Sign in to follow this
Andy_in_SD
Latest Progress
On the 70 (the white one) cut -n- weld is down to the fenders and whatever I find under them. Here's a pic after I pulled the first fender. You can see the rot at the bottom of the post (was hidden under the fender). So all the gets cut out and rewelded with new steel. The fender is rotten at the bottom (the usual spot) and it has a small dent I'll pop out under the headlight.
On the 66 (the red one), I need to order a set of valve shims (the flat ones) and exhaust valves. Then the head is completey restored and like new.
And of course, today it is raining....
Share this post
Link to post
Here is a zoom on the newly discovered rot I found after pulling the fender.
time for chop / chop / weld / weld....
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
