21 should be different. The stalks for the wipers and turns are set further back on the truck. What brand is the wheel? Did you look for an answer on infamousnissans.com? Link to comment
fritzdixxon Posted October 21, 2015 Report Share Posted October 21, 2015 And if you really really want the wheel go full Ratsun and take the whole steering colom and make it fit.lol 2 Link to comment
flatcat19 Posted October 21, 2015 Report Share Posted October 21, 2015 His project should be hard parked for a year and a half too. 3 Link to comment
fritzdixxon Posted October 21, 2015 Report Share Posted October 21, 2015 And if you really really want the wheel go full Ratsun and take the whole steering colom and make it fit.lol Link to comment
fritzdixxon Posted October 21, 2015 Report Share Posted October 21, 2015 Apparently my pocket liked that.....also just in case they are different ( or you like to count things) count the splines to make sure theyvarevthevsame Link to comment
HRH Posted October 21, 2015 Report Share Posted October 21, 2015 On page 35 of the Grant pdf catalog, it appears newer Nissan hub adapters are the same. Datsun will be different. Considering it's 88 and up, you should be good to go. 1 Link to comment
q-tip Posted October 21, 2015 Report Share Posted October 21, 2015 Damn fd, double posting like crazy eh? Link to comment
Rick-rat Posted October 21, 2015 Report Share Posted October 21, 2015 That's just the echo in here Link to comment
maltese Posted October 21, 2015 Report Share Posted October 21, 2015 That's just the echo in here. Link to comment
MicroMachinery Posted October 21, 2015 Report Share Posted October 21, 2015 Or you could take your whining elsewhere before the trolls come and eat you up. 2 Link to comment
russaroll Posted October 21, 2015 Report Share Posted October 21, 2015 http://lmgtfy.com/?q=will+an+after+market+stearing+wheel+for+a+240sx+s13+will+fit+in+to+a+88+HB%3F 1 Link to comment
Draker Posted October 21, 2015 Report Share Posted October 21, 2015 On page 35 of the Grant pdf catalog, it appears newer Nissan hub adapters are the same. Datsun will be different. Considering it's 88 and up, you should be good to go. Spoken like a true parts professional. 1 Link to comment
